Question about HP Office Equipment & Supplies
Scanjet 3970 lamp burned out
Is there somewhere I can order a replacement?
Phil
    President:
  • 2,692 Answers
Have you tried the HP parts store? I am guessing that the lamp bulb may be even more commn and may be found at a office supply.
http://h20141.www2.hp.com/hpparts/search_Product.asp?mscssid=17679809BE194F1B97551B36426B2776&SearchCriteria=Q3190A&Smethod=1&sRefAsp=Search_Multi_Product
Posted on Feb 16, 2009
Re. HP ScanJet 3970 Flatbed Scanner Horizontal lines.\r\n When I scan, I get light coloured lines approx 2mm apart across the complete scan, which show up primarily on the dark colours. Different...
Hi! I had a same issue with another HP Scanner model. I was not able to repair, so I ask my company to buy a new one. I know that it can be repaired as ething can, but as I undertand this issue occur as the head of the reader is not scrolling in the glass as expected and it can be for differnt reasons or power supply is not work properly.
Have more success,
Sly
Nov 19, 2010 | HP ScanJet 3970 Flatbed USB 2.0 Color...
My hp sacanjet 3970 doesn't work
Most likely cause of the "Scanner could not be initialized" error on the HP Scanjet 3970 is due to using an incorrect power adapter and cord -- the only power module and cord that work for the HP Scanjet 3970 are these part numbers: 8120-6260 for the power cord and L1970-80003 for the power module / AC adapter I hope this info helps you.
May 23, 2010 | HP ScanJet 3970 Flatbed Scanner
I changed my Pc and I don t have an install cd for my hp scanjet 3970.Ca you help me?
Here you are:
http://www.driverstock.com/download-HP-3970-driver/10-7-4669/index.html
Ok be sure to select the coresponding windows and type the security code accordingly.
Good luck
Uttam
Jan 26, 2010 | HP ScanJet 3970 Flatbed Scanner
Hp scanjet 3970 will not scan slides with Vista
HP only have a basic vista driver for this scanner which won't give full functionality.
Sep 19, 2009 | HP ScanJet 3970 Flatbed Scanner
Hp scanjet 3970 on Mac: lamp error
Normally this error means that your lamp will no longer come on to scan anything. The only way to fix this is to replace the bulb. If your bulb is coming on, but you still receive the message, their is an internal error that must be checked by a repair center. You might want to check into the cost of repair as it is often cheaper to replace than repair.
Jul 10, 2009 | HP ScanJet 3970 Flatbed Scanner
Fuse for hp 3970
After you have UnScrewed and Opened Up the Scanner.
On the Circuit Board (Green Board with Electronic Components) just where you Plug in the Power Pin there is a Small Glass Tube Looking Component.
You need to replace that with a 1.2mA Fuse.
Hope this Helps
Apr 03, 2009 | HP scanjet 3970 digital flatbed scanner
I can't find the Serial Number on my HP Scanjet 3970 Flatbed
The 10 character serial number and the product number are located (on my 3970) on a sticker on the inside of the cover.
You can verify that you have the correct numbers if you enter them at
http://h20000.www2.hp.com/bizsupport/TechSupport/WarrantyLookup.jsp?lang=en&cc=us&prodSeriesId=298547&prodTypeId=15179
That will tell you if they are the wrong numbers as well as the warranty status of your scanner.
Jan 24, 2009 | HP scanjet 3970 digital flatbed scanner
HP scanjet 3970
hi frined
take ur adper & show the store he will give u same needed code of power u have to nearest electronic or electrical store there u get a power cable
thmx using fixya
Apr 06, 2008 | HP scanjet 3970 digital flatbed scanner
418 people viewed this question
Seeker5211
Seeker5211
