Question about GoVideo Go Video DVD/VCR Combo
Get a "fail" error message when trying to record dvd
Get this error message even when using a formatted disk - have used at least 5 different types of disk and still get the same message.
    Problem Solver:
  • 14 Answers
Check disc speed some dvds don't like under 8x
have you got manual , what type disc are you using ? still need help call 0403960527 jeff
Posted on Feb 16, 2009
I have a toshiba dvd recorder D-R160SB and am trying to record from sky plus to a verbatim dvd-rw (as recomended by the manual). When i put the disk in the dvd recorder it immediately starts to format the...
Two in ten discs usually are corrupt out of the box unfortunately. Try a different brand. As for it coming out in 4:3 or 16:9 try the settings on your SKY box. This should work.
Mar 01, 2014 | Televison & Video
FUNAI SV2000 WV10D6 DVD recorder Recording errors on new DVD +RW discs
You can try cleaning the dvd lens with a commercialy available cd/dvd cleaner.
Aug 27, 2008 | Computers & Internet
Trying to write to blank disk first time (Memorex CD-RW). Get message: Record failed: wrong format for re-write Spectroniq SDR-205 DVD Recorder
Some DVD recorders cannot write CD-RW - only DVD-RW (+ and -) as well as DVD-R (+ and -) (this depends on the brand/model). This unit probably does not support CD recording. Try using DVD-RW instead for this machine - see if it records that (do not finalise even if unit prompts you to with an on-screen message prior to ejecting disc).
There are DVD players and recorders which can play CD-RW (mp3, jpegs etc.) but I don't know of any which record this format (a PC CD/DVD-ROM drive can do this though).
Mar 09, 2011 | Televison & Video
I have a Panasonic VDR-M50PP DVD camcorder.About 5 years old. I have about 10 disks that needed to be converted / downloaded on to a PC or a DVD but am having a problem trying to understand how....
It is usual for camcorders to be set up to only transfer videos when mails powered. This it to prevent corruption of either the source files or the copies should there be an interruption in the power supply, such as a battery failing.
Mar 09, 2017 | Panasonic VDR-M70 DVD Camcorder
Format error when i finalise the disk
If a FORMAT ERROR message is displayed, then the inserted disc is not formatted or it is recorded in a different format not useable by the camcorder. If using a DVD-RW or DVD+RW, format the disc prior to use. Otherwise, use a different disc.
Mar 21, 2010 | Sony Handycam DCR-DVD201 DVD Camcorder
Won't format new DVD-RW disks
i did everyting today to fix this. bought new dvds, name brands different, tried finding codes, called the number. trust me. try this. clean it. thats All i did. cleaned it with a dvd cd cleaning disc, the one with two little brushes on it, nothing special, ran it until i heard the beep, popped my dvd in, they all worked. everyone, im still recording. i ran it about four times. now, if you tried to burn a dvd, and got the error, throw that dvd away. because i tried about ten dvds. after i fixed it, THOSE dvds were no longer usable. dont know why. hope this works.
Sep 18, 2009 | GoVideo Go Video VR3840 DVD Recorder/VCR
Toshiba D-R560KU Fails to record. Error message E-21 E-4 E-4 54037380 Time Schedual starts then fails almost immediately. Using Sony DVD+/-RW disks. Tried from new disks from several different stores.
I read your return email solicitation to me to pay you before any indication that you even have a clue as to how to solve my problem nor even a guarentee should you not be able to. My solution is to block any further emails from your bogus service.
Apr 14, 2009 | Televison & Video
Dvd recorder
Hi Nickstart, start checking if the problem is related with the kind of Disk and test on different brands, disk types.
Even if a recorder is supposed to work fine on both +R, -R etc. , often you find out, that due to error correction methor, a device worksd well on one or the other type.
Your DVD supports the following DVDs -R, -RW, -RAM, all -R disks are supported both on 3'' and 5''.
On +R it just writes regular DVD +R, DVD +RW and mini DVD +R are not listed in DVD specs, therefore are not supported on writing.
When your unit records DVD +R it changes the format to DVD-V, The usint does not support DVD+RV.
I assume it works better with -R
I often get troubles with many DVD low price brands, try testing some good ones like Verbatim, TDK, Sony , Philips etc.
See also the manual here, at page 6 and 7 it also says: "Play may be impossible on some DVD-RW (DVD Video Recording format), +RW, CD-R or CD-RW discs due to the condition of the
Hope this had been helpful, test both a good brand DVD-R and a Good brand DVD+R.
If it still has problems when finalizing the CD, then it can be the usual lens problem, Or the DVD you are writing is too big in size and your player has problem on the final phase of DVD writing. If Data nearly takes all the 4.7 Gb allowed, there won't be enough space to finalize the DVD.
Sep 08, 2008 | Panasonic DMR-ES40V DVD-Video Recorder
Dvd do not record
The unit is saying that its an "Un-format disc" problem. Is this the only error code you are getting? Also, what types of DVDs are being used? As in, DVD-R DVD-RW DVD+R DVD-RW and what speeds? 1x 2x 4x 8x 16x?
Apr 04, 2008 | Emerson EWR20V4 DVD Recorder/VCR
GoVideo Go Video DVD/VCR Combo Logo
71 people viewed this question
Top GoVideo Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a GoVideo Televison and Video Expert? Answer questions, earn points and help others
