Question about Microsoft Xbox 360 Console
My xbox 360 has no sound and now no picture when it is turned on
It used to have picture but the color was really light, when it would change to a new screen, right before that the color would come back and then dim again. Now it has nothing. I tried unpluging the power cords and re pluging them but nothing.
Check the brightness on your tv..or u cud have the wrong PAL settings..i sort of had the same problem but it was the settings on the console..
Posted on Feb 16, 2009
Xbox 360 color problem.
i actually have this exact same problem with mine and i cant figure it out. lemme know if you figure it out cuz its pissing me off
May 09, 2009 | Microsoft Xbox 360 Pro System Console
My xbox 360 has no picture but sound only no red lights green ok
First take off my hard drive on the 360. Then plug it to the tv not with HDTV (use the red, yellow and white make sure it is on tv not HDTV) because it will not work for HDTV setting . then plugit into the wall with the 360 laying down not up and down and turned it on. (no picture but sound) with the 360 on take 1 towel fold it long ways and wraped it around 360 from back to front (make sure you cover the fans in the back to make it over heat.) leave your 360 on until it red rings (you can hear the 360 quit down. it takes about 15-30 mins depending on how fast it over heats. once this happens unwrap the 360 and turn it off wait 5 secs and power it back on and there you go you should have picture and sound again. if you still have problem you can now can send it to get repaired since there is a 3 year warrenty for red ringed 360's.
Feb 15, 2009 | Microsoft Xbox 360 Console
Have sound no picture and 2 green rings around power button
They are green?!? usualy when people have problems with  the xbox 360 hardware, the lights turn red. This xbox 360 may have a birth defect... Best thing to do is call 1800-4my-xbox. Talk to a representative about sending your xbox in, ONLY if you have not voided the warranty. If so, you will most likely have to buy a new xbox or new motherboard for it.
Also try changing your video settings to tv instead of hd, or hd if it is plugged into a hd tv. You might have toggled the HD switch on the video/audio chords.
Dec 31, 2008 | Microsoft Xbox 360 Console
New XBOX 360 no picture / sound
ok your lucky, you just need to by a new av cable.. or if that dosnt work you need to get the av caple connection fixed (only about $25)
thanks, Domo
Dec 23, 2008 | Microsoft Xbox 360 Console
Hello my name is steve
Maybe Your A/V cord went bad maybe you should try buying a new one
Dec 13, 2008 | Microsoft Xbox 360 Console
No picture yet i can hear sound green effect before it happend
First thing would be to make sure that you're only using the yellow, red, and white cables, but seeing as how you said you had picture before, I'm guessing that's not the problem. The 360 uses an automatic recognition for the hardware to make sure that it is set to the right input. So, in essence, it won't be that the settings were changed. I would say go pick up a new cable and see if that's the problem, it sounds like it is. If the cable doesn't solve it then I would say it's time to call Microsoft. For the guest with nothing working, call up Microsoft, I really don't know what else the problem could be except for hardware.
Oct 04, 2008 | Microsoft Xbox 360 Console
No picture or sound on the tv
where you put the cables for the sound and picture if you look on the end where you plug it into the xbox 360 you will see a little switch it has HD and TV on it depending on what your tv supports (HD ready TV) (normal TV) switch that switch to what TV you have (e.g. HD TV, switch the switch to HD) if that doesnt work then try checking that you have all the cables in the right ports if you have pluged the HD cables into a normal TV then this is not going to work, check cables and check the switch!
Jun 05, 2008 | Microsoft Xbox 360 Console
Xbox 360 has sound but no picture on HD setting
Is the tv rated for HD? if its not the inputs will be at a wrong voltage and will create that snow like effect.
Is the TV you normally game on HD?
Dec 16, 2007 | Microsoft Xbox 360 Console
No picture or sound
perhaps the xbox is causing the tvs to malfunction. i would get a new one. remember that xbox is giving everyone a 3 year extended warranty on the xbox 360
Jul 31, 2007 | Microsoft Xbox 360 Console
Screen blank
use the towell trick! Wrap the 360 in 2 towells turn on and leave running for 15 minutes. It gets very hot but after the 15 minutes turn off the console and power it back on again and it should work. Dont know if this is a permanent fix but my 360 hasnt broken again so far. Dont ask me how but it works, google it if you like. It also cures the 3 red lights problem.
Jun 22, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
121 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
