Question about Kenmore 24032\24036 Top Load Washer
90 plus series with a slow fill problem.
I have a kenmore 90 plus top load with very slow water fill on both cold and hot. I took off the hoses and the flow is very strong but slow when hooked to the machine. Water valve I guess.
  • 150 Answers
Or the screen.
Posted on Feb 16, 2009
Kenmore 90 Plus Series washer washer takes forever
is the cold water all the way on?
if so, the first thing to do would be to check the screens in the cold water fill hose and the screen in the cold side of the water valve on the back of the machine. if that is not the problem then replace the water valve.
(turn the water off before taking the hose loose)
Jun 16, 2010 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Kenmore washer 90 series will not fill up with water
You can shut off the water, then remove the hoses to see if the screens on the fill valve are gunked up. This is much easier to do than to replace the valve. I think you'll have sucess on that route :)
Aug 09, 2009 | Kenmore Washing Machines
Slow Cold Water Fill
There is possibly a filter screen in the hoses as well as the water valve.Check the hoses for screens.Occasionally the water valve will deteriorate inside and must be replaced.
I am on a water well and have the same problem. This weekend I installed a inline filter purchased from Lowes. It has stopped the sand and silt problem. You will have to buy one extra water hose to do this yourself.
Jul 16, 2009 | Kenmore 22422 Top Load Washer
Kenmore 90 Series Washer : cold water fills at just a trickle:
your hot water goes through the water heater so contaminates settle in the heater. the cold does not, there is a screen inside the fill valve where the hose hooks to the valve on the machine. if this in not plugged then the fill valve will have to be replaced. because of the build up of contaminates..
Jul 08, 2009 | Kenmore Washing Machines
Kenmore Washer 90 series cold water trickle
Hi, You need to remove the fill hose and see what is plugging the inlet valve screen. This should make a guge difference.
Please let me knwo ig I can assist you further.
Thanks
Vic
May 23, 2009 | Kenmore 24032\24036 Top Load Washer
Washing machine won't heat water
it sounds like the hot water supply hose on the back inlet water valve is not opening up,to check it switch the hoses,cold on hot,and hot on cold,put the washer on fill cold,if hot water comes out you know it's the water valve-mike
Mar 21, 2009 | Kenmore 80754 Top Load Stacked Washer /...
Kenmore 90 series Water pressure turning up and down
it will switch from hot to cold and back and forth trying to regulate the temp. You probrbly have more pressure in your cold water line than your hot or vise versa. This will cause it to seem to pulse. Dave www.washermd.com
Jan 12, 2009 | Kenmore 24032\24036 Top Load Washer
Slow cold water only fill kenmore heavy duty 70 902202
remove fill hoses and inspected for debris or cloggs ,,,,
Dec 30, 2008 | Kenmore 22422 Top Load Washer
Kenmore 90 series Clothes washer
there are filters in the fill hose which could be blocked but usually the fault is low water pressure
Aug 31, 2008 | Kenmore 24032\24036 Top Load Washer
Have model 88675 with slow hot water fill
I once had this problem. The solution was to remove the hot water hose connection to the washer and look at the filter/screen inserted into the end of the hose connection on the washer machine. This screen protects the washer components from foreign particles entering. You may find a badly-clogged screen, so clean it. I have seen a cold water screen clean, while the hot water screen was clogged...something to do with hot water and minerals or iron in water.
Jul 17, 2007 | Kenmore 88732 Top Load Stacked Washer /...
Kenmore 24032\24036 Top Load Washer Logo
226 people viewed this question
Sal De
fordexpert
Robert Rankin
