Question about Hotpoint NVL333EY Electric Dryer
Model nbxr453evoww takes too long to get hot
Hotpoint model has to run at least 45 minutes before it gets hot. Once it gets hot it dries fine. I have checked the lint exhaust and it is clear Any ideas?
  • 150 Answers
Sounds like your heating element is on its way out. If you understand one it is just wires that coil around a shroud,over time it only has to get weak or break in one spot.I suggest replacing it.
Posted on Feb 17, 2009
Dryer gets warm (not properly hot), and takes repeated cycles to dry clothing.
If you have heat but ineffective drying, it will always be an issue with the venting system. The hose could be smashed, there could be a clog anywhere along the run of hose or even at the exit outside. A very long run of hose (more than 12 feet) will often cause problems.
If you were to take the hose off the back of the dryer, run a cycle with a load and have it dry in 45 minutes or less, you will know it's an exhaust issue in the venting system.
Mar 17, 2014 | Whirlpool Dryers
NBXR453EVOWW dryer squeeks
The rear drum bearings could be going out, and believe it not, on some rare occasions the motor itself could make a chirping sound.
Jun 21, 2012 | Hotpoint Dryers
I have a hotpoint dryer model nbxr453evoww. when turn the knob to start it, it wont stay on.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer is not Turning
Dryer Repair - The
heatman101
Dec 16, 2010 | Hotpoint NBXR463EBWW Electric Dryer
LG dryer (model DLE3733W) takes forever to dry the clothes.
check your vent hose for a clog. If dryer dont vent clothes wont dry.
Aug 25, 2009 | LG DLE3733 Electric Dryer
Hotpoint Electric Dryer Model NBXR453EVOWW squealing when turned
Replace the drum support bearing at the rear of the drum.
Jun 11, 2009 | Hotpoint Dryers
Will not turn on.
u should check the on off switch and the door lock
May 26, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint aquarius ctd40
most likely, there is a blockage in your exhaust. take it apart and check every inch from your dryer to the outdoors. i clean mine once a year, it keeps the dryer running efficiently. when lint backs up in there, the heat cannot get out and there is a sensor that will shut off the heating element when it gets to a certain temp, so your clothes will take a long time to dry
Oct 27, 2008 | Hotpoint TDC32 Electric Dryer
Hotpoint bwd129 washer dryer won't dry my clothes.
my Hotpoint dry will not dry my clothes. It will run for hours and the clothes still haven't dry just felt hot.
Oct 05, 2008 | Washing Machines
My hotpoint vtd00 dryer seems to have stopped drying
Have you cleaned the exhaust ducting? The duct that runs from inside to outside. Try that first. Sounds like your exhaust line is blocked. Also with the filter out get a flash light and look down the venting if alot of lint vaccum out. NOTE: Unplug the unit, wheather gas or electric.....and if it is a gas shut off the gas to the dryer before moving just in case something gets loose while moving. Hope this helps.
Nov 11, 2007 | Hotpoint NWXR473EV Dryer
Hotpoint NVL333EY Electric Dryer Logo
115 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
