Question about Tatung Computers & Internet
Monitor LT73 is dead no power when turned on. Mel
  • 296 Answers
If you dont even get a yellow light, red light, let alone a green when its plugged then its eather a faulty outlet or bad power supply.
Posted on Feb 16, 2009
    Sergeant:
  • 326 Answers
Check out the cables at they will be loose not connected properly.also remove the batrtery and reinsert and check out.other wise it can be power failure in the circuit board needs reparing.
  • Tatung Master
  • 19,396 Answers
Check the power cord. The problem is a faulty powe supply.
  • Ginko
    Ginko Feb 16, 2009
    Check first that the power cord is well plugged.
    Test a different outlet, and if you have another power cord test it.
    If it still has no power then the psu board has blown, usually a blown capacitor.
    In that case find a local repair shop to fix it.
How to turn my 1080 hp monitor on connected to my computer
Look for the power button/switch on the monitor
Oct 13, 2017 | HP Computers & Internet
It will not work i switch it on and nothing happens
Remove cable connecting monitor to computer, turn it on. If you see a "NO SIGNAL" note, your monitor is ok and the problem is the graphic card of your computer. If you've recently removed and reconnected the monitor, might be a bent pin of cable input.
If Monitor is dead when you turn it on disconnected, it's defective and you should repair it
Apr 26, 2015 | Computers & Internet
My monitor screen went out and now I can't turn it back on
Unplug your monitor from the power for about 5 minutes. After 5 minutes press the power button, and then plug it in, turn it on.
If it still does not turn on, the monitor is dead and you'll need to replace it.
Apr 11, 2011 | Samsung Computers & Internet
My HP monitor was working fine then randomly one day it went dead, I turned it back on and I could see the screen and what it displayed for about 2 seconds, then the screen dies again. The power button is...
Sounds like your monitor is going dead. If its under warranty that would be the best way to go. Specifically it sounds like the power inverter is dead or there is a busted capacitor.
Mar 12, 2011 | HP Pavilion F1703 17" LCD Monitor
My HP L2335 Monitor wont display anything. I can literally turn it on (the led power light comes on and it turns green if plugged in and I can tell the backlight is on), but nothing will display no...
why not try a dead display on 2 machines 2 PCs
using only 1 data cable at a time why try to confuse it????????
the OSD must work, or the display is bad or the power supply to it is dead.
easy as apple pie.
the monitor has a tiny computer inside it (micro)
on mine, the data lines dead shows NO SIGNAL in the screen
every time you I power up my monitor with data cables pulled off.
best is to read the book for your monitor, and run all the tests it
tells you there,
Mar 13, 2017 | HP L2335 23 inch Monitor
No plug in play... don't think their dead... do I need drives first?
no country stated or if not usa what is your line power?(volts AC)
your PSU is inside monitor not outside, so uses a simple line power cord. (just wires)
12 year old monitors, found, (dead)
page one of your user guide is clear, read it yet?
seems not.,
Auto-ranging, 90 to 265 VAC
1280 x 1024 @ 60 Hz, 75 Hz (never higher) resolution settings.
those are very old monitors.. worth like $10 used.
if the power lamp shows wrong, the monitor is dead.
right button is power to the right of it is a power led that must glow.
the old monitors had CCFL backlamps before year 2010.
those are back lamps, that fail fast. 20k hours, fast. (short)
first is the power switch
2nd is a working PC with at least sync signals on 2 pins
Horz/vertical.
then the OSD screens work of not the monitor IS DEAD.
inside this OLD monitor is sleep time, turn if off with OSD menu's its nothing but trouble.
some have an OSD lock, so hold the menu key for 10 seconds
and it unlocks. button 2 from left is MENU.
see page 4-10
the guide is here. not too good , poor diagnosis sections
http://h10032.www1.hp.com/ctg/Manual/c00276671
specs.
https://support.hp.com/us-en/product/hp-l1940-lcd-flat-panel-monitor/427303/document/c00278650#AbT3
testing
power it on, LED power , glows.
with a PC working, say running any BIOS screen only....
or running, windows, in low resolution mode 1280 x 1024
if wise set the pc up to that first. not second.
then plug in the vga cable so the MOnitor only sees that signal above. (if you do above wrong, monitor shows OUT OF RANGE on the screen)
at mon.
PUSH the OSD button, menu, if OSD is dead the montor is dead.
OSD= on screen display., (yes the LDC has brain inside)
then take a flash light . point it at screen
see data now, if yes, in the beam is data the back lamp is dead
as are most 12 years old montors now.
see those 4 cream colored connectors bottom of this PCB
those are the high voltage CCFL lamps.
2 lamps 4 ends. the lamps are bad or the board 500 to 1000vdc
power supply is dead.
Sep 20, 2017 | HP L1940 19" LCD Monitor
HP Flat Panel Monitor is dead!
The power supply within the monitor has probably expired. HP doesn't do spare parts for their TFT monitors as they are Full Unit Replacement items (if in warranty).
Jan 25, 2008 | Computers & Internet
Monitor gone dead
does your tower turn on? just check if the monitor is the cause of the problem..
Jan 20, 2008 | Gateway FPD2275W LCD Monitor
Motherboard/chipset
check ur motheboard configuration on website or user manual..
Oct 19, 2007 | Computers & Internet
Computers & Internet Logo
Top Tatung Computers & Internet Experts
Tony
kj henriksen
kj henriksen
Are you a Tatung Computer and Internet Expert? Answer questions, earn points and help others
