Question about ASUS P5QL-E Motherboard, LGA775, Intel P43 + ICH10R, Dual DDR2, PCIe x16, SATAII, RAID, eSATA, Gigab
Bios Utility Setup
I am new to building pc's and I've just bought a asus p5ql motherboard, 4gb ram, intel processor and a hd. I have it all together. Green light on board, fans spin, etc. I get the Asus start up screen and press the delete key to get to the Bios Utility...
I really don't know what I should no next. I have Windows XP disc, but need "next steps"
    President:
  • 2,692 Answers
Tell it(The BIOS set up screen) to load default settings. Start up CD driver first. Then  Save and exit. Now install Xp disk and turn computer back on. After windows loads . Run the install disk that came with *********** board.  If I missed something or is doesn't work exactly as I stated , write back and I wil assist you farther.
Posted on Feb 16, 2009
I am using asus p5kpl-am se motherboard with c2d 2.93, 4gb ddr2 ram, 1gb zotac geforce 9800 series pci card with xp sp3 os. When i check properties from my computer the memory ram is showing only 3gb...
ASUS P5KPL-AM SE supports up to 4GB RAM. I think that 1GB RAM is shared with the PCI Express Graphic Card.
For further details about your CPU and Graphic processor, I suggest that you download two small free utilities
Click here to download CPUz
Click here to download GPUz
These usefull utilities will provide you all the additional details.
Good Luck!
CreativeTECH
Nov 25, 2010 | ASUS P5KPL-AM SE Motherboard
Hi i my computer suddenly started to shutdown and turn on again after a fev seconds.some times it goes in to windows but soon after crashes.it has wrked for over a year and this was a home built...
Try these....
Overheating problem in your PROCESSOR!
Check the temp in your BiOS and the setting of your processor!
Check also the power supply and upgrade it to hifgher wattage!
Clean your processor HEAT SiNK, dust and dirt might have acumulated!
Check the HEAT sink position, if its flatly fitted on top of procie, and scrape the old silicon paste between ur proci and heat sink and put a NEW ONE!
Encountered this kind of prob.. the prob is in the PSU unit(Power Supply Unit)!
These might help you!
Nov 07, 2010 | ASUS P5QL PRO Motherboard
Recently my mother bought a new PC with spec: Intel G31-M7 Intel Dual Core E4500 2.7GHz 2GB RAM 500GB HD The problem is that it keep on restarting randomly. It even restarted itself while in safe mode...
The only thing that would cause a restart in the BIOS is a hardware fault - most likely the power source is too weak. But you should also check the temperature of the processor from the the BIOS besides the voltages.
Jul 09, 2010 | Intel Motherboard
I have had a motherboard failure the MS-7357 (V1.X) Mainboard... needing upgrade thinking of the MSI G41TM-E43 LGA 775 Intel G41 will i have to mess arround with the power switches with the case as this...
Boards don't come with switches. The problem with company made computers is that they get a manufacturer to make a board especially for the case they make. They do this to specifically stop you doing what you are trying to do, upgrade a machine with a proprietary board in THEIR case. You will find trouble at the rear of the machine getting to sockets and plugs.
It is far better to buy a good case, and then you can swap out components with ease. The case that held my Asus boarded P4 with the first SATA drives now has an Asus Quad Core in it with SATA 2.
MSI G41TM E43 LGA 775 Intel G41 HDMI Micro ATX Intel Motherboard Newegg ca
I would contact MSI direct
G41TM E43 MSI Global
Some of this might be useful
G33M - MSI
https://www.msi.com/Motherboard/G33M.html
... the app from the MSI website. Features - Automatically Detect the BIOS/Driver/VGA/Utility Update - Support Microsoft Windows XP/Vista/7 32/64bit. featurePic ...
::UPGRADE:: G33M (MS-7357) - new processor and RAM - MSI Forum
https://forum-en.msi.com/index.php?topic=125215.0 Mar 11, 2009 - 6 posts - ‎2 authors
The motherboard is a G33M (MS-7357) and has a piddly 1.6ghz processor and 1gb of generic RAM. I'm running Windows XP Home.
CPU-Upgrade: MSI G33M (MS-7357) processor support and ...
www.cpu-upgrade.com > MSI Nov 28, 2010 - MSI G33M (MS-7357) motherboard specifications ... FSB 200 MHz, L2 512 KB, TDP 35 Watt, Conroe-L, Rev A1, SSpec SL9XP, 7357v10.zip.
UserBenchmark: MSI G33M (MS-7357) Compatible Builds
www.userbenchmark.com/System/MSI-G33M-MS-7357/450 Compatible Components (from 7 PCs). Popular components in PC builds with the MSI G33M (MS-7357) Motherboard. CPU. Core2 Quad Q6600Intel $190Bench ...
Oct 21, 2017 | MSI G41TM-E43 LGA 775 Intel G41 HDMI Micro...
Problem with Shutdown
try microsoft/windows update, its on the start menu
reply if you still need help have a good day please rate bama46
Aug 22, 2009 | ASUS P5QL PRO Motherboard
I am new to building pc's and I've just bought a asus p5ql motherboard, 4gb ram, intel processor and a hd. I have it all together. Green light on board, fans spin, etc. I get the Asus start up screen and...
Just follow these simple steps:
1. Make sure you have all the discs included in your package.
2. After you power-up, strike del key to go to bios/system.
3. In boot selection, select DVD/CD ROM to boot first, HDD second and other if you wish..
4. Press ctrl+alt+delete to restart.
5. After pressing the tree (3), insert your CD/DVD installer to the drive..
6. Follow the instruction...
Good luck and have a nice day!
Feb 16, 2009 | ASUS P5QL-E Motherboard, LGA775, Intel P43...
Intel DG31PR Motherboard not booting
You could try reseting the Bios settings using the jumper of the motherboard after installing the new Rams. Anyways ,its working, so don't do that now :P .
"If some thing is working, don't try to fix it" :) .
Jan 28, 2009 | Intel DG31PR Motherboard
Bios changes
What are you changing? The motherboard or one of the peripherals such as memory or video card or drive controller may not like the setting or may be incompatible with certain options causing the problem. You may also want to see if there is a bios update to address the issue.
Good luck.
Dec 26, 2008 | ASUS P5QL-E Motherboard, LGA775, Intel P43...
Computer Build Problem
Try taking out the mobo and ps out of its casing, lay it on a table, hook things together and power it up. I had some problems before caused by mounting studs or try insulating all stubs from the mobo. hope this will help.
Apr 09, 2008 | Intel Motherboard
ASUS P5QL-E Motherboard, LGA775, Intel P43 + ICH10R, Dual DDR2, PCIe x16, SATAII, RAID, eSATA, Gigab Logo
152 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
