Question about NEC Electra Elite DTU 16D-2 Corded Phone
No dial tone on a nec dtu
I bought a nec phone on ebay... i know bad idea! i plug it to the phone jack, i get no dial tone. am i missing something?
The NEC phone is probably a business multi-line digital phone, requiring a phone 'back-end' system. Will not work on an analog 'home' phone line.
Posted on Mar 06, 2009
How to conference call on a nec dtu 32d 1a phone?
When your're on a call, you press Conference, get internal dial tone, dial the extension you want or 9 plus the whole outside number you want, then press Conference again to tie the calls together. Some exts only have access to one call at a time, so if you can't make 2 calls at a time, this feature won't work.
Sep 07, 2014 | NEC Electra Elite 32D-1 Corded Phone
One of my phones stopped ringing on my nec dtu 16d phone
Ringing is assigned in system programming, very little chance it was changed by mistake. If Do-Not-Disturb was turned on, that could make a phone stop ringing. If it's just one line on a phone, maybe the system got put in night mode by mistake and night programming isn't identical to day ring. If you have direct access to the phone line check it for dial tone. Often virtual lines are used and you can't check for direct dial tone. On very rare occasion the ringer stops working, which can't be fixed.
Jul 11, 2014 | NEC Electra Elite DTU 16D-2 Corded Phone
Does not ring
If you recently dialed 4-0 or 4-1, those are Do Not Disturb and Call Forward codes. if this is what happened, then dial the cancel code for both, which is 4-2. This is with internal dial tone, don't grab an outside to do this. You could have someone dial your extension to test if the ringer is faulty. if their call comes in as voice announce, have them add a 1 to their dial sequence and their call should switch to audible ring, and you will know it's not a ringer issue. Adding a 1 can be done continuously if you want to switch back and forth.
Jan 07, 2014 | NEC Electra Elite DTU 16D-2 Corded Phone
How do i change the extention number or port number when i move my Nec Electra Elite 192 phones to different wall phone jacks?
Look for the Elite Attendant User Guide
Also call your vendor for the password
SET RELOCATION MODE
Set/Cancel using the Access Code:
1. Press the
Feature
key.
2. Dial Set Relocation Mode code
84
Oct 16, 2013 | NEC Electra Elite DTU 16D-2 Corded Phone
Nec etw 8-2 wont work at home?
Sorry, but there is no way to get this phone to work on your normal residential phone jack. It was designed to be used as part of a key system, which requires the control system (also called the KSU). The phones are a proprietary digital design and only work when attached to the proper KSU. Unless you want to try locating the rest of the system on eBay or purchase through some other vendor, all you can do with the phone is use it as a paperweight.
Mar 12, 2010 | NEC DTU 8-1 Corded Phone
I want to move a phone. What do I need to do?
All you need to do is find the phone jack nearest to where you want the phone and plug it in. If the phone cord is plugged in properly, and the interior wiring of the house is in good shape, you should hear dial tone.
If not try moving the phone to a different phone jack until you do get dial tone.
Jan 22, 2010 | NEC Electra Elite 32D-1 Corded Phone
Programming speed dial numbers into NEC DTU-32D-1A phone
hit feature key,hit a line key,dial 9 plus the number,hit feature
Mar 12, 2009 | NEC Electra Elite 32D-1 Corded Phone
NEC DTU 16D-2 issue
hi,1.to adjust the ring tone volume. from your phone set,press speaker dial 601.press the arrow key up or down to adjust. 2. if your station is programmed as system admin phone,then you can press feature 80 feature.to toggle between day or night.do not press speaker button while doing this. 3.the headset port need to be program,or you can do without it,by purchasing the headset came with the adapter and connect thru the handset cord. the new model is DTH-16D. CAN email me if you need a new phone, sjohnnyh@yahoo.com
Sep 28, 2007 | NEC Electra Elite DTU 16D-2 Corded Phone
NEC Electra Elite DTU 16D-2 Corded Phone Logo
386 people viewed this question
Top NEC Lands Phones Experts
Brian LaDuca
Oloyede Monsuru
Are you a NEC Lands Phone Expert? Answer questions, earn points and help others
