Question about HP Compaq Presario v3000z Notebook
I Have a Compaq V3000 Laptops. The display is very dim. HELP!!
The display on my Presario V3000 id very dim. I have had the inverter and screen replaced but its still the same. Is this a known problem?
  • 1 more comment
  • jodamis Feb 16, 2009
    Thanks for your suggestion. It will not display on an external monitor (just tried it now)
    Please disregard my last. There IS a display on an external monitor.
    Thanyou for that!!!!
  • 537 Answers
It miight be the backlight for this unit. It all depends on whether the screen came with the backlight. There is a remote chance that the display circuitry on the motherboard is faulty too. Try to plug a monitor into the VGA port and check to see if it is dim there too.
Posted on Feb 16, 2009
  • Mike McWhinney Feb 16, 2009
    my thinking it would be the CCFL backlight. They are usually less than $10. They can be a little tricky sometimes to replace.
Hallo , I have compaq presario c745ee , and suddenly the screen getting black but every thing is working , sound , fan sound .. every thing , I connected the laptop to a lcd and it is working probably , I...
Hello !
Since an external monitor works, it is the display's backlight or inverter board.
If you were experiencing discoloration in the screen (pinkish lower light hues) before it failed, that would indicate a CCFL backlight issue. If the screen suddenly went dim rather than a slow degradation, the inverter would be indicated.
In either case, a technician in your area should be able to help. Evaluate to see if the repair is cost-effective.
Hope this helps.
May 02, 2011 | HP Compaq Presario C700T
What is a inverter on a presario v3000 moniter?
It's the controller for the light inside the screen.
The backlight in the screen is a high voltage device that needs the inverter to boost the voltage up enough to trigger the light to come on.
Usually if the inverter goes wrong you will only get a really dim display on the screen.
Apr 18, 2010 | HP 417065-001 - HP Compaq Presario V3000...
Compaq presario v3000 display problem
the problem might be from the screen or the screen bulb.
Connect your laptop to an external monitor and see if any display will come up.
If there is a display, then the problem is either from your screen or from the screen board, or screen bulb.
I would advice that you take your laptop to a repairer so that the fault can be rectified.
Good luck.
Mar 15, 2010 | HP Compaq Presario v3000z Notebook
Facing Problem with compac v3000 no display
First see if any monitor will work, plugged in at back? If works, check, just isn't been LCD monitor has been disabled by a key command, then if NOT work, it is probably Video card. OR actual LCD, OR the LCD power supply and/or Inverter? may also be bad connection to MB? Or Broken ribbon in lid, or case. Faulty sleep open/close LCD switch? Try those.
Mar 02, 2010 | Compaq Presario 2580US Notebook
Compaq Presario Laptop half screen issue
no photos of the screen presented.
so all i can do is guess what it looks like,
its so old HP has no info on it. legacy PC, called retired.
i guess 10 years old
2007
so one side is dead, black screen right?
and if you shine flash light on the black side, is there data there or not?????????????????
the v3000 is a CCLF back lamps (edge)
and last 20,000 hours max, (very very short life)
so when one side fails. it goes black
the bulb does or its inverter, supply does.
all do this everyone,
all go dim
then blink
then die, or are random starting.
just like a florecent light in say your garage, same deal. same gas tube.
use the flash light, see its not really BLANK IS IT
only the black lamp quit.
endless post here on topic,
in the year 2010 most of these ended and are now all LED
ending all this pain.
Sep 20, 2017 | HP 435768-001 - Compaq Presario C300...
My compaq presario v3000 lcd display is too vague. You have to use a flash light to see the messages on the screen. How do i resolve this ?
Too dim I think you mean. But vague is okay I guess
http://dictionary.reference.com/browse/vague
Probably the backlight for the LCD has went bad or the high voltage inverter that supplies the voltage to the backlight. You'll be going to a repair shop.
Nov 23, 2009 | HP Compaq Presario v3000z Notebook
I have a Compaq Presario V2000 and am on it right now but the screen is black and I am using it by pluging it in to a diffrent screen
You may have a defective CCFL backlight, it may have the following symptom: Screen flashes on and off or displays reddish pink hue. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickers on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replace the CCFL lamp.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight. It could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out, this is the most likely case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out LCD Parts for service, parts, and DIY info Use this link to their WEB site :-
www.lcdparts.net
Sep 28, 2009 | HP Compaq Presario V2000 Notebook
Compaq Presario R3000 dim screen but not dark
Sounds like the auto-dim in the BIOS is set too low. Fortunately the Compaq R3000 allows you to adjust the brightness right from the keyboard. Hold down the [FN] function key while tapping the [F8] key will brighten the screen, while [FN]-[F7] will dim it. The settings are different for running on AC power and battery, so you must do each individually.
Dec 31, 2008 | Compaq Presario 700 470024-192 Notebook
Driver probs
Here's a link where you can download the drivers for your presario v3000 laptop.
Compaq Presario V3000 CTO
Nov 06, 2008 | Compaq Presario Notebook
Presario 900 display faults
try to increase its brightness from Power options/Control panel..
hope it works u out
Jun 23, 2008 | HP GF939ATABA Notebook
HP Compaq Presario v3000z Notebook Logo
305 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
