Question about ASUS P5QL-E Motherboard, LGA775, Intel P43 + ICH10R, Dual DDR2, PCIe x16, SATAII, RAID, eSATA, Gigab
I am new to building pc's and I've just bought a asus p5ql motherboard, 4gb ram, intel processor and a hd. I have it all together. Green light on board, fans spin, etc. I get the Asus start up screen and press the delete key to get to the Bios Utility... I really don't know what I should no next. I have Windows XP disc, but need "next steps"
  • 53 Answers
REVISED:
Just follow these simple steps:
1. Make sure you have all the discs included in your package.
2. After you power-up, strike del key to go to bios/system.
3. In boot selection, select DVD/CD ROM to boot first, HDD second and other if you wish..
4.Save your settings.
5. Insert your CD/DVD installer to the drive.. during boot-up
6.Click enter to boot to CD
7. Follow the instruction...
8.after installing your OS install your motherboard driver
9.Display driver
and there you go..
Posted on Jun 01, 2009
    Problem Solver:
  • 8 Answers
4. Press ctrl+alt+delete to restart.
5. After pressing the tree (3), insert your CD/DVD installer to the drive..
6. Follow the instruction...
Good luck and have a nice day!
Posted on Feb 16, 2009
2 Suggested Answers
  • 2692 Answers
SOURCE: Bios Utility Setup
Tell it(The BIOS set up screen) to load default settings. Start up CD driver first. Then  Save and exit. Now install Xp disk and turn computer back on. After windows loads . Run the install disk that came with *********** board.  If I missed something or is doesn't work exactly as I stated , write back and I wil assist you farther.
Need picture layout and specs fore cg5270
http://www.ebay.com/itm/0A01-001L0AS-ASUS-ESSENTIO-CG5270-P5QL-VM-Motherboard-61-MIB8Q3-01-OEM-/221134531038?pt=Laptop_Batteries&hash=item337ca529de
[The above is for Reference, NOT advertising ]
The Asus Essential CG5270 Desktop PC uses the Asus P5QL-VM mobo.
(MOtherBOard)
http://www.asus.com/Motherboards/Intel_Socket_775/P5QLVM_EPU/
Click on the Download tab.
(Overview / Specifications / Download / etc)
Click on the blue Down Arrow, on the right side of the - Select OS box.
Click on ANY Operating System. You are just after the Manual.
At the bottom of the list click on the + sign, to the left of the blue -
Manuals (7)
Scroll the INSIDE blue scroll bar down, until you see -
Version E4576 - P5QL-VM EPU user's manual (English)
Click on the blue - Global
A small window will come up -
Opening E4576_P5QL-VM-EPU_manual.zip
Make SURE there is a Green dot, in the small circle to the left of -
Save File.
If not; left-click once in the small empty circle, to the left of -
Save File.
Now go below in the small window, and click on - OK.
A small download window will come up. Allow the file to download all the way, then DOUBLE-click right on the file name.
Another small window will come up.
Go to the far left, and click on - Extract all files
At the bottom of the next 3 small windows, click on -
Next, Next, and Finish.
In the last small window DOUBLE-click right on the file name.
(E4576_P5QL-VM EPU, next to the red Adobe PDF icon)
There is your motherboard manual in PDF file form.
Motherboard Layout is on Page 1-6
Internal Connectors on Page 1-24
Specs on Page 1-13 for Ram Memory, and Page 1-1 for the motherboard.
A) CPU:
Supports Intel;
Core2 Duo, Core2 Quad, and Core2 Extreme processors;
with,
either an 800MegaHertz Front Side Bus, 1066MHz FSB, or 1333MHz FSB.
ALL use the Socket T processor socket. (LGA 775 = Same/same)
ALL based on -> Up To the 45nm architecture.
(Means will support Intel Core2 processors that are based on the 65nm architecture, OR 45nm architecture)
http://en.wikipedia.org/wiki/List_of_intel_core_2_microprocessors
The motherboard chipset is an Intel G43 -> Northbridge chip; and an Intel ICH7 -> Southbridge chip.
(Part number on Southbridge chip is Intel 82801GB)
THIS, is according to the following website,
http://www.meetgadget.com/gadget/2815/ASUS+Essentio+CG5270
I don't think so.
The Intel G43 - Northbridge chip, is usually matched up with the Intel ICH10, or ICH10R - Southbridge chip,
http://en.wikipedia.org/wiki/List_of_intel_chipsets#Core_2_chipsets
Scroll down to G43 in the left column.
(Past G35 and P45)
[Part number of ICH10 and ICH10R, is Intel 82801JB, and Intel 82801JR; respectively,
http://en.wikipedia.org/wiki/List_of_intel_chipsets#Southbridge_9xx_and_3.2F4_Series_chipsets ]
http://en.wikipedia.org/wiki/File:Motherboard_diagram.svg
http://en.wikipedia.org/wiki/Northbridge_%28computing%29
However, suggest you use the free tiny program CPU-Z, from CPUID.com, and find out what motherboard chipset is used,
http://www.cpuid.com/softwares/cpu-z.html
[ When CPU-Z is opened it automatically opens to the CPU tab.
