Question about Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner
Fine black vertical lines on color prints
Epson RX595 all-in -one
  • 684 Answers
In this case what i would request u to do is.......
Take out both the catridges from the Printer.........
Take 2 Paper Towels one should be wet with Luke warm water and the other one should be dry...........
Take the Colour catridge first turn it upside down and u will see a small copper plate on the catridge from where the ink comes out.......
Place the wet paper towel using ur thumb on the Copper plate and press it a lit bit for 10 Seconds......
Now remove it and see whether u see any ink on the paper towel..........
U should see some ink on it now place the dry paper towel on the ink catridge in the same way........
Now do the same procedure again..........
Do the same procedure twice on the Black Catridge.................
Now take the dry paper towel and turn the direction of the cartridge so that u can see a Copper plate on it with small boxes just clean that copper plate with the Dry Paper Towel..........
Know insert both the catridges inside the Printer...
Now Try to Print.............
Will work Fine............
Good Luck
Posted on Feb 16, 2009
How to clean my Epson RX595 Photo All In One Printer printer nozzles. My printer is always needing print head cleaned. I run clean print head but still have issues with yellow and black. I have installed...
Did you use Epson Genuine Cartridges?
ALL…. Epson & Brother Requires Genuine Cartridges. !!!!!!!!
That sounds like your problem.
In Purchasing Epson's CX 5400, CX4600, & CX7400 and more, I found out that Epson does not like Generic Printer Cartridges. I also Purchased a Brother MFC-240C All-In-One InkJet Printer. That also does not like Generic Print Cartridges. Color that should be Yellow, will turn out Green, Blue Brown, etc.
These printers have a CHIP that will detect if it is Generic or Genuine. When they see it’s Generic Cartridges, it will print lines thru the words, stripes across the picture and also do a mix match with the colors. It also will not let you print anything, if only one of the cartridges is empty.
I wanted to print only Black, and would not let me, because I did not have any ink in one of my cyan cartridges. Go figure.
That's what these Companies do., so they can keep selling the ink cartridges. Some Printers, are able to use Generic, and some are refillable. Some you can refill them up yourself and I heard, quite MESSY.
So I learned, thru trial and error, that you must use the ORIGINAL Genuine Cartridges for these PRINTERS. Some people say some models work fine compatible, but not mine.......
I had to replace the printer, but Epson, Lexmark & Brothers are always on sale. My Brother & Epson cost me $50.00 with Rebate. .
IF YOU ARE USING GENERIC CARTRIDGES, MAYBE IT WOULD BE BETTER IF YOU DISABLE THE INK MONITOR.
This is the only advice I can give you.
The next step would be to disassemble the Epson, and clean the Pads/Heads. Click on link below.:
http://www.hm2k.com/posts/parts-inside-your-printer-are-at-the-end-of-their-service-life
I located a page on http://www.fixyourownprinter.com forum, which had plenty of details about similar issues.
If you find this helpful, pls rate me.
Thanks and Good Luck :0)
Apr 02, 2010 | Epson RX595 Photo All-In-One Printer
Epson RX595 prints "wet" on non epson paper
the reaction of the photo chemicals that are on the paper cannot be guaranteed by the printer manufacturer as they have no knowledge of its composition.
3rd party photo paper manufacturers have better compatibility results.
epson for epson, kodak for kodak, hp for hp
Apr 09, 2009 | Epson RX595 Photo All-In-One Printer
Epson RX 595: Yellow streaks in black
In the printer settings, there is a button to switch to Advanced.
So, right click on the printer, select properties, click Advanced, then Printing Defaults, then there is your switch to Advanced button. That will reveal the tick box that says only use black.
Mar 05, 2009 | Epson RX595 Photo All-In-One Printer
When printing B&W pics, prints in color instead (sepia)
The b&W option from the driver are only applicable to documents. If you wanted to print B&W picture, you need to set it on the program that you are printing from.
Feb 02, 2008 | Epson RX595 Photo All-In-One Printer
Poor print quality
im sure your familiar doing the head cleaning from the computer / driver at least 3x consecutively
and still the issue persists, hardware problem
printer needs service / this might come handy : http://www.epson.com/loyalty
Jan 03, 2008 | Epson Stylus 680 InkJet Color Printer
Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner Logo
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
