Question about Altec Lansing VS4121 Speaker
Subwoofer producing backround noise
With no music playing through system, sub-woofer box is making a noise which should not be. The noise gets louder when the bass dial is turned all the way down.
Took 1 back to future shop and the new one did the exact thing.
Maybe just cheap electronics.
  • 684 Answers
It hapens when there is a Problem with the Connection y cant u try Reconnecting each and every Wire again Once................
Posted on Feb 16, 2009
My sub woofer making noise like machine gun w out connect toamp
Disconnect the sub-woofer and see if the noise stops, if so the amplifier is OSCILLATING and so produces the noise.This can be related to fault with the pre-amp or audio processing section. Try and heat up the circuit using a hair dryer and if the fault clears then there are faulty electronic capacitors. If leak is seen then the pcb must be washed after the capacitor is replaced which can solve the issue.
Mar 12, 2012 | Infinity BU-120 Subwoofer
No base is coming from my Home sub woofer, It detects signal but very little noise comes from it.
You need to make sure everything is wired properly, make sure the device your playing the music off of has the capacity of 130 watts of sound, and check to make sure your system is set to play that woofer.
Jun 06, 2011 | MTX SW1212 Subwoofer
When my KEF home theatre subwoofer is maxing out on bass, it often makes a loud popping noise. Should I be making some adjustments to reverb, volume, or something else?
Yes you should make adjustments.KEF makes very good products, however if you don't handle this you will have to replace or service it.
1 If the woofer is very close to you, relocate it further away. The reason being is that the lower the frequency the larger the wave form. The lowest waveforms will become louder.
2 Adjust the high frequency cut off to be at 80Hz. This should eliminate boom. Higher Sub frequency tend to muddy the sound.
3 The sub should have a subtle effect in music. So the relationship between it and the speakers it augments the sound of should be seamless.
4 If you are playing Rap or Reggie music and you like to play it loud. Add another sub into the system and locate it NEXT TO the KEF Sub. In this fashion the two subs will reinforce each other's energy. They will "couple" thus multiplying their energy considerably.
Hope this helps,
Best Regards,
Mark
Jan 04, 2011 | Audio Players & Recorders
I have an onkyo reciver and 7.1 speaker system. The powered sub-woofer keeps timing out and when I run the automatic speaker test on the reciever, it does not see the sub-woofer. I checked the reciver...
I assume you mean the subwoofer remains silent during the test. Perhaps the subwoofer is where we should be looking.
If you jack it into one or both of the Tape Out connectors and play some music with substantial low bass, does it make any sound? This would at least prove it is alive.
Dec 13, 2010 | Onkyo TX-SR605 Receiver
If i put the TS-swx310 sub in a bigger box would it get help the sound.......i have a 12'' regular sized box and the speaker is going in a car now???
It is amazing the difference box construction can have on the overall sound of a system. Size is only one factor. Using a larger sealed box may make the sub hit lower, but not necessarily louder. Because the TS-swx310 is a shallow mount woofer, it is designed to run in small enclosure. Putting it in a much larger box could potentially cause damage to the woofer over time. If you want more bass my advice is to use a normal woofer in a box built to spec for it. Generally a ported box will provide more output, and sealed hits tighter. It all depends on the type of music you listen to.
Hope this helps
Please Vote & Rate
Mar 08, 2010 | Pioneer TS-SWX310 Car Subwoofer
What should the subsonic filter be at
The subsonic filter is to help your system's overall performance by blocking frequencies that your subwoofer cannot effectively produce. For example, if you have a single 10 inch sub, it's not likely to be able to produce sound much lower than 60-80Hz with any respectable volume. If you have the subsonic filter on and set to 60Hz, it will prevent a 40Hz tone from being delivered to the sub. If the subsonic filter is turned off, your sub will get everything, and it will try to produce every sound. If it gets a 40Hz tone, it will make the sub work extra hard without any audible noise. It'll just degrade the overall so the answer to "shoud the subsonic filter stay off" would be "it depends on your system" but in most cases, you should keep it on, and set it to the low end of your subwoofer or woofer range. This also applies to filters on mids and highs.
May 15, 2009 | Performance Teknique ICBM-2400 Digital...
Loud noise from subwoofer on standby or while playing music
Hi There, Please advise us what happens when you turn off the sub woofer is the hum still there....??
From YUBEUT.
Nov 27, 2007 | Teac CD-X8 CD Shelf System
"cracking" noise
Your subwoofer is not capable of playing as loud as you want it to. That sound is the woofer reaching its limit. If you have any bass tone setting on your receiver set them to flat. If there are any other bass settings i.e contour, loudness boost etc turn them off. You can also try putting the woofer into a corner. This will increase the output. Closer to you would also be louder. Otherwise you need a sub with more output. Don't let the power rating fool you when you get a new one.
Aug 26, 2007 | Acoustic Research ARS108 Speaker
PROBLEM WITH SONY WOOFER
This must be cable connection problem. There may be loose connection or cable is not working properly so change the cable and enjoy. Thanks
Aug 10, 2007 | Sony DAV-DX255 System
Woofer making horrible noise! HELP!
Think as an expert... Probably from my experience repairing woofers etc... the cone (1) or the spider (2) isn't well glued onto the woofer skeleton(or both???) The woofer cone must be absolutely centered or else you will get those clicks in low frequencies(you also get them in higher frequencies but you can't hear them!) I must say that it is very difficult to repair a woofer by your own. I suggest to return it back where you bought it and take another one (i suppose that you have a guarantee ha?).
Aug 10, 2007 | Alpine SWR-1542D Car Subwoofer
Altec Lansing VS4121 Speaker Logo
628 people viewed this question
Top Altec Lansing Audio Players & Recorders Experts
Brian Sullivan
Brian Sullivan
Carlos L. Burgos
Carlos L. Burgos
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
