Question about JVC XV-FA95 Multi-disc DVD Player
Quit playing D VDs
My JVC FA95 7 disc player worked great for years. I had only played DVDs in it, never used it for music. Wanting some music I played some cds in it. When I next went to play a DVD it would not read until after several attempts and turning the power on and off. It happenened again- no problem until I played a cd. Third time I had to unplug the unit, give it a light shake, plugged it in and it worked. this caveman technique worked 3 times and now, nothing. Any solutions/reprimands? I cannot find anything in the troubleshooting guide.
    Problem Solver:
  • 14 Answers
It sounds like bad connection dry joint , needs service clean if you are here in brisbane
i could fix ?
if you can service yourself ok, but if not you can
call 0403960527 jeff.....
Posted on Feb 16, 2009
My JVC HR-XVC27U plays some DVDs but not others. They have the correct codes, but it seems to not play the newer DVDs like Toy Story 3
see the causes and remedies and fix it: God bless you
  1. No disc. - Load a disc into the tray.
  2. Disc has been loaded upside down. Place the disc with the label side up.
  3. Disc region code does not match region code of the player.
  4. Disc type is not the correct type to play.
  5. Disc is damaged or dirty. Clean the disc or try another.
  6. Moisture may be condensed inside the unit. Remove the disc and the leave the power on for one or two hours.
Jul 20, 2012 | JVC HR-XVC27U DVD Player/VCR
Suddenly my recorder won't play my DVDs - both those I burned on the computer and the commercial ones. Have done the unplug, etc.exercise - still won't. No changes made in setup and no r eason for it to...
Try a music CD. Also, open up the unit and clean the lens using a cotton swab and alcohol. If the CDs play but DVDs do not even after the clening, the optics are failing and need to be replaced.
Dan
Aug 20, 2008 | Panasonic Televison & Video
I used my Pioneer DVD-RAM DVR-112CH for a few years; and I was able to play all my discs without any problems (all are legit). I mainly use AnyDVD to play any of my DVDs. But I had noticed recently that...
Hi, You can try testing the discs on a different player. The problem may be with a scratched disc or damaged disc. The player seems to be fine if it works with other discs. In any case, I have provided a link to the player's manual: http://tv.manualsonline.com/manuals/mfg/jvc/jvc_xv_n320b_xvn320b.html
Regards, Icom1
Apr 05, 2011 | JVC XV-N320 DVD Player
I recently bought some dvds from the UK. JVC XV-S65 dvd player will not play them. It reads 'region error' everytime I try to play the discs. HELP!
The dvds discs u bought from the UK is play on only the DVD player that play PAL signal format. Where u live Canada,US or Mexico?DVD players in these countries.It play only NTSC signal format.U can't change DVD players regions format,only can a DVD players that have regions free to play all DVDs discs of the world.
Feb 02, 2011 | Televison & Video
New DVD will play on computer not JVC DVD player
Did you check the Instruction book for compatible disc list?
Jan 16, 2010 | JVC DR-MV78B DVD Recorder
I have a few purchased DVDs that will not play. Two have played one time. The message is "No Disk". Thanks. Suzanne
Try getting a lens cleaner and running it. I dont know why but sometimes when the lens is dirty they will get picky about what they will play. You would think that they would just quit! Anyway the lens cleaner should work. Also avoid touching the hold in the middle of the disc. That is where the drive hub that spins the disc goes. No spin no play. Try cleaning the holes on the discs that do not play. Good Luck!!
Jul 06, 2009 | JVC DR-MV77SU/78BU DVD Recorder/VCR
Disc error message when load DVD
Are you loading to play or to record?
Commercial DVDs should play.
DVDs for recording may not be recognized by your drive. First make sure that the disc is blank. You must insert a blank disc of the proper format: DVD-R or RW, DVD+R or RW. Even with the proper format, some brands may not behave the same way as other brands.
Dec 24, 2008 | JVC XV-N320 DVD Player
Tempremental playing dvds
In response to your jvc-a75r DVD player, sometimes the solution might be less complex than it may appear. Had the same problem with my Samsung s321,the machine refused to read DVD's but would play CD's no problem. Simply opened up the cover(usually)4-6 small screws, and found my dog's hair inside of the player covering the laser eye.Electrostatic ionization attracts dust,etc. into the player remarkably well sometimes. Carefully used a cotton swap to remove debri. PLayerworked fine afterwards ...Good luck!
Feb 27, 2007 | JVC TH-A75R System
JVC XV-FA95 Multi-disc DVD Player Logo
237 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
