Question about Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker
Compressor keeps running, and really noisy, seems to be working though, when thermostat set to off the compressor shuts off, so the thermostat should be good right, could it be a low charge, or just a bad compressor going out, fridge is from 1990.
  • 2 more comments
  • jackass2_98 Feb 16, 2009
    Ok 1st off it is a whirlpool and the freezer is running 12 degrees F and the bottom is running 47-48 degrees F with it at a setting of 2 and i dont seem to be having any leaks around the seals.
    I have cleaned up the coils as well as i could now how would i go about troublshooting the defrost system and what temps. should i be running in the freezer part. thanks for the info by the way.
  • Mark Egan May 11, 2010
    Is the condenser area clear of all dust accumulations?Clean that area up real good first.
    2nd, the defrost system may be acting up. It is unlikely you would have 12 degrees in the freezer if the defrost system was initiating, or not finishing cycle, but I would check this first.
    We need to know what the refrigerator and freezer temperatures are in order to determine if there are any issues.
    It is possible it could be a low charge, but we need to look at all other possible causes first.
    Other than the compressor running quite a bit, what other issues are you having with the refrigerator?
    Genius:
  • 1,075 Answers
I agree with you its is one of those problems you mention or both,so lets look at cost first:under new EEU regulations an engeneer has to drain you old gas from your fridge back into a special containor he will charge you for disposing it, then he will charge you for finding your leak/s and repairing it or them and last he will tell you what you already know your compressor is on its way out.I want you weigh up the costs of repair which im sure will be quite substantional to the price of a new or good second hand fridge your call ,.hope this helps you.adrian
Posted on Feb 16, 2009
My domestic rv ac unit reaches the temp setpoint and the compressor shuts off but not the fan, it just keeps on running. Is this normal or should the fan shut off also?
Set fan setting to auto and not high or low setting. Fan will cycle with compressor after setting set to auto or " au" if a digital thermostat.
Mar 21, 2015 | Dometic Rooftop RV Air Conditioner
COMPRESSOR RUNS A LOT
Your model has a mechanical thermostat inside the control panel. I believe you have something else going on like a bad fan, start relay, capacitor. Something is causing the compressor to struggle to keep up and in turn causing the compressor to short cycle. If the thermostat has no control over run time then something like I explained is causing the problem. Here is a parts manual=> ED5VHEXVB04 Contact me if you would like my help, Thanks Sea Breeze
Feb 26, 2013 | Whirlpool Refrigerators
Air conditioner frezing up.clean filter and air conditioner but still ferzing up
If its doing it over night or in several hours, you need to check the thermostat. Turn it all the way to the warmest setting and listen for the compressor to shut off. If the compressor keeps running at the warmest position your thermostat is shorted. If you do hear your compressor shut off , and the thermostat is working, you are probably low on refrigerant.
Apr 14, 2011 | Kenmore Single Room Air Conditioner
The fridge is not cooling!! The motor and fan are both making noises as though they are working and the freezer is working perfectly. I have turned the thermostat up to the maximum but still no cool air.
If there is no cooling on the fridge but the freezer is cooling then the compressor and gas pressure seems good. So to check the set for blocks in the ducts we must shut off the fridge.Keep it off while you clean and check the evaporator for frost. If frost is seen it is a good indication as the compressor is working with sufficient gas within.
Now after about 6 hours plug in the fridge to start. Observe cooling to happen in about one hour and ice to from under three hours.
Earlier make sure that the thermostat was set to normal mode for freezer and fridge.
However if Ice forms then observe the fridge for about 24 hours for cooling to continue and the fridge to cut off . If not the auto defrost timer, or the thermostat must be checked.
The fan making noise can be due to frost build up .If defrost timer works but frost keeps forming check while the compressor shuts if the heaters are working, check continuity of the heaters.
Do not set thermostat up to max but keep it to normal .So try this test from the outside and make your observations so that we come to the solution.
Oct 09, 2010 | Refrigerators
Defrosted it and now when plugged in, not getting cold.
If the compressor is running then it ought to cool. If not shut if down once again wait for few hours and keeping the thermostat in the normal position switch on.
If there is no cooling check if the compressor is working, If the motor speed seems dull check for capacitor being weak, gas pressure being down.
Though it seems strange that a defrosted fridge does not cool and we must suspect the compressor..
Sep 14, 2010 | Danby (DAR604BLS) Refrigerator
High Temp light will not go off even though the freezer seems to be working. Compressor does not stop running
What makes a compressor to run constant is the thermostat. Bang on it to see if it will turn off. turn the setting to 1. if it still wont shut off replace cold control (aka thermostat)
worry about the light later hope this was helpful
Mar 29, 2010 | GE 13.7 cu. ft. / 388 liter Upright...
No motor sound, no cooling fridge
Raise your cooling knob to higher levels - just to troubleshoot raise it to maximum and see if the compressor runs. When your compressor cycles off, so does your evap fan, it should not be spinning ! Keep the thermostat to highest position, this is to rule out thermostat poblems, otherwise you will need to call for service and check your control board and compressor relay/run capacitor, etc. More likely a therm out of calibration or set too low.
Sep 25, 2009 | GE Refrigerators
Kenmore refrigerator seemingly runs all the time. Defrost cycle must be working, because I find no frost on the evaporator. On a setting of 3, the recommended setting, the refrigerator is 40 degrees, the...
Yes you are right the thermostat is not responding to switch off the compressor at the desired temperature setting. It stay "always on" position. Replace the thermostat to rectify this problem....................sodeep
PS: low refrigerant gas could also contribute to aggravate this problem, so have it checked too by the repairman.
Aug 06, 2009 | Refrigerators
Compressor starts and doesn't stop
Relay for the compressor may be stuck ( Contacts welded) both the fan and the compressor should operate at the same time. Have the relay(s) checked and possibly replaced.
Apr 29, 2008 | Dometic Rooftop RV Air Conditioner
Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker Logo
142 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Mike Cairns
Mike Cairns
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
