Question about Arris DSR922
I get get digital signals on dsr 922
I laid new cable from the dish to the house; I changed the lnbs. The battery is not dead. I get analog fine but no digital.
Help Please?
Mike Dubis
  • mdubis Feb 16, 2009
    I mean : cant get not get get
    Problem Solver:
  • 5 Answers
Does the creen say searching for channel? if so you might have to update the maps...go to G! 3 and leave there for about 15 to 20 minutes...make sure you got a dc light....if no you have a tuning issue...play with the skew...
Posted on Mar 25, 2009
Reports no signal from dish. old analog works fine. How do I trace problem?
What inputs are you using, HDMI or A/V because RF has either air or cable and if you are using cable it could be that tuner bad, I would try all inputs you can and eliminate which is working.
Jan 03, 2011 | Digital Lifestyle FA1B32Z 32 in. LCD...
Will a Dish network 1000 satellite dish work with my VIP 211 reciever?
It should as long as it is pointed to the correct orbital locations,
Jun 26, 2010 | DISH Network ViP 211 DTV Receiver
Digital labs 19 inch tv/dvd combo
Wish I knew the answer ... I have the same problem after switching to Dish Network (Satellite). It worked fine with Time Warner Cable. I'm suspecting the signal over Dish is analog (NTSC) which is not supported by this particular TV. I wish I still had the box and receipt!
Feb 01, 2010 | Televison & Video
All we are getting is a pixilated screen and no sound. Dvd's play normally
OK. This should be simple. If you are using a TV with a built in digital tuner like all the HDMI ( High Defintition Media Interface) flatscreens then you probably need to go through your set up menu on your Digital TV and select Initial Setup / Channel Input / Cable / Satellite if coming directly from a dish on 75 Ohm Coax / or Cable if coming directly from the outside 75 Ohm coax with analog signal. ( When I say DIRECTLY, I mean you are not going through any boxes and changing or passing the signal). All satellite direct connects are digital and all satellite converter boxes have multiple out puts these days. There is an HDMI output for high def and low def analogl to digital (A/D) signals coverted within the TV, sometimes there is a DVI or even a USB out put connector...and there is a 75 Ohm coaxial RF cable connection for all the old schoolers who do not have a widescreen digital TV. RF means Radio Frequency and uses Radio Frequency Channels 3 and 4 at the bottom of the RF band around 56 MHz to which any TV with an Analog Tuner can use. In the old days this is what was used for the connection to the TV from the cable boxes because our TVs did not have the capability of decoding analog pay channel signals, hence the little black boxes sold and used ONLY by cable thieves and not any of us here on fixya. For starters, let's make sure you are using your high def, dvi. or some format of digital It sounds like your TV is set up to search and code digital signals but is looking for the wrong carrier frequencies, meaning it is either looking for decoded digital satellite box signals, digital broadcast ( New Digital TV received via an Antenna). Once your TV scans for channels in the cable mode they will be memorized and available on your channel up / down keys and Favorites. (FYI t will scan for both digital and analog channels on antenna mode). Repost if you have troubles or refer to your users manual.
Aug 17, 2009 | Televison & Video
DSR 922- to begin with it wouldn't shut off, no function will work with the remote, unplugged it and replugged it and now there is nothing but the inspirational channel on G3 217. H20
IF the receiver lost its sat settings you had, you best check the internal battery. the lithium battery should be 3.70 volts...if its dead you need to replace it, without interupting the power source...this will also cause you to lose your unit ID number. then you won't be able to subcribe to programming...the 922 can be repaired if the battery dies.
Jul 09, 2009 | Arris DSR922
Dsr 922 no dc light on g1 etcs
you are not on the satellite. need to reporogram or fine tune these satellite into receiver.
Oct 11, 2008 | Arris DSR922
I cannot get in any digital signals today.
Same thing happened to me. After much research I found out that the digital descrambler was dead. I found a good used unit on e-bay, but I found out later that the repair usually averages about $120. I plan on getting the old one repaired for a spare. Contact ATS Electronics at 828-465-9968. They have a set labor rate of $98 plus parts.
Aug 12, 2008 | Arris DSR922
Won't keep digital signal
If you're connected to a digital cable box, I would try using the external component connections and bypass the TV's tuner. If all you have is straight cable coming into the house, it could be the cable signal itself or a defective tuner in the TV assuming all the menu settings are correct in the TV.
Jul 25, 2008 | Toshiba MW20H63 TV
Televison & Video Logo
144 people viewed this question
Top Arris Televison & Video Experts
Are you an Arris Televison and Video Expert? Answer questions, earn points and help others
