Question about Whirlpool 24 in. DP840SWP Free-standing Dishwasher
Water spout on the side continually brings in water
I had to turn off the water from under the sink because it wouldn't stop. After the load was drained, it continued to put water in and overflowed everywhere.
  • jmayfraundor Feb 16, 2009
    So how do I fix it?
  • 150 Answers
You have a bad water check valve.
Posted on Feb 16, 2009
  • Len West
    Len West Feb 16, 2009
    Follow the hose it will lead you to the valve,get the part and replace it.
Faucet will not swivel
if your faucet is new....the spout was put together wrong and it needs to be removed and re-attached correctly...(friction washer/ring in wrong position).....if not new....spray some penetrating oil on the connection that is supposed to swivel....make sure the surface is dry and try to avoid overspray. let it sit for 15 min...then spray it again...and again let it sit ....after sitting for a few minutes.....gently try to move the spout side to side...if no change...repeat the first processs...and continue to repeat until it becomes moveable....once moveable....detach the spout.....dry out and remove any foreign matter from the connection side on the faucet...then apply a small amount of faucet grease to the connection threads and the inside barrel....a thin even coat ...excess grease will clog your aerator...don't use too repeat the cleaning and lubricating process on the removed spout connector....reassemble.....remove aerator....turn on the water and flush....replace the aerator....turn water on full blast....check for leaks and for should swivel now ....if not...loosen the connection nut a tad and try again....if still no are missing a friction ring somewhere in the connection and it needs to be replaced before you will be able to swing the spout.....good luck...
Oct 11, 2014 | Price Pfister Marielle Kitchen Faucet with...
What to do if i can't stop the water flowing from the shower spout and there's little water pressure coming from the shower head and a hand held shower?
One rule I live by: more parts, more problems. Sounds to me that the plumbing/valves were not insalled properly. If you hired a profesional plumber, have them fix it. I am a licensed profesional plumber and I offer a 1 year warranty on all my work. If the contractor did the work and does not hold a plumbing license, that person is still responsible and may have to suffer legal consequenses.
Sep 10, 2013 | Latoscana TC3TPW690 Water Harmony...
Hotpoint HSS25GFT 25.0 Cu. Ft. Side-by-Side Refrigerator with GE SmartWater Filtration, LightTouch Problem: Water continually drips from water dispenser spout
Should be the water valve in the back. Over time the seals break down our debre in water will cause to leak. Sometimes new water filters will also cause small issues but shouldn't last long.
Aug 18, 2012 | Hotpoint HSS25GFT 25.0 Cu. Ft....
Hot water wont stop running on hot water side
If the hot water side of the kitchen faucet will not shut off valve under the sink, dirt,rust,and/or scale could have been forced into the faucet along with the possibility of flux and some old rubber washer from the old valve. You will need to take the kitchen sink faucet apart and most likely only need to clean it out, looking for any little black,brown, or white pieces to remove. If cleaning does not work because you cannot get into an area of the cartridge, you will need to replace the carteidge and or rubber seals. Make sure to clean out the aerator on the end of the spout when completed also.
Sep 29, 2011 | Pioneer Plumbing
The swing mixer handle has become very stiff. how do i get it off to clean it/
The first solution is of course correct. However I found it almost impossible to remove the spout assembly. It was very stiff and it was difficult to get any leverage to force it off without damaging the finish to the tap as a whole or damaging the sink.
What I found was that if you poured boiling water over the tap/faucet it eased the stiffness and having done this several times - ie about 5 kettle loads of hot water, I managed to remove the spout. It helps if you reconnect the hose directly to the outlet under the sink (ie not via the faucet). THis allows you to run cold water through the tap whilst pourung boiling water over the outside of the tap. The cold water shrinks the copper/brass components whilst the hot water expands the spout assembly.
Once off, it is possible to clean the inside of the assembly to remove corrosion or calcium deposits to say nothing of old "O" rings.
I also used a kettle descaler between dousing with boiling water in the hope that some of it would seep down within the assembly.
It took me three attempts to do this. I was almost going to spend UK pounds 430 or US dollars 670 and buy a new unit. So do not give up and I hope this helps.
It swings backward and forward now perfectly.
Aug 27, 2010 | Blanco Classic Single Handle Faucet with...
No water pressure at kitchet faucet
alot of times when you shut off valve under sink or in basement when you turn it back on you can get a little debri in faucet i would try cleaning the aireator the little thing on end of spout where the water comes out
Apr 14, 2009 | Moen Plumbing
I have a Mico 7777 Kitchen faucet that was purchased in 2001.It has become difficult to move from side to side. Do we need to replace the cartridge in the faucet and if so how much does it cost and how...
it may not be nesesary to replase the cartridge you could just have some lime or sediment build up in the faucet a bad cartridge would effect your handle not your spout turn the hot and cold water off under the sink,pull the bonnet or cap off and the spout should just lift up take care not to damage o-rings pulling and reinstalling spout check for debris clean and replace spout to insure not damaging o-ring try putting a little vaseline on them will help go on easier will help to lubricate the swivel of the spout replace the cap turn your water back on. if your cartridge is bad your faucet will drip or constantly run
Apr 07, 2009 | Plumbing
Leaking Kitchen Tap
I am assuming that your kitchen tap is leaking through the spout
if it is single lever you will need to remove the crown and spout by removing a small erasure size cap on the housing right under the spout or up near the back of the ever then use a hex wrench to remove the set screw( plug the drain holes do it does not go down the drain)
turn the water off (hot and cold ) under the sink
remove the set screw and lift off the lever
at his point you can take an adjustible wrench(channel lock and tighten the big ring nut that holds the cartridge in place
temorairly put the handle back on and put the handle in the off position turn the water on under the sink and see if it stopped leaking
if it still leaks you have to turn the water back off and remove the lock nut then the cartridge and go to big box store with old cartridge and name of mfg and get a new one and install
If you have seperate hot and cold valves on top of sink deermne which is leaking by turning one off with oher on undr the sink
once you have determined which it is (hot or cold)
take a phillips head screw driver( remove plastic clear cap on top of faucet handle with sharp crewdriver of knife blade) and remove the screw holdin the handle on to the stem(turn counter clock wise
be sure to turn water of under snk on both faucet risers after removing acrylic handle you then take an adjustible wrench and remove the crown nut turn counter clockwise until it comes off over stem
remove stem( looks like size of a pretzel about six inches long with washers on side and one on end
take the stem to local hardware(ace) or big box store and go to lumbing section ask clerk to inspect and recommend replacement washers or replacement stem (if needed)
go back reinstall and tighten crown nut snug( open (turn counter clockwise) tem valve before you snug it down with crown nut
install acrykic or chrome handle with brass phillips screw then ut cap on and turn on water and check for leaks
good luck
Dec 30, 2008 | Home
Loss of pressure in kitchen faucet - Price Pfister
Your problem is a simple one.
  1. Turn off water to faucet.
  2. Place a towel(s) in the base of the sink(s) to prevent any parts from going down drain.
  3. Remove the handle to the faucet. (single handle only)
  4. If not a single handle then remove spout from faucet.
  5. If a single handle remove cap carefully and any loose parts.
  6. Gently turn spout side to side while lifting to remove.
  7. You will see a hole with a very small valve where the water comes out to the spout on the base of the faucet.
  1. Remove this valve (which is a backflow preventer) and replace.
  2. Reassemble and test.
Problem solved.
Dec 04, 2008 | Price Pfister Marielle Kitchen Faucet with...
Whirlpool 24 in. DP840SWP Free-standing Dishwasher Logo
113 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
