Question about Kenmore Oasis HE 27082 Top Load Washer
F codes flashing
When I start my machine on any cicle it flashes F1 code, I have to press stop and then start several times to get it to work. Also I got an UL message and a HC message. Does any one know what those codes mean and how to fix the problems? I am desperate and very unhappy with the product. HELP PLEASE!!!!!!!!!!!!!!!!
  • 1 more comment
  • asmith30 Feb 16, 2009
    We get code F51 and it stops in the middle of the cycle.  It is only 18 months old.  The machine is terrible.  have read about class actions suits for this washer.  Sears says you need a new control board at 400.00.  That's crazy.  If a product breaks down in 18 months it's obviously faulty.  Is there anything we can do.
  • Anonymous Feb 16, 2009
    I have the same problem!!!! Unfortunatlly, we purchased ours on display for a less expensive cost because of a scratch and we have no manual.
  • Anonymous Feb 18, 2009
    I've had my machine a little over 2 years and it beeps way to much. It just recently a couple days ago, totally quit. It won't even power up as if I've got a electronic board problem. I did not get the extended warranty and now I'm stuck with an expensive washer that won't run. I've read that the electronic boards are very expensive. I'm thinking about buying a basic agitating machine instead of spending hundreds of lollars to fix this one when it's probably going to tear up again anyway. Don't buy one of these washers!!!
    Novelist:
  • 126 Answers
It is the control board that has failed. there is an upgraded version that runs about $150 and can be installed by the homeowner. its not that difficult. and, if you call sears one source, they may pick up $100 in parts and $150 in service call fees if you complain enough.
however, this doesn't explain why a recall has not been issued for this problem and others that will soon crop up as the machine ages (HC code, LF code, constant UL code).
i learned from this experience. i will never buy another kenmore item again.
Posted on Feb 20, 2009
While filling it will flash an F1 code and stop. If I cancel the cycle and press start again it will usually go ahead with that cycle until the nest fill up. What is an F1 code?
This is a pressure sensor issue on the machine control board .The only sure fix is to replace the machine control board which has been updated numerous times.( whirlpool is very aware of the problems) At one time whirlpool was assisting owners who had this concern .
Sep 09, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Kenmore Electric Range model 790 has F9 & F1 code error
Before you go working too hard to get you oven to go into the self clean mode....check out this tip...
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! "
Apr 20, 2010 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Machine started filling with water - then stopped and flashed F
I have the f51 code filled up with water and stopped. They are coming today to fix it. Called whirlpool and they are fixing this at their expense. I have the extended warrenty they said they are fixing codes f1 and f51
Oct 18, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Machine stops several times shows F1 code
this is a main control board failure and needs to be replaced
Sep 16, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Washer is showing a code f1
press PAUSE/CANCEL once to clear code. press start.if code reappears call for service
Mar 23, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
F1 error code on Kenmore Oasis He
Moister can get in between the contacts,is it in a high moister environment? Try using a hair dryer on the panel to dry it out.Also unplug it to reset.
Hope this helped.Let me know by rating me
For more help go to live chat.
lenwest
Jan 31, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore Elite Oasis HE/ Error Code F1
f-1 error code,, replace main contol board ,,pressure swtich is loacted inside board would not fill drain and spin once replaced there will be no more problems, if machine is 2 yrs should be covered under warranty
Nov 24, 2008 | Kenmore Elite HE4 Electric Dryer
Sorry to tell you but you have a faulty control board. It is a bad part from the factory. They know that its bad too! They have completely remanufactured the part. There is lawsuit against whirlpool (whirlpool made the oasis) for the problem. Some people have been able to call and complain to whirlpool and got them to pay for the repair. Complain a lot. Good luck. sorry for the bad news.
Nov 20, 2008 | Washing Machines
repl/ main control board reason for error code F 1 ,,,nothing else
Nov 08, 2008 | Kenmore Elite HE4 Electric Dryer
The machine flashes f1
Hello madelinezak
Welcome
F1
“F##” code
Press PAUSE/CANCEL once to clear code. Press START. If
code appears again, call for service.
Thank you, Huuum
Please remember to leave a rating
Oct 12, 2008 | Whirlpool Washing Machines
Kenmore Oasis HE 27082 Top Load Washer Logo
164 people viewed this question
Sal De
fordexpert
Robert Rankin
