Question about Maxtor Hard Drive
Jumper settings current backup hd has jumper on top/bottom of #1 pinm abd jumper from top of #2 to top of #3, had been working as backup to c: drive, I want to make it as master. Where can I find a pictiure of settings, there are no markings on the front or back of case? bb pic of jumper set
  • 537 Answers
Check Maxtor's web site, or simply this one:
http://eshop.macsales.com/Tech/manuals/idehdsettings/Maxtor72.pdf
It depends on your jumper style (see diagram in pdf above), but generally it will be the first column you want to jumper to select the drive as master.
Posted on Feb 16, 2009
2 Suggested Answers
  • 3 Answers
SOURCE: jumper settings
Hi
If you look on the top of the hard drive you will see a diagram of the positions you need, master setting is nearest the IDE connector.
Posted on Jul 04, 2008
My personal Macbook pro died, but I did have a Time Machine backup. I have a new iMac that I would like to use as a family computer. I would like to transfer some files to the new computer (and set-up a...
The best approaches is to buy a 2.5" usb sata drive case. Remove the hard drive on the macbook to get back your files and folder on the new imac. Use the drive afterward for time machine
Aug 03, 2013 | Apple iMac Computers & Internet
Jumper settings to connect to mac
If the hdd is a 3 1/2" version you need a power supply to run it. The usb will only power a mini SATA 2 1/2 or smaller as the 3 1/2 needs 12volt supply as well.
Jul 02, 2017 | Western Digital Caviar WD1600BB 160 GB...
How to set hd fujitsu MHZ2250BJ as slave ?
Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to IDE-1 means Pri slave escape then press f10 to save to cmos to restart
you will have to have master with slave set up
you can find the jumper location next to the power on a hard drive and the settings for plastic jumper location is usually printed on the top of a hard drive
IDE-0 means Pri master ?
IDE-1 means Pri slave ?
IDE-2 means Sec master ?
IDE-3 means Sec slave ?
hope this helps
Aug 14, 2011 | Fujitsu MHZ2250BJ - 250 GB, 2.5", 7200 RPM...
New larger hard drive can only be detected as Primary Slave
Floydage, some ribbons are different in the orentation of pin#1. try a differnent cable...but you said that you tried that right.? have you tried to make sure you have the latist BIOS. It could be this paticuler drive have a different bios it self...and yes drive's do have chip's and software in them. If nothing ells just load the OS to that drive anyway and than change the drive letters in windows.
Feb 16, 2010 | Computers & Internet
I am installing a new WD3200AAJB HD in a Dell Dimension 4550. This is the only HD in the system. There are also 2 CD drives and a floppy drive. I used the jumper settings the drive came with which pins...
Reinstall your old hard drive as master and install the new hard drive as slave.
Here is the link to jumper settings from Westrn Digital;
http://wdc.custhelp.com/cgi-bin/wdc.cfg/php/enduser/std_adp.php?p_faqid=1540&p_created=#jumper
If you've got your jumper settings wrong and installed your os on the 127 GB section of the 320 GB Hard drive and you change jumper settings and then you have problems you may need to reinstall the old hard drive as master and the new hard drive as slave. Reformat the new hard drive as 320 GB, and as a bootable drive. You can either do a disk copy from old to new or reinstall your os on the 320 GB drive. Please let me know how this goes. You can get to me @ johnkariotisjr91741@yahoo.com
Oct 25, 2009 | Dell Dimension 4550 PC Desktop
How to set jumpers in an old quantum fireball Lct20 HD. The master mode needs to be "jumpered"
Please look on top of your HD and u will see a table that show u the HD jumper setting (Master, Slave or Cable Select).
Then look again the rear side of the HD and u will see some pin that locate beside the power input of the HD, that is the jumper pin.
Now set the jumper according to your requirement refer to the jumper setting table just now. To set it just unplug the jumper (look like a U shape contactor covered with plastic) and plug it back according to the requirement. Sometime u may lost the jumper contactor, nevermind just use what ever conductor cable to roll between the two pin and make sure the pin is connected that all.
YBC (/\)
Oct 06, 2009 | Quantum Fireball Lct20 (QML20000LD-A) 20...
Cannot get 2 IDE devices to show in bios.
Does the computer have two IDE channels? If so set the Maxtor HDD as master on the primary channel and the DVD drive as master on the secondary channel. Also right click on My Computer, left click on Manage and left click on Disk Management and see if the drives show up there. Also check the boot order in BIOS.
Jan 07, 2009 | Dell OptiPlex GX280 PC Desktop
Your solution
That depends on the type of HD you have...Mine is a Maxtor 3 1/2" ATA 60 gig...On Maxtor's web site you can print the jumper settings for the type and style of the the HD you have...A side note on Maxtor's ATA HD's, the jumper setting for 'Master' on all styles would be the last VERTICAL pin setting on the LEFT.
I'm sure if you have another type (Seagate,etc.) they will have setting's on their web-site.
Don't worry if you get it wrong you won't damage the HD, it just won't work.
Hope this helps!
Jul 31, 2008 | NexxTech Portable Hi-Speed USB 2.0 Kit...
Jumper settings
Hi
Jul 04, 2008 | Maxtor Hard Drive
Computer doesn't see hd
hi, re: sabrent enclosure:
sort of same issues. documentation is feeble. hd powers up. red light is on.
but the new pc doesn't recognize the drive and, obvously doesn't assign a
drive letter to it.
i tried reversing the cable, changing the hard drive, using different usb port,
re-booting. still doesn't see the drive.
1. jumper settings are correct
2 i use vista, not win 2000 or xp
2 harddrive is old, from old computer
vista doesn't have 'my computer'
i can find manage disk management
can't right click becausse the drive isn't there
how do i change the hdd settings from dynamic to basic if i can't see the drive?
answers to your questions":
1. i'm running windows vista home
2 size of drive... it's old and probably fat(32) under 1g
3 i cycled through the settings
j8 jumper settings
slave, master, & single
no settings work
4. yes i heard the drive spin up
5 the led is red, not green
thx again for your efforts
ken bossewitch
kb@bossewitch.net
Dec 03, 2007 | Sabrent (USB-2535) (USB2535) IDE...
Maxtor Hard Drive Logo
136 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
