Hp media center - hard disc failure iminent
Have a hp media that all of a sudden came up with hard disc failure iminent. when I f2 and try to restart with last know config, just kicks back to failure screen, wont start in safe mode, can get it to go to windows repair, but doesnt do anything. can get it to go to recovery but really dont want to lose all info. tells me to back up hard drive and replace but wont let me. HELP?????
  • 3,051 Answers
Hi there hey try this ok you are going to have to remove the hard drive from the computer that u are using and put in a nother computer make sure that it is recognized as a slave ok than boot from it and back up the hard drive onto a disk ok best regards mike
Posted on Feb 16, 2009
    President:
  • 2,692 Answers
I am sure that noone wants to tel you thins but when you go the Hard disk failer iminent that was so you woudl shut it down and transfer everything onto another disk. Once it crashes, such as your has, you cannot recover the data w/o very expensive equiptment or costly contracting out the HD for data recover.      About the only thing that you can do now is replace the hard drive, download a   recovery disk from HP,if one is available, for your model, If you have not already made one, and reinstall the software from the disk.
Media test failure, no os
Your hard drive is missing from the system. Or, just does not recognize it.
The obvious - Remove any USB devices like drives and any media from disc player. Its trying to load, but can't find bootable hard drive, CD, or USB...
Remove the hard drive and re-seat (reconnect). Check BIOS by pressing an F key during boot. Look on the screen for correct Function key. Might be F2 key. Verify BIOS recognizes the drive. It must be listed! There is no going forward if it's not. Check boot order and make internal hard drive first. Save and restart.
Dec 10, 2012 | Dell Inspiron 1501 Laptop
Disk boot failure
Your hard drive is missing from the system. Or, just does not recognize it. The obvious - Remove any USB devices like drives and any media from disc player. Its trying to load, but can't find bootable hard drive, CD, or USB... Remove the hard drive and re-seat (reconnect). Check BIOS by pressing an F key during boot. Look on the screen for correct Function key. Might be F2 key. Verify BIOS recognizes the drive. It must be listed! There is no going forward if it's not. Check boot order and make internal hard drive first. Save and restart.
Dec 04, 2012 | Foxconn G31MV-K Motherboard
Diskette drive 0 seek failure
Your hard drive is missing from the system. Or, just does not recognize it. The obvious - Remove any USB devices like drives and any media from disc player. Its trying to load, but can't find bootable hard drive, CD, or USB... Remove the hard drive and reseat (reconnect). Check BIOS by pressing an F key during boot. Look on the screen for correct Function key. Might be F2 key. Verify BIOS recognizes the drive. It must be listed! There is no going forward if it's not. Check boot order and make internal hard drive first. Save and restart.
Nov 25, 2012 | Dell Dimension 3000 PC Desktop
No bootable CD in ATAPI CD-ROM Intel UNDI, PXE-2.0 (BUILT 082) copyrighr (c) 1997-2000 Intel coperation For realtek RTL8139(x)/8130/810x PCI Fast Ethernet Controller v.2 13 (0203326) PXE-EGI: media test...
You hard drive is missing from the system. Or, just does not recognize it. The obvious - Remove any USB devices like drives and any media from disc player. Its trying to load, but can't find bootable hard drive, CD, or USB... Remove the hard drive and reseat (reconnect). Check BIOS by pressing an F key during boot. Look on the screen for correct Function key. Might be F2 key. Verify BIOS recognizes the drive. It must be listed! There is no going forward if it's not. Check boot order and make internal hard drive first. Save and restart.
Nov 19, 2012 | Computers & Internet
Harddisk failure iminnent in hp pavillion ms 200 how to fix
You need to open the case (make sure power and everything is unplugged), which if slightly harder on a All-in-one PC. But when you do. you'll see a hard drive (google images) you need to unplug it from its cable and replace it with a new one. And depending on the problem, you could try get it fixed, take it to a repair shop, if not, transfer all your data onto the new hard drive by mirroring it. Then place the new hard disk in place of the old one.
Nov 03, 2012 | HP Pavilion Computers & Internet
My HP pc keeps throwing the error 1005 at 31%, I did just install a cpu (used) so I am reformating with discs. Any good ideas?
Error 1005 when using HP recovery DVDs
Before using the Recovery Disc, make sure the HDD is good. The Hard Disc Driver Test can performed either through [F2] Screen : Start up Diagnostics or through [F10] : Diagnostics . The [F2] / [F10] should be held while turning on the computer to get to the respective windows. In most cases, the reason for this error: 1005 is the Hard Driver failure.
You could also try to remove a memory module as sometimes Vista does not like a large amount of memory installed when using recovery CD/DVD's.
Regards.
Jan 16, 2011 | Compaq Computers & Internet
Wont boot, not even from CD, won't open setup or boot options
At first you insert your system disc on your cd/dvd rom driver and restart your computer. Now press F2 or DEL until you get your BIOS option. Now go to advance option then boot option in that. Now change your first boot option to CD/DVD ROM DRIVE and save that change by pressing F10. Now restart your computer and continue your installation. Thank you.
Jun 10, 2010 | HP Media Center m7250n (ED842AA) PC...
No hard driver found, the computer SMART DRIVE software informed me of an iminent hard drive failure, I tried the restore discs, no hard drive is found, can a new hard drive be installed with using the...
If your hard drive is dead, (no hard drive found), you're going to have to have a new one (hardware) installed before you can re-install the OS and drivers (software). I doubt that you'll be able to retrieve data from the dead hard drive short of herioc (and expensive) measures.
Sorry - hope you were backing-up your data frequently.
If I can be of further assistance, or if you have questions about any of my response(s), please let me know before rating me.
If this solves the issue, please rate it accordingly. My goal is to earn a "Very Helpful" rating from everyone I help.
Thanks for using Fixya.com,
Jon
Dec 29, 2009 | HP Pavilion Ze4805us Notebook
Turn on, after intital screen with setup options the following appears: "SMART Failure Predicted on Hard Disk 4: SAMSUNG HM121HI - (S1) WARNING: Immediately back-up our date ....... Afailure may be...
Have you installed or attached any Software /Device since then.
Please unlug any device attached and then try. Also try tapping F8 key during bootup.
Check BIOS with F2, DEL or ESC key during Bootup.
Best of Luck & Regards Puneet
Oct 05, 2008 | HP Computers & Internet
Open Questions:
Computers & Internet Logo
286 people viewed this question
David Payne
David Payne
