Question about Cobra 29 WX NW ST 40-Channels Base CB Radio
It's like she's "charging".
My Cobra comes on good at first but then doesn't transmit or receive after about 5min. The weather band still works and all her lights work. If I turn it off and on again, nothing happens. But if she sits for a while with the power supply on, it's like she's "charging". Then she'll give me another 5min. Tried other mics and I'm stumped.Any ideas? Any help would be sweet! Thanks!!!
  • 55 Answers
SOUNDS LIKE A COLD SOLDER JOINT OR A BAD COMPONENT WHEN IT WARMS UP THATS WHEN IT STARTS ..TAKE OFF THE COVER SO THAT YOU CAN SEE THE SOLDER SIDE OF THE BOARD PUT POWER TO THE RADIO AND WHEN IT WARMS UP AND SHUTS DOWN TAKE A LITTLE PIECE OF WOOD OR PLASTIC AND PROBE ALL THE SOLDER CONNECTIONS TO CHECK FOR A COLD SOLDER JOINT IT MAY BE GRAY IN COLOR MAY NOT.. SEE IF IT GOES ON AND OFF.. IF SO RESOLDER THAT SOLDER JOINT.......IF THIS DOES NOT WORK ....PICK UP SOME FREEZE SPRAY AND SPRAY IT ON THE COMPONENT'S ON THE OTHER SIDE OF THE BOARD THIS IS WHAT A SERVICE PLACE WILL DO IF THAT DOES NOT WORK NOW BRING IT TO A SERVICE AND LET THEM SCRATCH THERE HEAD GOOD LUCK
Posted on Feb 21, 2009
Problem no squelch noise or speaker like its muted, but can hear weather ok shows receiving and ant ok
Since the radio cannot transmit on Weather bands, there is no need for the radio to detect if it is transmitting when receiving weather.
In CB mode (on CB channels) the radio will mute when transmitting. So... a guess is that it is muting, or transmitting all the time in CB mode. Check for a mic problem by removing the Mic from the radio ... if it receives CB with no mic connected, then there is an issue with the mic. Otherwise, unless the unit is in PA mode (public address mode) it is likely something internal and beyond the scope of this service.
Sep 08, 2015 | Cobra 29lx Cb Radio W/clock 29 Lx Lcd
Cobre 18 wxstII
Check and be certain you are not on the weather band. if you are you can not transmit and if you are not set to the proper weather station you will hear nothing. Sound like your problem.
Apr 12, 2014 | Cobra Radio Communications
I am able to transmit but not receive
get another that only receives and no transmit.hook them up together .one on top of the other .I have a friend that did this and it actually worked
May 30, 2012 | Cobra 18 WX ST 40-Channels Base CB Radio
I have an old cobra 18 and the weather chanel comes good but won't transmit or receave
Check the swr's. Or there are vertical circuit boards that get loose. We do not charge to look at any cb.
Apr 26, 2011 | Cobra 29 LTD CB Radio
Cobra marine band radio will not transmit more than a quarter mile is it blown?
Before changing out the radio try the radio on a ANTENNA RADIO TESTER or try it on a different antenna. Good luck.
Jan 05, 2011 | Cobra Marine Vhf Radio
Will not receive channels 1-40. Only receives 3 weather band channels
the switch for weather band and channels could be bad may have to put new switch in
Dec 22, 2010 | Cobra 18 WX ST 40-Channels Base CB Radio
I am able to transmit but not able to receive on this model and the squelch is very low, can you help me resolve? I am not receiving any weather transmissions either.
Hi, my name is John. Check your antenna that it is getting a good connection,and that it is grounded. Turn your RF GAIN to MAX. Turn squelch all the way to the left. To hear Weather, Press the Weather button. hope this was very helpful.....rate this solution on the four thumbs-up.....John
Sep 08, 2010 | Cobra 18 WX ST 40-Channels Base CB Radio
Problem with Cobra CB23 transceiver. In weather channel mode, everything works perfectly. But in CB mode, no audio heard on any CB channel just a whining hum (this is indoors with a clean DC power...
Hi, my name is John. Try putting the unit on PA and PA speaker plugged in the back, try another cobra mic on it, if that does not do it, then we will look at the audio chip. Let me know how it goes, I will post the tools needed and procedure here. Hope this was very helpful....Rate this solution on the four thumbs-up....... John
Aug 08, 2010 | Cobra Radio Communications
My cb transmits with a very weak signal and won't recieve anything. The weather band recieves with no problems. I couldn't even pick up a signal on my SWR meter but a friend of mine tested it on his home...
There are a few things that could be wrong. If there is something wrong with the mic, you may not hear anything on the radio. but weather will work.
Other then that, the receive section of the radio could be blown.
Try a new mic, and if it doesn't work, then there is something blown in the radio. It needs a tech.
Sep 25, 2009 | Cobra 18 WX ST 40-Channels Base CB Radio
When i click the mic i get no transmit
If the receive works ok,sounds like a mic
problem,try another mic if you can find a
buddy who has a Cobra that may let you
try it most all Cobra mic will work but not all.
Good Luck
Sep 08, 2009 | Cobra 29 LTD CB Radio
Cobra 29 WX NW ST 40-Channels Base CB Radio Logo
77 people viewed this question
Top Cobra Radio Communications Experts
AnyMHz.com
AnyMHz.com
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
