Question about Technics Audio Players & Recorders
Receiver says power overload, turn system off
I have a Technics SA-GX 470, sometimes the receiver is turned on and it says power overload right away, at other times it takes time and then says overload, turn power off. We have had this system for years and it started about a year or more.
  • Anonymous Mar 16, 2014
    will not turn on
  • Dale Patterson
    Dale Patterson May 14, 2016
    It turns on for 3 sec andthen shutdown And displays overload
  • 336 Answers
It probably needs soldering of the voltage regulators and/or output IC.
I think that model has an access panel on the bottom (it may need to be cut out then rotated and screwed back on when done).
If it doesn't have the panel the main circuit board needs to be taken out to access them.
The regulators and output IC are mounted on the main heat sink. a little soldering and it should be good as new.
Posted on Feb 17, 2009
When I turn on my technics sa-gx amplifier I can't hear the sound
Have you noticed if the speakers selector switch in the front panel is set to off ? That position for the switch is only suited to listen heaphones. Good Luck.
Flavio/BRAZIL
Jul 28, 2010 | Technics SA-DX750 Receiver
On switching my technics sa-dx750 it says switching off overload
The question is what is causing the overload? The power supply or the output devices on the heat sink?
If you have accidently shorted a speaker wire, then the answer will be output devices, otherwise it could be anything in the power section. You may find a burnt or damged device with either of the causes.
Mar 08, 2010 | Technics SA-DX750 Receiver
Overload on sagx550 technics
Disconnect all speakers at the receiver then turn it back on. If it still goes into "overload" you need to have the unit serviced. If it stays on, post a comment and I can walk you thru troubleshooting your system.
Dec 22, 2009 | Technics SA-DX750 Receiver
My Technics AV Control Receiver SA AX530 is in overload
An amplifier should never be turn on without speakers, it will overload internally.
make sure speakers work and try again.
Dec 04, 2009 | Technics SA-AX530 Receiver
Overload at medium (4-6) volumes. Can you adjust or disable the overload protection on these Technics amps??
try this mate:
http://www.electronicspoint.com/googlesearch.php?cx=002919058480771089906%3A03mranmmdze&cof=FORID%3A10&ie=UTF-8&q=Technics+SA-GX550&sa=Search#862
May 23, 2009 | Technics SA-EX400 Receiver
Overload on Technics SA-AX710 Receiver
u can measure the speakers impedance, if is ok. I think this can be a problem, when is speakers with 4ohm conected.
Dec 21, 2008 | Audio Players & Recorders
I have a Technics SA-AX610 receiver that says overload .
From the manual pg 27....... "The protection circuitry has functioned because the positive and negative speaker connection wires are "shorted," speaker systems with an impedance less than the indicated rated impedance of this unit are used or under severe use, such as loud volume, excessive power and in an excessively hot environment."
Nov 16, 2008 | Technics SA-EX110 Receiver
Technics SA-AX720 AMP
The audio amplifier IC of your device are damaged you need to replace it.
Jul 04, 2008 | Technics SA-AX720 Receiver
Technics SU-G91 OVERLOAD PROBLEM
I had the same problem. As soon as the volume reached about 24db it would go into overload. I was able to fix it by soldering all the connections on the larger power module. The one connected the the heat sink. When I took it apart there where several solder points that had come loose.
Oct 10, 2007 | Technics SA-AX540 Receiver
300 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