(Processor)
Clicking on the Mainboard tab gives you information on the Motherboard.
If you need help in downloading, installing, or using CPU-Z, post back in a Comment ]
B) Ram Memory:
DDR2 Sdram.
240 gold plated contact pins. 120 on each side.
One Locating Notch.
Reputed to use 800MegaHertz up to 1333MHz.
(800MHz, 1066Mhz, and 1333Mhz)
However it MATTERS on what Processor you are using.
Ram Memory typically operates at half of the Frequency Rate ('Speed'), of the Processor's Front Side Bus. (FSB)
Since the Intel G43 came out in 2008, it stands to reason that the PCI Express technology is PCI Express 2.0
http://en.wikipedia.org/wiki/PCI_Express#PCI_Express_2.0
For additional questions please post in a Comment.
Regards,
joecoolvette
Dec 31, 2012 | ASUS Computers & Internet
I have motherboard i845G with intel chipset i845GL , processor is Intel celeron@1800 MHZ. Ram is DDR SD256 MB Ram. Can I upgrade my RAM to DDR 2 1GB RAM.
No each type of ram is different, it wouldn't even fit in the slots, nevermind use it. To upgrade to a different type of ram you'll need to get a new motherboard. Unfortunately there aren't many motherboards that'll take your processor any more, unless maybe if you try to get a second hand one.
Here's a link to one, there may be a few more available elsewhere though
http://www.ebuyer.com/product/179185
If I were you I'd think about building/buying one with a newer processor. If you decided to build one yourself, then you could get a new motherboard, ddr2 ram and a new cpu for about £150 and use the other components from your present system ie. case, dvd drives, hard drives, although you may have to get a new power supply if your current one can't supply enough power, that would add another £50 for a decent reliable one, go for a decent make like antec or ocz
Obviously I'm in England so it may be cheaper or more expensive depending on where you live. The links below are for an example of what you could get if you decided to build a new one.
http://www.ebuyer.com/product/245670 - Antec 400w psu £47.43 may not be needed though
http://www.ebuyer.com/product/200938 - E5500 2.8Ghz dual core processor £49.40
http://www.ebuyer.com/product/168935 -Asus P5KPL-AM EPU motherboard £31.98
http://www.ebuyer.com/product/166785 - Crucial 4gb ddr2 800mhz ram £58.75
Jan 21, 2011 | Intel CELERON 2.66Ghz CPU AND MOTHER BOARD...
Hi i my computer suddenly started to shutdown and turn on again after a fev seconds.some times it goes in to windows but soon after crashes.it has wrked for over a year and this was a home built...
Try these....
Overheating problem in your PROCESSOR!
Check the temp in your BiOS and the setting of your processor!
Check also the power supply and upgrade it to hifgher wattage!
Clean your processor HEAT SiNK, dust and dirt might have acumulated!
Check the HEAT sink position, if its flatly fitted on top of procie, and scrape the old silicon paste between ur proci and heat sink and put a NEW ONE!
Encountered this kind of prob.. the prob is in the PSU unit(Power Supply Unit)!
These might help you!
Nov 07, 2010 | ASUS P5QL PRO Motherboard
ASUS P5QL PRO memory problem
This problem occurs because of confliction between RAM memory frequency.
For that you must have 2 RAM with same memory frequency and same company chip .
Then it works fine with 2 RAM.
Let me know if you need further assistance.
Thanks.
Nov 03, 2009 | ASUS P5QL PRO Motherboard
Problem with Shutdown
try microsoft/windows update, its on the start menu
reply if you still need help have a good day please rate bama46
Aug 22, 2009 | ASUS P5QL PRO Motherboard
Bios Utility Setup
Feb 16, 2009 | ASUS P5QL-E Motherboard, LGA775, Intel P43...
Intel DG31PR Motherboard not booting
You could try reseting the Bios settings using the jumper of the motherboard after installing the new Rams. Anyways ,its working, so don't do that now :P .
"If some thing is working, don't try to fix it" :) .
Jan 28, 2009 | Intel DG31PR Motherboard
Asus motherboard M2N-E will not power up
It could be a memory card too. I would start by pulling the memory cards and see what happens.
Is there a connection on the motherboard for your hard drive?
Jun 12, 2008 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
Computer Build Problem
Try taking out the mobo and ps out of its casing, lay it on a table, hook things together and power it up. I had some problems before caused by mounting studs or try insulating all stubs from the mobo. hope this will help.
Apr 09, 2008 | Intel Motherboard
ASUS P5QL-E Motherboard, LGA775, Intel P43 + ICH10R, Dual DDR2, PCIe x16, SATAII, RAID, eSATA, Gigab Logo
332 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
