Question about Mitsubishi VS-50603 50" Rear Projection Television
Mitsubishi vs-50603 does'nt get regular antenna chanels.
I don't have cable TV.I have rabbit ear antenna,do i need a better one?All i see is static. What do i do?
    Problem Solver:
  • 3 Answers
You might also be having a problem with the tuner does the 50603 have digital tuner or old analog??
If it is older tuner then you need a converter box to recieve new digital signals. then if this is your answer an outdoor antenna always performs better and sometimes a power booster will help the inside antenna(rabbit Ears) good luck!
Posted on Aug 09, 2009
    Novelist:
  • 184 Answers
Indoor antennas have very limited capabilities especially in areas with elevation changes and heavy tree cover. Ideally, you should put an outdoor antenna on your roof or the highest elevation you can find with a relatively short distance to the TV. Make sure it has a good UHF section as this is where all digital broadcasts will be sent by the broadcasters as the digital transition occurs. You might try an amplified indoor antenna for better results than what you have now, but its no substitute for an outdoor antenna.
michtech
Posted on Feb 16, 2009
TV picture freezing
digital signals do not fade out and get snowy like signals used to do ... if the signal gets too weak then it just freezes .. you might say its either perfect or frozen .. sometimes it gets blocky .. where some sections of the screen freeze while other sections continue .. what that means if you are using an antenna is .. you need a better antenna or better aim for the one you have .. outside is much better than inside but just rabbit ears are ok for strong signal areas .. you can aim the antenna based on a signal strength meter usually provided in HD receivers in the setup menu .. you can also get an antenna map from "www.antennaweb.org" .. that will show you what direction to point the thing for each channel and how strong each channel should be ... if you are using Cable instead of an antenna then you should have good signal strength but there is a problem called "Crest Factor" .. that becomes an issue when they put too many signals on a given cable .. the cable handles it ok as long as there is no damage (bad ends, water inside, animal chews, corrosion) but the cable box or receiver may be overloaded as thousands of signals drift in and out of phase ... thats a cable company problem that might be getting worse as more channels are added .. the results are that periodically the picture will freeze or pixelate .. you probably have to accept a little of that but more than a little gets really irritating ....off the air reception with an inside antenna (like rabbit ears) you will find that moving around the room can effect the signal for channels in the UHF range (most are) .. aiming the antenna and getting it as high as possible will minimize that problem.. make sure whatever antenna you use is designed for UHF as well as VHF .. the little circle often found between the two "rabbit ears" is actually the UHF part of the antenna .. it can be rotated for UHF channels while the big ears are aimed and adjusted for VHF .. antennaweb.org will tell you which is UHF and VHF ..
Dec 28, 2009 | Televison & Video
Digital Converter connection with old Rabbit Ears TV
First, make sure your connections are right. The rabbit ears need to be disconnected from the TV and reconnected to the converter box. Then the output cable from the converter box connects to the TV. Then try turning the rabbit ears or re-locating them near a window if the wire is long enough. You should be able to get some signal. A newer indoor antenna may help you pull in some of the weaker stations.
Jun 15, 2009 | Insignia Digital-to-Analog Converter for...
Is my polaroid TLX-04244B Digital
I checked out the manual for a similar model tv from polaroid...there's only one input for the coax cable from your antenna, so if the antenna's cable is connected to this input, this couldn't be the problem. What I do have trouble with on my own tv is that my indoor antenna location can make huge differences in recognizing all available digital signals. I could even have the antenna facing a different direction, and get different results. There are a few sites you can google for to find your distance from the broadcast towers, too. This might help to determine if you need a stronger antenna. It's a painfully long procedure to try different angles and positions for your antenna each time you run a channel scan, but this might be the only thing that would prevent you from picking up the digitals. I try the highest spot possible, and the one closest to the outdoors. Good luck, I hope you can pick them up soon! (Any antenna works...the industry tries to pass off "digital/hdtv specific antennas" to make a buck. I've used a cheapy rabbit-ears antenna and was able to bring in digital channels, as long as your tv or converter box is converting the signal.)
Jun 13, 2009 | Polaroid TTM-2401 TV
Mitsubishi VS-50603 Wont Turn on
The power supply will need to be changed. The capacitors inside the power supply are not sending the correct amount of power to tv and will need to be changed.
May 13, 2009 | Mitsubishi VS-50603 50" Rear Projection...
Can't get any channels on Coby tv
Yes, you need an antenna -- rabbit ears or some other type of digital antenna.
Jan 28, 2009 | Coby TVDVD1350 13 in. TV/DVD Combo
We have a new HDLCDVD220 Sansui television. The rabbit ears antennae we were using on our old tv worked ok, but on this one. its awful. There is almost no color and terrible reception. We were told to get...
You mentioned rabbit ears for old tv, how old are the rabbit ears? Time and humidity will make rabbit ears lose connections internally. Also, if your old rabbit ears have the flat cable going to the tv you probably had to add a converter to go to the new tv. The flat cable will lose signal strength were ever the cable touches metal. Also the adapter will cause signal lose. The best bet is to buy an amplified indoor antenna. You also may try a paper clip and about 3to4' of small gauge wire put the paper clip (bend out to fit) into the center of the antenna in on the tv have the wire connected and let it hang or lift it to see how the picture improves. The problem with rabbit ears is that you have to use war time tactics. Crawl on your stomach and adjust to best picture, if you stand and adjust the signal is usually reflected off your body and will be nice until you walk away.
Jan 28, 2009 | Sansui HDLCDVD220 22 in. LCD TV TV/DVD...
Digital TV Signal
Not if you cable TV, DirecTV, Dish network, or FIOS. The converters are not usable with those services.
If you use a regular TV antenna or rabbit ears, then, yes, you will need a DTV converter box. If so, I'd suggest getting one well before next February. Why? 'Cause the pictures are better, and you'll have access to "virtual channels", where broadcasters send more than one program on channels like 4.1, 4.2, etc. Also, if you have poor reception, you may need a better antenna to see the DTV signals. Better to know that before DTV is all that is being broadcast over the airwaves.
Jan 19, 2008 | GE 19GT243 19" TV
'Scratchy' video
Yes tuner problems, may need to replace.
Nov 15, 2006 | Mitsubishi VS-45607 45" Rear Projection...
Televison & Video Logo
205 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
