Question about Panasonic DMR-EZ47V DVD Recorder/VCR
Always says bad disc
I have the panda 250 dvd player and it was working fine we watched a movie one afternoon then later that same day dvd player started to say bad disc. Tried two or three movies all said the same thing. Less than two years old any fix for this?
  • 537 Answers
Try to clean the DVD lens using a lens cleaner.
Posted on Feb 16, 2009
Machine shuts down after 6 seconds of operation
Machine shuts down after 6 seconds... Answer Failed: retry DVD/VCR Combo was working fine then one day machine started shutting down after a few seconds of... (More) (More) DVD/VCR Combo was working fine then one day machine started shutting down after a few seconds of operation. It happens with both, a VCR and a DVD. I can watch 6 secs. of a movie at a time.
May 07, 2010 | Sylvania DVC840G DVD Player/VCR
Player always says the disc is bad. We are unable to watch any movies.
If all discs say this, and you have tried cleaning the laser eye and the TRV Base (where the disc is held in the middle) and still get the same result, most likely your diode has gone out in your laser optical pickup. The optical pickup will most likely need replaced if the part is available.
Apr 30, 2010 | Polaroid DPA-08040B Portable DVD Player
Mine is Sony DVD player..I insert a disc and it says "CAN NOT PLAY THE DISC" and then the player shuts off. The other DVD works fine.
Check the manuel some DVD Players do not support DVD RW or -R +R formats.When Ifirst put my burned movie in I got the message that the player cant play that format Just ignore that and advance the Video to where the movie is starting then all my burned movies played fine. My Pioneer BD 51 FD does support DVD RW +R -R formats so be sure that you can play burned DVD RW +R -R on your Sony player. I was in Wal Mart the other day and they had some DVD players on sale but on the box it said that they do not play DVD RW +R or -R Burned DVD's so be careful if you do buy another one I went to best buy and found mine. Check first it will save a lot of hassle later. This software works great but it may not play in your DVD Sony Player there is a list here of compatible DVD Players
your disc is scratched or a pirated one
thank you for using fixya,rate my answer,
Oct 02, 2009 | Sony Televison & Video
DVD disappeared in DVD Player after viewing movie
Get the dummy cd disc, put a blue tac on it. Insert it. Then after few seconds, eject it. Your dvd disc should stick with it when they came out. It worked for me and hope it will work for you.
Jan 31, 2009 | Kenwood DV-505 Multi-disc DVD Player
Won't play any DVDs
I mostly first always recommend a dvd lens cleaner to clean the lens incase there is something on the lens.
Is the player underwarranty? the lens may have a issue other than dirt and might need to be replaced.
What happened last time it worked fine? try unpluging the dvd player for 5 minutes and try again.
Jan 04, 2009 | Toshiba SD-6980 DVD Player
Blue ray player wont play blue ray ''Kung Fu Panda'' disc.
i fixed this exactly as previous posted solutions, however a couple of points.
a) recordable CDs work if you don't have a DVD burner.
b) I didn't have a CD burner that would do an "image burn", I downloaded a free copy of "Express Burn" and that worked fine. The disk needs to be "finalised" or "fixated", it should do this automatically, or it may be a tick box selection.
c) I got a "No DWLD 09" when I put the disk into the player. I found this was an incompatibility with the CD-R (Maxwell) I was using. I changed to JVC and it worked fine.
Nov 22, 2008 | Sony BDP-S300 Blu-Ray Disc Player
Try to play a disc and the player says ''bad disc''
Have you tried unplugging the DVD player and letting it sit for a couple of minutes? If that doesn't work try holding the power button as you unplug/plug the machine.
Nov 16, 2008 | RCA DRC8052N DVD Recorder
-bad disc reports
The problem with using rental discs is that they are dirty. Buy a dvd player cleaning disc and follow the instructions. These discs help to realign the laser. If this does not help try cleaning the disc with a disc cleaner. Also depending on how new the dvd is there have been a lot of discs manufactured outside of the US that have been bad. It may not be your machine but the discs. I personally went through 6 of the same movie before i gave up and rented something else that worked perfectly fine. Hope this helps you watch.
Sep 11, 2008 | Televison & Video
I just rented a new dvd from Blockbuster and I get a parental screen that comes up. I can't get past it and can't watch the movie. All my other movies work fine. Even the feature dvd that came with the...
You have the rating set on your DVD player to lower than the rating of the movie you are trying to watch.
Somewhere in your setup menu of your DVD player (press the "setup" button on the remote with disc stopped or no disc) you will find a place to set the parental lock. Either turn it off, if that is an option, or set it to the rating of the movie (or higher) to enable viewing.
Feb 14, 2008 | Televison & Video
Dvd player not loading
I openned mine up and found that the lens carrige was not in the fully retracted position. I pushed it all the way back to the back of the slide. Then I removed the two screws on either side of the spindle support so I could get to the lens. I hit the lens with some compressed air, plugged it in and loaded a disk and it worked like a champ. Listening to some Stevie Ray Vaughn right now!!! And going to watch some movies later. ;)
Good luck, I hope this helps someone.
Jul 09, 2007 | Apex Digital AD-1110W DVD Player
Panasonic DMR-EZ47V DVD Recorder/VCR Logo
127 people viewed this question
Top Panasonic Televison & Video Experts
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
