Question about GE Profile 26.6 cu. ft. Side-by-Side Refrigerator with Dispenser TFX27PRBWW
Refrigerator will not defrost or cool
I have a GE refrigerator freezer. The freezer works but the refrigerator will not cool.
  • 150 Answers
Either your fan is going out or you have a blockage.Replace the fan after you totally defrost it.
Make sure your fan is working ,its located behind the freezers back wall. If it is working the vent from the freezer down to the refrigerator may be blocked.With out a fan you have no circulation but your freezer may look likes its working becuse it is still frozen,it may last 3 days.Also if you can move everything out unplug it turn it off w/ doors open 12 to 24 hrs this will free up any clogged tubes. Good luck.
Len West
Posted on Feb 16, 2009
Maytag317
  • 1136 Answers
SOURCE: refrigerator not cooling enough and freezer has ice on back wall
HI, You will need to remove the rear inside panel of the freezer and check the defrost heater located on the bottom of the evaporator coils, for continuity. If the heater shows a break in it, replace the heater. If the heater checks out ok, check the bimetal switch that is located on the top of the evaporator coil. It has to be tested while it is cold. Check coninuity and if is shows the switch is open, replace the bi-metal switch.
If the heater and bi-metal check out ok, you will need to replace the mother board.
The heater is the nost common issue with this model.
I hope this helps you and if I can assist you further, please let me know.
Vic
Posted on Jun 28, 2009
aasc
  • 1606 Answers
SOURCE: Side by Side GE Refrigerator wont cool and freezer side frozen
Bad defrost heater in the freezer section .
Posted on Jul 21, 2009
aasc
  • 1606 Answers
SOURCE: 15 yr old GE TBX18SA refrigerator. Not cooling.
Remove the screw , on the left side of the control panel , and pull the panel , from the left side , outward to the right . You should now see , slightly to the right , from the middle , a black screw , a hole with slot , and slightly higher to the right , a hole with a white piece , with a hole in it . Now , the hole with the slot , turn with a screwdriver , until you hear/feel a louder click . Turn this slowly . When you hit the right click , the refrig will shut off . Remove the inside rear freezer panel ( and ice maker if equiped ) , by removing 3 or 4 screws , pop off the grill piece , and may have to twist the ice maker receptical slightly , to remove . If you do not see the heater on ( red ) , below the coils , then the heater is most likely the problem . pt # WR51x464 . Your old one , has a glass tube , but the new one , is calrod . I believe 2 screws hold this heater on .. If the glass heater does come on , then the problem is the defrost timer ( the piece you turned with the screwdriver ) which is removed , by removing that black screw and bending the panel out slightly . Pt # WR9X520 .
Posted on Nov 04, 2009
heatman101
  • 43501 Answers
SOURCE: GE Monogram Freezer wont defrost
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Posted on May 31, 2010
heatman101
  • 43501 Answers
SOURCE: Hello, i own an GE refrigerator Model No:GDS18SBRALSS
heatman101
Posted on Jun 09, 2010
I have a ge frige that the freezer works but frige is warm
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
May 01, 2011 | GE GTL18JBPBS Top Freezer Refrigerator
Freezer working ok, but the refrigerators not working
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
heatman101
Mar 05, 2011 | GE GDS18LBR Bottom Freezer Refrigerator
I have an older side by side GE refridgerator model number TFXC222J. The freezer section is working but the fridge side is not cooling. light works.
heatman101
Jan 16, 2011 | GE Refrigerators
Why is this ge side by side refirgerator not cooling on one side but the freezer part working?
heatman101
Dec 26, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Ge profile refrigerator/freezer, freezer on the bottom. Refrigerator stopped cooling.
heatman101
Nov 06, 2010 | GE Refrigerators
GE Hotpoint Top-Freezer model - freezer works but the rest of the refrigerator is not cold - even when we turn the cold dial up to 9. Model - CTX14C1TGLWH
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
heatman101
Sep 01, 2010 | GE Hotpoint Top-Freezer Refrigerator
GE GDS18LBP bottom Freezer - Refrigerator not cooling
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
heatman101
dl;
Feb 17, 2009 | GE GDS18LBP Bottom Freezer Refrigerator
I THINK YOU HAV A DEFROST PROPLEM .. CHECK AND SEE IF YOU HAVE A LOT OF FROST ON BACK WALL OF FREEZER ./. IF SO YOU HAVE YOU DEFROST HEATER ,. DEFROST BY-METAL OR // TIMER OR MOTHER BOARD ..
Feb 04, 2009 | GE GDS18LBP Bottom Freezer Refrigerator
Refrigerators Logo
67 people viewed this question
Top Refrigerators Experts
Gere knutson
KJ4QOB
Stan Ford
