Question about Epson Aculaser C1100 Printer
Replace toner problem
How to replace epson c1100 toner cartidge
  • Anonymous Feb 25, 2009
    How do you replace the cartridges before they are actually empty?
  • Anonymous Apr 18, 2009
    I have got the toner out.. and now I am having trouble trying to get it back in?
  • 3 Answers
To replace the cartridges before they are actually empty you should:
  1. Navigate to the reset menu (using down arrow)
  2. Select this (right arrow)
  3. Navigate till you get to Change Toner x (where x is the colour)
  4. Select this.
  5. Wait for the printer to stop churning.
  6. Open the front door and you should see the correct toner cartridge at the back.
  7. Follow the instructions just inside the door (or on the cartridge box.)
Posted on Jun 24, 2009
  • 163 Answers
When the toner is completely empty it will position itself ready for replacing and a message saying replace (C, M, Y, K,) toner will appear on the panel. Open the front cover, inside you will see the toner cartridge with a coloured lever on the right. Lift up the lever to unlock the toner and pull the cartridge forward. Remove the plastic strip on the new cartridge and insert it, ensuring that it is seated at both ends and lock the cartridge in by pushing the lever down.
If you wish to replace the toner before it is empty let me know & I will explain how to.
Posted on Feb 17, 2009
  • 8 Answers
5 Suggested Answers
SOURCE: epson c1100
thanks i will tray
Posted on Sep 06, 2007
Inky
  • 691 Answers
SOURCE: epson c1100
you may have replaced the cart with a faulty one. It does happen occasionally. Get another cart and swap that one also. If the error clears, return the original full cart for a refund as faulty. If the error does not clear you may have a problem with the receiver on the C dev and it will need an Engineer.
Posted on Sep 17, 2007
  • 4 Answers
SOURCE: Epson C1100 - Vertical faint stripes on colour photos
see if this solution fixes the problem.
Also clean the print head using instructions in the manual
http://www.fixya.com/support/t241840-smudges_color_printing_black_ok
Posted on Mar 06, 2008
Shah_Sheh
  • 81 Answers
SOURCE: Epson Acculaser c1100 ink blead
First rule out that it is a paper issue by trying a different type of paper
If that dosnt work
check if the gradation setting is too small when printing graphics. On the Basic Setting menu in the printer driver, click More Settings, adjust the gradation setting by sliding the Contrast slider bar
If that dosnt work
Clean the print head .
see steps at the bottom
If that dosnt work
It is starting to look like drum/photoconductor problem, this may need to be replaced (the most expensive solution)
Follow the steps below to clean the printer head.
r_1.gif Open the cleaner cover on the right side of the printer. Then, open cover A. d580095.gif
r_space.gif r_note.gif Note: r_space.gif r_space.gif Move the cleaner completely in and out. Otherwise, the printer may not be cleaned effectively. r_4.gif Push back the blue lever on the right inside of the printer. d580098.gif
Posted on Sep 11, 2009
How exchange cartridge for Epson C1100
Make sure that Ready or Sleep is displayed in the LCD panel.
Select Change Toner X (The letters C, M, Y, or K appear in place of X, indicating the colors Cyan, Magenta, Yellow, and Black.) in the Reset Menu on the control panel.While the cartridge X you selected above moves to the cartridge replacement position, Please Wait appears on the LCD panel.Replace Toner X appears in the LCD panel when the cartridge to be replaced reaches the cartridge replacement position.Then Open Cover A.Push up the right lever to unlock the toner cartridge. Then remove the toner cartridge from the printer.
May 15, 2010 | Epson Aculaser C1100 Printer
Where abouts is toner k
K toner is refering to black toner. Here is a link to Epson for your Aculaser C1100 Reference Guide. Look under Setup & Maintenence for >Replacing Consumable Products..... click on 'Toner Cartridge' for the proceedure.
http://support2.epson.net/manuals/english/page/aculaserc1100/ref_g/index.htm
Nov 27, 2009 | Epson Aculaser C1100 Printer
If that dosnt work
If that dosnt work
If that dosnt work
Sep 11, 2009 | Epson Aculaser C1100 Printer
Override Toner Out on Epson C1100
This may or may not work but you can try taking the toner cartridge out and carefully shaking it, (don't spill it on yourself) then re-install it and see if you've shaken enough toner loose to fool the printer.If so it may make a print for you if this doesn't work you have no option but to replace the toner cartridge.
Aug 31, 2009 | Epson Aculaser C1100 Printer
Epson acculaser c1100 ink replacement
K- black
M- Magenta (red)
Y- Yellow
C- Cyan (blue)
Hope this helps.
Jul 03, 2009 | Epson Aculaser C1100 Printer
How to change the balck toner only in the epsom aculator c1100 showing K toner low, but blue at the place the black should be?
Epson C1100's show toner low for a long time before it actually needs replacing (usually have another 500 - 1000 copies left). This is to give you time to order a new one. When it is completely empty you will get a message saying replace K toner and the cartridge will be moved into the front position ready to remove it. If you really must replace it before it is empty let me know and I will try to explain how to do it, although it is quite involved.
Please take a moment to rate this solution. Thanks.
Mar 03, 2009 | Epson Aculaser C1100 Printer
How to install toner chip on epson c1100
The toner chip is situated on the end of the toner cartidge - it's a circle, about 1.5cm in diameter.
They may have given you a new housing, in case you damage the one currently on your toner, when you try to remove it.
Nov 15, 2008 | Epson Aculaser C1100 Printer
Replace toner k
Replace black toner with new
Nov 27, 2007 | Epson Aculaser C1100 Printer
Epson c1100
Yes, they do make this model, I'm using one now. I had the same problem
The solution for me was to clean inside of printer thoroughly, with the C (or whatever) cartridge removed. The sensors get dirty.
Sep 04, 2007 | Epson Aculaser C1100 Printer
Epson Aculaser C1100 Printer Logo
912 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
