Question about Compaq Pesario S4120WM (DK216AR#ABA) PC Desktop
Wireless on but still can't get on interenet,
I tried uninstall but nothing, could it be a bad switch or what. I can get on internet if i use ethernet cord from router to laptop.
  • kathrynvn May 11, 2010
    Do you know your IP settings? The wireless router may be sending the wrong IP range via DHCP.
    Scholar:
  • 134 Answers
You probably need to set up your router... try to go on this website : http://www.cas411.com/ShowArticle.aspx?ID=68
and follow the tutorial
Alex
Posted on Feb 16, 2009
My wireless internet works in my hometown, but I go to college 2 hours away and plugged my Ethernet cord in. Everything says its connected, but the internet page will not load. I tried 2 of my friend's...
dont uninstall / reinstall anything on that laptop, will cause more trouble since it was working fine hours ago.
first check your ethernet properties
Aug 30, 2008 | Computers & Internet
Wireless not seeing internet but ethernet is
Try uninstalling the wireless adapter from the control panel. Reboot the system (although with Window 7 that shouldn't be necessary), and let it Windows auto-discover the device again. Disable/enable doesn't for Windows to re-install everything.
Jun 15, 2012 | Acer Extensa 5620 Notebook PC
Im using dell laptop winxp, I alredy connected to wifi access yet cant access internet connections. Pls help. Thank you
You can try other options such as these
1. Try disabling or uninstalling your Firewall / Antivirus 2. Uninstall your Wireless Application and use the wireless zero configuration on your computer 3. Try resetting your router to its factory defaults 4. Try hooking up a ethernet cable to the router see if your getting internet access.
Jul 22, 2011 | Internet Computers & Internet
My Ethernet lite will not come on on my modem, cannot get online thru this wireless router, tried reconnecting cables and power down the modem per set up instructions that came with the netgear router,...
if your modem has an ethernet connection the drivers should be on the disk provided by the internet provider
control panel admistrive tools,computer management,device manager scroll down network adapters +expand Ethernet driver right click update driver,disable,uninstall or select properties general you can trobleshoot or driver to update,rollback or uninstall
hope this helps
Nov 30, 2010 | NetGear WGR614 Wireless Router
Unable to connect my vaio to the internet, help
Lets start from the basic troubleshooting steps.
Things to confirm:
1. Confirm that the Ethernet cable inserted properly to the Ethernet port of the Computer.
2. If it is using Wireless network, confirm that Physical Wireless Switch is turned ON and the LED is glowing.
3. Confirm that the Wireless is turned ON in Smart Wi Utility.
If you confirm all the above, go for the further steps:
Uninstalling and reinstalling the driver could resolve this issue.
1. you can find the Ethernet driver here
2. Also find the Wireless LAN driver here
3. There is an update available for the Wireless Adapter Manager here
Sep 19, 2010 | Sony VAIO PCG-K35 Notebook
I have tired to log on to the internet through my default provider and cannot. I have gotten error messages that read: Sigmatel C-major msinfo32
Sigmatel c-major is your audio driver, not your internet driver. It is possible you have a corrupted driver. I would uninstall the sigmatel driver, then get the dell disc and reinstall it. I would also remove and reload my Ethernet driver, my Wireless driver and my dial up modem driver, just to be sure.
As for the internet provider, You would need to clarify how you connect: wired (ethernet, usb) wireless (wifi, router, cellular) or dial up (aol, netzero, juno on a 56k modem and phone line). Different things can cause internet failures. For example, a cordless phone can disrupt wireless connections. An infected "winsock" can knock out all your network connections, and a bad cord or a bad jack can ruin any wired connection.
Let me know how it goes, Good luck.
Nov 23, 2009 | Dell XPS M1530 Laptop
Wireless internet doesnt work
I'll bet they are offering to sell you one. Anyways, is there a switch on the front of your laptop for wireless? It might have gotten turned off when you reloaded the OS.
Mar 19, 2009 | Sony VAIO VGN-FS980 Notebook
Shows connected to interenet wtih 54 mbps but no IE
one thing you may need to do is go in the Internet Options Folder then click on connections tab on the top.. then click on lan settings at the bottom..the put a check mark in the automaticly detect proxy settings.. make sure no other boxes are checked.. close the browser and re-open it.. and so long as you have a connection to your router it should work.. if not post what version of windows you are using and the wireless settings..everything on the page when you run ipconfig post..
Jan 11, 2009 | Motorola WPCI810GP 802.11g/b (51803000100)...
Compaq Pesario S4120WM (DK216AR#ABA) PC Desktop Logo
26 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
