Question about Canon imageRUNNER 5000 Copier
Error Code : E000400-0100
We have a Canon imageRunner 5055 that just displayed this error code. Can you tell me what the code refers to? Please send your solutions to my email:zulkarnaini97@yahoo.com
Saya punya masalah dgn kode di atas. Mohon bantuan rekan2...!
TQ :)
  • Canon Expert
  • 1,326 Answers
The problem is with the adf. You can try to reseat the connectors on the adf controler PCB. Only do this with the copier turned OFF. If that does not work you will most likely need to replace the adf PCB
Posted on Feb 25, 2009
Clearing error e000067 canon irc2880i
Error Code Canon IR C2880i E-067-102 - CopyTechNet.com
www.copytechnet.com > ... > Copier Technical Discussion > Canon
Feb 6, 2013 - 10 posts - ‎5 authors
I have a Canon C2880i that has been giving strange messages. It started with the ... Had to clear dc-con for the drum lifes to regulate. Problem I ...
Canon ImageRunner Error Code Reset - Question Defense
https://www.question-defense.com/.../canon-imagerunner-error-code-res...
Nov 10, 2008 - These are the steps to resetting error codes on the iR5570/iR6570 and other ImageRunner printers. This also refers to eCopy, so follow the ...
How to give code for Normal ERROR in canon IR 3300 ...
? 2:28
https://www.youtube.com/watch?v=WyVgSjP_xms
May 19, 2014 - Uploaded by Prince tv
How to give code for Normal ERROR in canon IR 3300 ... thank you sir my canon ir2870 err no E000002-0000 ...
Jan 18, 2016 | Canon Office Equipment & Supplies
How to correct this error E0000040010
Dear
In service mode do in service mode
(COPIER >FUNCTION > CLEAR > ERR).
this may solve the problem. The code is due to the irregular supply to heater assembly. If J303 at DC-CON board is opened then the code may display.
Thanks.
Feb 02, 2015 | Canon Imagerunner 5055 Digital Copier
How do i fix error 000121-000?
According to the manual which I have put here under printers and copiers "If the job or operation does not complete correctly, check the End Code, and
perform the necessary operations according to the End Code displayed. You can
check the End Code in the Details screen under Log in the System Monitor screen.
(See "Checking Job Details," on p. 2-8.)
canon imageRunner 6020 Reference Manual Reference Manual List Of Error...
Feb 01, 2015 | Canon imageRUNNER 6020 Copier
Canon ir 5055 has an error e000004-0010. how di I fix this?
This is a fixing error code - there is too much temperature difference detected by the thermistors. Mostly a error reset will take care of the problem. You have to get into service mode first. Press the additional function key, then press the 2 & 8 keys at the same time, then the additional function key again. Then copier, function, clear, err, then OK. This clears the error code from the copier. Then power cycle the copier and the copier should be operational. If this doesn't work then you will have to have a technician fix it. DO NOT keep resetting the code. There is something wrong with the copier that needs to be taken care before major damage is done to the copier. Good Luck
Dec 08, 2010 | Canon imageRUNNER 5570 Copier
E000014-0000
yours machine problems is heater section is very hard rotate so you are clean the top roller and bottom rollers by using thinner or kerosine
Oct 23, 2008 | Canon imageRUNNER 5000 Copier
E000001-0000 error code
it s a thermistor problem
to clear the error do the following.
press additionel functionel* button & press 2&8 at a time &press additionel functionel button* select COPIER>FUN CTION>CLEAR>ERROR>OK.
Aug 06, 2008 | Canon imageRUNNER 5000 Copier
Error 001Fuser Problem
*then
2+8then
this will get you into service mode choose COPIER
then FUNCTION then
CLEAR then
ERR or ERROR then press OK(bottom right hand corner of screen)
turn power off then on
Thank you
Mar 12, 2008 | Canon ImageRUNNER 330s Copier
Error code no. E00004-0000
the fuser has a bad
thermistor or
thermofuse or
lamp
Dec 20, 2007 | Canon imageRUNNER 5020 Copier
Canon imageRUNNER 5000 Copier Logo
3,188 people viewed this question
old marine
old marine
