Question about Toshiba 65H84 65" Rear Projection HDTV
Replacement grill for Toshiba 65H84
I was just wondering if anyone knew where I could find a replacement gril?
    Problem Solver:
  • 14 Answers
Try ebay , did you try toshiba
Posted on Feb 16, 2009
Gril makes aumming noise when lited
The diaphragm inside the regulator is vibrating against the outwear housing. usually this simply means it has some humidity built up inside and nothing unsafe. tap it with the handle of a screwdriver and that usually stops it. Many customers will replace the regulator because the noise sounds dangerous but it is only annoying.
Sep 24, 2014 | Grilling
The picture on my Toshiba 65H84 - 65 Inch Theaterwide HD Projection Television is going dark. Is there a bulb that I can replace? If so, how?
This model 65H84 is a rear projection type with three picture tubes. And if I am not mistaken is around 10 years old. So, if it is at least 10 years old then the picture tubes are getting weak and burned out, therefore not producing a bright enough picture. Typical with rear projection with age on them.
Jun 28, 2011 | Televison & Video
Hi, My friend has a Toshiba 65h84 Rear projection tv that has bad picture. when turned on it shows some snow effect but pink instead of white. when we connect the cable you can see distorted video on the...
Chances are you have a defective hyper module. The symptom with this problem is called piecrusting and appears as a squiggly and distorted picture, usually worse at the top. It may dissipate after 20 to 30 minutes as well. This module has been out of production for a few years but some regional companies will rebuild it for around $125.
Bill W
Mar 14, 2011 | Toshiba 65H84 65" Rear Projection HDTV
3 burner charmglow gas gril
I am replacing burners and I need to know if the burners if they go tightened or loose.
Oct 20, 2009 | Brinkmann Charmglow Stainless Steel LP...
Vertical Lines that occur for the first 5 min the tv is on
sounds like you have sa bad what is called the hypermodule. ideally the best coarse of action would be to replace this. but do to the fact it is a common problem these cuircit boards are hard to come by. Toshibia has told us service centers how to repair these boards which involves replaceing 11 micro caps very very small compnents that usally involve twezzers and magnifier. not for the do it yoursefer. you can easlly damage the board and if that happens that ends the tv right there. at my shope such a repair runs 250 with the parts and labor but it will depend on the shop it is rather labor intensive even to remove the board
Jun 19, 2009 | Toshiba 65H84 65" Rear Projection HDTV
Problem with toshiba 65H84
Good Day, mowattearl;
The most common with this TOS TV is the failure of the convergence IC's, but rebooting, resetting first, unplug TV from wall for 3-5 minutes then plug back into wall. The "conv" IC's are STK's, large black devices mounted to a large heat sink on the verticle.
Good luck, big IRISH.
Jul 24, 2008 | Toshiba 65H84 65" Rear Projection HDTV
Toshiba 65H84 65" Rear Projection HDTV Logo
123 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
