Question about Olympus Stylus 740 Digital Camera
Dropped camera when kens was out
I dropped the Stylus 740 when the lens was out. Now the lens is pushed in and doesn't come out after it hit the ground. Something definitely is broken inside and I can hear the motor working, but I don't know if it will cost more to fix whatever is broken than what the camera is worth. It was in great shape and almost new before this incident. What do I do?
  • pk0703 May 02, 2009
    I dropped my mju-740 OLYMPUS DIGITAL CAMERA when the lens was out. The lens is stuck midway.Neither it comes out nor goes in.Other features of the camera is ok . Can u tell me if it can be repaired and where?I stay in MUMBAI.
  • 744 Answers
Hi...The transmission system that moves the lens in and out has a problem with it's gears. There is most likely a gear or an actuator that has fallen out of alignment and is getting stuck at a certain point as the lens comes in/out.There is some disturbacnce of the lens arrangement that is preventing the lens from coming in/out.Any of these symptoms above could trigger the camera to shut itself off to protect itself from further damage.
thank u rate me!!!
Posted on Feb 16, 2009
Xb31 projector makes loud click noise
Could be anything, you will have to dismantle it and remove the bit of broken plastic/clip/screw ???
Dec 11, 2013 | Computers & Internet
Nikon D40 green light flashing even when off
Sorry to hear this. Dropping something on concrete creates a high G force. Can you make sure the battery is fully charged before you put it in. If you have a good battery and all it does is blink something must have been broken. I think a D40 is a rather old camera too. Sorry I do not think I can help you. In most times a LED green blinking means it is charging. When carrying a camera you should wrap the strap around your wrist. If you do it correctly if you drop your camera it will not hit the ground. It is best to keep it from dropping on the ground.
Feb 06, 2018 | Nikon D40 Digital Camera with G-II 18-55mm...
HAVE olympus 1010 stylus and the lens won't pop out. when I push the power button, it makes a sort of dragging chain sound and then 4 sort of "chimes". Looking at it facing front, the lens...
The internal plastic gears which govern the lens opening and closing are either damaged or out of alignment - this happens when a camera is dropped or has any other form of physical interaction for which it is not designed.
Jun 26, 2017 | Olympus Stylus 1010 Digital Camera
My olympus stylus 710 is in zoom view when turned on then it will just shut off then on then the display is in color blue with displays of 5f 08 and 5e 02. help?
Hello
The problem is that the lens has become stuck in the barrel after dropping it. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
Hope the advise is useful.
Regards
Andrea
Aug 25, 2010 | Olympus Stylus 710 Digital Camera
Olympus stylus 730 zoom error , what is the solution for this kind of problem
Hello
Regards
Andrea
Aug 14, 2010 | Olympus Stylus 730 Digital Camera
I dropped my Nikon D90 (Lens clicking and Battery problem)
No. The warranty does not cover damage caused by dropping it. Maybe you have an insurrance that covers it?
Jun 30, 2010 | Nikon DSLR D90 Digital Camera
Olympus Stylus 1010 lens keeps going in and out
There seems to be some problem with the lens system. If it was dropped or had an impact when the lens was extended, then the possibility is great that damage has affected the lens system. This could be off track, broken parts, or something which is jammed.
You may try this (which could cause more damage) ..as the camera is turned on pull or push on the lens and gently try to turn from side to side as pulling a dn pushing. This may put the lens back on track, if that is the problem.
Other wise, sell it as parts on a site such as Ebay.
Apr 12, 2010 | Olympus Stylus 1010 Digital Camera
I have dropped my friends camera (while it was on). It hit telescope first and got jammed is there anything I can do? It is an olympus stylus 760 7.1 All-Weather. It was purchased on ebay about 6 months...
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Don't want to get your hopes up too high, but here are some things that you can do to try to correct it. They only seem to work for about 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
Nov 15, 2009 | Olympus Stylus 760 Digital Camera
Polaroid i834 lens bent and lens protecter popped off wont turn on for more then two seconds
How did this occur?
If the lens was hit or dropped while the lens was out, that can cause a lot of damage.
First, Look at the lens as it is extended. You may be able to gently push the lens in the opposite direction after starting the camera. This has worked for me on some.
If the lens protector on the end of the lens has popped off, look at the problem. If the shutters have also popped out.... oh boy, that may not be able to be fixed.
You may want to sell this camera on Ebay as a broken or AS IS, PARTS, FOR REPAIR. These lenses are not the easiest to repair, and the small parts inside may be broken.
Jul 19, 2008 | Cameras
Focus
This camera has TTl auto focus so it can't be switched to manual so that idea is quickly stomped on. A silly question, are you half pushing the shoot button down first to activate the auto focus. If you don't and just hit the shoot button you'll definitely get out of focus shots. Have you sat down and read the manual on how to correctly focus. A number of things can crop up which can fool the autofocus into a wrong setting. Have you dropped the camera or has someone else done so? The lens assembly could be damaged. Try pointing the camera at something about three feet away whilst half pushing the shoot button then still holding the button half way point the camera at something a long way off. Can you hear the mechanism trying to focus and does the picture in the LCD change. If it's all quiet and the picture doesn't change then it could be a damaged focus motor or a connection to it is broken. Are you sure the camera isn't switched to Macro. A lot of people get caught with that one. You'll never shoot a focussed picture in macro unless it's less than a foot or so away. BMW
May 31, 2006 | Samsung Digimax A400 Digital Camera
Olympus Stylus 740 Digital Camera Logo
117 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
