Question about Whirlpool ED5VHGXM Side by Side Refrigerator
Slow ice making capacity---water flow slow. can not keep up with
I have a model ED5VHEXT001 that is one year old and it has never seemed to produce a suficient amount od ice for two average users. additionly the wter flow appears slow.
  • john_glenn95 May 21, 2009
    very slow to no water flow, and makes no ice. The water is hooked up and there is pleanty of pressure.
  • 537 Answers
Make sure your water source is completely open and your hoses are not clogged.
Posted on Feb 16, 2009
JCD-23 making too little ice
Check the water flow to the ice maker. Turn the supply water off, loosen a fitting near the ice maker and then turn the water on. You should get plenty of water. If it is slow, check the filter.
Dec 01, 2013 | Frigidaire FRS3R5EMB Side by Side...
Icemaker is slow in producing ice
If your icemaker is producing ice, but it is slow, there are 2 likely explanations.
1. Temperature. Water freezes at 32 deg, but the icemaker won't eject the ice until it gets below 10 degrees. If you always had good ice output and all of a sudden it has slowed down, you're temperature is a little higher than ideal. Check for a door seal not making good contact or try dropping the temp in the FREEZER side a couple degrees
2. New model. Most new refrigerators make ice much slower than older models to meet energy efficiency guidelines. This is not a repairable issue.
May 25, 2012 | GE Refrigerators
Icemaker has always been slow. It produces ice, just a couple or 3 times a day. We have to keep our old fridge running just to get enough ice... Cubes are full size, freezer is 0 degrees, not much...
The main reason behind an icemaker to make ice slow is the freezer temperature. It needs to be below 10 degrees. Also check the water inlet valve. Water is controlled by a timer and if its obstructed or slow filling, it will not make ice. You could also have a bad motor, defrost heater, or sensor. If these items fail, it usually won't make any ice. Check to be sure the electric plug from the ice maker is plugged in and check the water flow. However if it is filling up with water or if it just has a small amount in the cube maker. If it's making some ice, it's probably not a defrost problem. Check the voltage to the fill valve. Also replace the freezer's water filter, as clogged filters block water flow. Set the ice maker arm to "Off," and then twist the hanging filter cup counterclockwise to remove it. Rinse the cup under running water and discard the old filter cartridge inside. Slide a new filter cartridge into the cup and reinstall the cup assembly in the freezer.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
May 27, 2011 | Kitchen Ranges
Water flow is Very slow coming out
Could be you need to give the coils on the bottom a good cleaning.
5f76c03.jpgKeeping a good air flow on them coils increases ice production. Check your water filter. It may need to be replaced. YOUR SERVICE MANUAL
Jul 28, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Icemaker is very slow in making ice
Hello, When an ice maker is producing ice poorly or when it produce a few cubes or none or when the cubes are too small, it is usually because of a clogged water line or a defective water inlet valve.
Firstly, check the water line attached to the back of the refrigerator for good water flow. To do that, first turn off the water supply valve, then remove the water line from the back of the refrigerator. Next place the water line into a bucket and momentarily turn the water valve back on to test the flow, If the flow is poor you need to, repair, clean or replace the tubing or the shut-off valve that supplies the water. If the flow is good you may have to replace the water inlet valve.
Thanks
Jun 21, 2010 | Maytag 25.1 Cu. Ft. Bottom-Mount...
The fridge is not cold enough
you might want to try and clean the condensing coils on the outside of the unit, located either behind or underneth, this will really hinder performance. Also there is a fan located near the compressor on some models, make sure this is working. And check the fans on the inside (good air flow).
Aug 18, 2009 | Kenmore Refrigerators
Slow making ice. It is taking forever to fill the ice bin. What can I adjust to make it produce ice faster?
Clean the coils under the ice box so that the flow of air cools the condenser mo propah my amigo.
Jun 14, 2009 | LG LSC26905TT Side by Side Refrigerator
Slow ice maker,poor water dispencer flow
If you used a self piercing saddle valve to hook up to the water supply it is probably the source of your problem. These should never be used. You need to install a drill in type which will increase the water flow and probably never clog.
Apr 10, 2009 | GE PSS26SGRSS Stainless Steel Side by Side...
Slow water coming out od water dispencer in door.
first off replac ethe water filter in the unit this will slow down the flow
Feb 15, 2009 | Amana ARSE66MB Side by Side Refrigerator
Hoshizaki Ice Maker
check condenser condition can be dirty, cleaning the coils with coil cleaner for ice machines(i suggest you take all the ice out of bin first) i'd go with that first. check if it works for you.
Mar 28, 2008 | Hoshizaki Freezer Commercial Ice Machines...
Whirlpool ED5VHGXM Side by Side Refrigerator Logo
337 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
