Question about Haier HDN305 Dehumidifier
Haier HDN305 Dehumidifier not working, Dead, fix or not to fix?
The unit was running fine for 2 1/2 years. Just stopped running. No lights, turn Humidistat nothing. Took unit apart checked fuse. Metal strip in fuse is intact. Float switch checked ok for continuity. Did not detect continuity on the Humidity switch. Is it possible it is just the humidity switch or could it be the capacitors in the unit? A new Humidity switch is around $26, if I have to replace other parts, I might as well buy new. Any pointers?
5 Suggested Answers
Buffalo12980
  • 625 Answers
SOURCE: Haier HDN655E unit runs but compressor won't kick in
use a jumper cord and go directly to the compressor to see if it will run. if it don't run, open up the motor box and see if there is a klixon overload inside. this should be normally closed. if it isn't replace it. the klixon is a thermal overload cutout. it usually trips because of high winding temperatures and protects the motor inside. the compressor is a hermetically sealed unit. no, or little freon will cause the motor to overheat.
Posted on Aug 21, 2007
SOURCE: 20% humidity reading
Hi, I just cleaned my dehumidifier and had the same problem as you. I used a spray water bottle and was not aware that the humidity sensor was being soaked. Very stupid of me!! Luckily I have two same dehumidifiers and used the other sensor to replace the one that I so stupidly ruined, and behold my machine worked again. Now I have to buy another sensor. To make sure we are talking about the same thing, my sensor is white,about 1 inch by 1/2 of an inch. It as 4 wires connected to it. To access it you remove the water tank, you will see 2 screws. Remove those, and pry the front panel loose. Be careful the top of the panel is held by two plastic hooks, they break easy. The sensor is located on the right side just above the radiator, under a produting oval lip which as foam around its rim. The wire colors are red black blue and yellow. Good luck Herman
Posted on Sep 20, 2007
SOURCE: Haier HDN305 Dehumidifier
agaver
Rank:nonexpert_s.gif Apprentice
Rating: 0%, 0 votes
Thanks qrx1llb3 for the help!
After carefully removing the plastic covers (yes, u need to remove both, I removed first the back one then the front one by pulling up, then disconnect the cable that joins the panel on the front cover with the electronic board on the upper right area) I found the electronic board with the blown up fuse. My was under a blue plastic cover. I'll try to replace it and see what happens! thanks for the help! :)
Posted on Jun 28, 2008
Illeagle
  • 525 Answers
SOURCE: Humidty reading remains at 84%
Dehumidifiers are generally a very simple appliance, however a humidistat is one of those items a person tends to rely on to provide feedback. You may want to remove the grille area where the humidistat is mounted and inspect for foreign material in the way of the sensor. If nothing foreign is detected then you should replace the humidistat.
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Posted on Jul 01, 2008
jgwhomeequip
  • 1902 Answers
SOURCE: Dehumidifier won't run
After all that testing you have diagnosed the problem. It is the main circuit board. So there is not reason to do any more test. I would just get a new control board and off you go
Posted on Apr 21, 2009
Hauier dehumidifier HDN305 suddenly won't turn on. No motor goes on and no red or green lights go on either. It's properly plugged in to a functioning electrical outlet which has a functioning...
You have already checked everything I would have suggested, so the only other thing I can think of is the temperature in the room, may be affecting it. If the ambient room temperature is above 112 degrees or below 32 degrees, the unit will shut OFF and not restart, until the temperature is within that range.
If you continue to have problems starting the unit, contact Haier America Customer Support 877-377-3639.
Hope this provided some help to you.
May 23, 2011 | Haier HDN655E Dehumidifier
I have a Haier HDN305 dehumidifier. It just sopped working and will not turn on. Can you help me?
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Apr 15, 2011 | Haier HDN305 Dehumidifier
We just got this dehumidifier in a garage sell, and it runs, but we see no water in the basin. We have run it for over an hour now, and we were wonder if it's working properly. The fans is working, and...
There are many reasons why a dehumidifier will not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier
heatman101
Sep 26, 2010 | Haier HDN305 Dehumidifier
Haier HDN305 dehumidifier does not pull moisture from air and does not collect water in bucket
heatman101
Jul 26, 2010 | Haier HDN305 Dehumidifier
Will not come on
heatman101
Jun 30, 2010 | Haier HDN305 Dehumidifier
Fan running
There are many reasons for a dehumidifier2_bing.gif to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
May 12, 2010 | Haier HDN305 Dehumidifier
Haier hdn305 dehumidifier does not turn on
Had the same problem with two HDN455's and took them to a local electronics repair shop. They replaced a Zener ZD2 diode for a total cost of $53 and now is working fine.
Jun 03, 2009 | Haier HDN455 Dehumidifier
Apr 21, 2009 | Haier HDN305 Dehumidifier
agaver
Rating: 0%, 0 votes
Jun 27, 2008 | Haier HDN655E Dehumidifier
Dehumidifiers Logo
462 people viewed this question
Top Haier Dehumidifiers Experts
Steve
Shawn DuRee
Michael Youngman
Michael Youngman
Are you a Haier Dehumidifier Expert? Answer questions, earn points and help others
