Question about Haier HTQ21JABWW Top Freezer Refrigerator
Haier Fridge and Freezer
This fridge is 4 - 5 years old. I don't know the model number. The freezer is just an icebox at the top. In other words, this model only has ONE main door and the freezer is a small door inside. The metal floor of the freezer was pierced during defrosting. The hole is smaller than a large safety pin would make, but gas escaped for several minutes. Here's the question: I'd like to continue to use the fridge without the freezer. But I don't know if the coolant is separate for the freezer and the fridge, or if the coolant is one single system for both? I can't see where the coolant enters the freezer. Is it possible that although all the coolant is gone from the freezer that the fridge still has coolant? Is it safe to just plug the machine back in and see? Any concerns in doing so? Ideas? Thanks!
  • 150 Answers
The compressor and Freon are all one sealed unit,never heard of a separated system. by turning it on you will just drain the rest of the freon.
Posted on Feb 16, 2009
Soft fruits, lettuce, cucumber in fridge turn to mush but jars and bottles stay cold
Crisper drawers were made to be a 4 degree lower temp
try turning up 1 number
Jul 01, 2015 | Smeg FAB10RR Retro style Red 114 l...
How to install/replace Icemaker in top bottom fridge
Start by unplugging fridge. Take 1/4 inch nut drive ( sometimes phillips ) remove bottom screw from under ice maker. Next loosen top to screws mostly out. The screws are located in brackets near the ice tray behind the front cover. Ice maker has brakets that the top screws slide into. Lift the icemaker up and out off the screws. Next disconnect the quick connect that is on the back wall of the freezer. Some models are hard wired into the icebox. If this is like yours than disconnect the quick connect from the icemaker itself. Take icemaker out of freezer and connect quick connect into or from new ice maker. Slide the new icemaker onto screws and into place. Screw bottom screw in and than tighten the top two screws. Place ice maker arm down so it can make ice. Give it 24 hours to cycle before it starts producing ice. Most of the time icemaker starts making ice within a couple hours. Plug in fridge.
on Aug 01, 2011 | Refrigerators
The freezer is COLD..freezes solid. Setting at low. The frige part is not cold and is set at high. Seems everything is going up to the freezer. Unit is just over 1 year old. Drinks are cool but not...
where is the freezer on top,side by side or the bottom.all a fridge does is blow cold air from the freezer to the fridge side that's it,if the fridge is warm there's a problem most likely in the freezer,a plugged drain or when you open the freezer door do you hear the fan blowing,if not you have a bad evap fan motor,also check your warranty it still might be covered.send the model number and i can help you,if you see water under the bottom draws or in the fridge section if the freezer is on top you have a blocked drain in the freezer.let me know what you find and i can help you
Feb 20, 2011 | Magic Chef Refrigerators
Mine is an older (20 year old) built-in sub-zero with freezer on the bottom and fridge on the top and only one temperature control (in the fridge portion). The refrigerator is working fine, but the...
You might have a dirty condenser or possibly a freon leak. Check to see if the fans are running and lights are going off when the doors are closed. You didn't mention what the model number is, that might help.
Jan 18, 2011 | Sub-Zero Refrigerators
Freezer side working but fridge side is not?
Since we know the machine is producing cold, that is a plus. The cold is created in the freezer. From here, a fan moves it through vents into the frig. From the frig it goes back into the freezer and makes a big loop. What you have here is a motor to the fan in the freezer gone out. If you want to fix it yourself I'd be happy to tell you how. If you want to know if it's worth fixing, I would say most definitely. I would expect $60-$100 for the fan motor then labor on top of that. If you have a model number I could look it up for you :)
May 28, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
We have a 4 year old GE fridge that is ticking like a clock but louder. the model number is GBS20HBSBWW
If the inside fan does not come one, suggestions are "bad mother board", possibly a free replacement from GE, that otherwise is $300+.
May 27, 2009 | GE GBS20HBSWW 30" 19.5 Cu. Ft....
Freezer does not work
Most model numbers are located in places like the photo shows below. It may be the thermostat itself causing the problem with freezer, yet I don't believe I have seen a refrigerator running without using the freezer to cool the refrigerator section. I guess anythings possible. Let me know, Thanks, Sea Breeze
Apr 21, 2009 | Sub-Zero Bottom Freezer Refrigerator
Leaking water inside fridge
With mine I turned it off for 24 hours until totally defrosted. Checked behind the panel of the freezer and removed one stubborn piece of ice. When I restared the fridge it was all good. I have this problem when we have had a lot of humid weather.
Feb 22, 2009 | Fisher and Paykel Active Smart E522B...
Samsung fridge freezer
hey gordon is this model 4 drawer electronic control with the display in the ice door
Feb 16, 2008 | Refrigerators
Haier HTQ21JABWW Top Freezer Refrigerator Logo
304 people viewed this question
Top Haier Refrigerators Experts
John Tripp
John Tripp
Level 1 Expert
Are you a Haier Refrigerator Expert? Answer questions, earn points and help others
