Question about kawasaki Full Suspension Mountain Bike Men
29hp engine wont start
Kawakasi 29hp fd791 digital fuel injection water cooled engine on scagg turf tiger zero turn mower .Backfires through exhaust and wont start.Has good spark and compression on both cylinders.
rockitman187
  • 2559 Answers
SOURCE: 08 brute force 750 efi drowned out now wont start
First things first,If this happened in the last few days,It may still not be dried out and a wet stator will still spark but won't allow starting,due to sparking at the wrong time.(If you have a leaf blower or air compressor with a blow nozzle,You can use to blow the connectors and engine area to dry it out)
  1. Make sure you get all the water out of the breather box.(and remove the filter and leave it out for now)
  2. make sure you don't have water in the oil.
  3. Remove the bolt on the bottom of the muffler.(about 2'' from the rear of the exhaust)
  4. Pull the plugs and turn the motor over with start button for about 30 seconds.
  5. Blow the plugs to dry around the electrode.
  6. reinstall plugs.
  7. Dry filter and re oil it.
  8. start it up.(if it starts,let it run for about 5 minutes and shut it off)
  9. reinstall the plug in the exhaust and the air filter.
If it still won't start,post back.
Posted on May 15, 2009
voodoomox
  • 1689 Answers
SOURCE: i have a kawasaki kx 250 2 stroke an it was
hi murray,
nice bike you have there.
have you checked on the carb ans see if the jet is right and the mixture is normal, this is usually the case if the carb is not tuned right.
better of reset the card, open it clean it, then set to default even if you are using your mixture of gas and 2t. just set to factory default. once it starts give it a few run, 1-2 hours, then set it to how you want your mixture to be.
hope this helps,
regards,
voodoo
Posted on May 17, 2009
  • 87 Answers
SOURCE: fuel injection problem, bike starts anad idles,
sounds like a couple of things. first because this is a free check. remove the plugs and do a pressure check on the pistons. you may have a valve problem. you will need to rebuild your carb and clean your jets as well.
Posted on Aug 04, 2009
SOURCE: engine turns over but wont start
could that be a possible fuel line crack? or the pet **** is fouled up. i got the same problem found 1/2 in crack in the fuel line. from trying to start it before i found the crack i dryed out the carbs. im a girl and its my first bike just learning
Posted on Oct 15, 2009
cardenderek
  • 783 Answers
SOURCE: I have a 07 kfx
you need to check throttle body and carbeurator. clean carbs. check your oil and check that your battery is holding a charge. has the bike been sitting for awihle? gas might be bad so replace it.
(press add a comment, upper right corner, to reply)
best reguards,
FixYa PremiumSupport
Posted on Apr 07, 2010
I changed my fuel pump & fuel filter but engine sputters & stalls noticed fuel filter is not staying full of fuel. Filter is on the proper way, what could be the issue?
It sounds like you have not primed the fuel system after changing the pump and filter. You need to purge all the air out of the system to avoid the problem you have been getting. Refer to the manual as this will tell you how to do it on this model. If you don't have a manual, then you probably should not have tacked a job like this. I is always best to have manuals when you tackle repairs to equipment so as to avoid this sort of issue. If you continue to crank it and let it splutter, it may eventually purge all the air and start to run properly. Worth a try.
May 25, 2016 | kawasaki Garden
I have a scag turf tiger and when I place the mower under load to cut grass it dies on me
Check the air and fuel filters? They could be clogged, especially if it's running rough
May 10, 2016 | Scag STT61V-791DFI-SS Gas Turf Tiger...
When u turn on key fuel pump does not come on ?
Do you get lights on the dash or running lights ? If not I'd say your fuel pump is bad if you normaly hear it come on .
Mar 12, 2015 | Scag STT61V-791DFI-SS Gas Turf Tiger...
Scag mower
If equipt, check the low oil switch circuit. Might be a failing switch.
Sep 24, 2013 | Scag STT61V-791DFI-SS Gas Turf Tiger...
Scag turf tiger cuts out while cutting starts right back up
I would check for a kill wire coming from your engine that might have rubbed through and is going to ground while running first. please let me know.
Sep 17, 2013 | Scag STT61V-27CH Hydrostatic, Gas Turf...
My scag turf tiger won't start. What should I do?
jump it with your car if that doesn't help jumper the safety switches on at a time check to see if there is spark spray some starting fluid and see if its a fuel problem if fuel see if gas is getting to the carb if gas getting to the carb check the solenoid they stick closed its on the bottom of the carb
Apr 27, 2012 | Garden
Turf Tiger wont stay running after about 40secounds
you need to remove the carb and clean it may need a carb kit sounds like its pluged up in side
Oct 12, 2009 | Garden
kawasaki Full Suspension Mountain Bike Men Logo
74 people viewed this question
Top kawasaki Sport & Outdoor - Others Experts
Wayne McNeil
Phillip Edwin
Level 1 Expert
Are you a kawasaki Sport and Outdoor - Other Expert? Answer questions, earn points and help others
