Question about Smart Modular SV3170A
Monitor mymonitor works fine on another computer.but when i put it to my compaq computer witch is the one it came with my led light is lit but it stays yellow it want go to green where it will show something on the screen.
    President:
  • 317 Answers
Sound like you have a video card problem. You probably need to replace it. If you have another monitor you can use to test, plug it in to the pc, if it doesn't come on, you know it's probably the video card.
Posted on Aug 01, 2007
I have a dell studio 540 desktop, I need to restore to factory settings but my monitor will not stay open. It opens for a few seconds then immediately goes into power saver mode and turns off, how can
I see two things here, but need clarification;
1) Monitor goes to Power Saver Mode, then turns -> OFF?
Sure that monitor didn't go into Standby Mode?
2) Why are you performing a restore back to factory settings?
Pick up a virus?
Primer;
The monitor receives a signal. A video signal. The video signal comes from the computer.
If the monitor is NOT receiving a video signal, then the monitor will state No Signal.
This is for older monitors.
New monitors do not state No Signal anymore.
It's Power Saver Mode, or Sleep Mode.
If the monitor is truly OFF, the Power On button will Not be lit up.
Or the Power On LED light on the monitor.
Monitor power on LED is lit, or Power On button is lit?
Monitor is not receiving a video signal;
Use a monitor cable from a KNOWN to be working monitor, for a temporary test.
OR,
Use a Known to be working monitor, and it's monitor cable.
Need to find out if monitor cable is good.
Monitor cable checks out good?
Then problem is computer.
The two leading issues with desktop computer failure, is;
1) Computer is dirty inside
2) Power Supply inside computer is bad.
Please post back in a Comment.
Regards,
joecoolvette
Mar 27, 2013 | Computers & Internet
What does the red light mean next to the power button?
The red light next to the power button is usuall the hard drive led which should blink every time the hard drive is in use, there is normally a green or yellow light for the power that shoukld stay on constant when the computer is on.
Feb 09, 2010 | Intel Compaq EVO D500 (RBMDTCPQP42400) PC...
AOC color monitor model 5En...during power on all led lights blinks then stops blinking without display action. all led lights on no more action observed.
actually if u repair an aoc monitor alone without getting connected to cpu once u switch on the monitor all led's will lit on ( green light ) it will remain on situation until u connect the vga connector to cpu that's the time led's will lit off and only the power led will remain in green condition.some aoc 5en once u power on power led is in green condition and if not connected to cpu it will be in orange condition.hope u get some idea but i am not sure if it will work with ur monitor. but as long as LEDs lit on i think no problem with ur monitor.
Nov 02, 2009 | AOC 5 En 15" CRT Monitor
Green light won't stay on, changes to orange . Monitor stays black.
Sounds like a "power savings" feature.
If you are sure this issue is not a power saving feature, it means the inverter in the display is broken. The inverter is used to generate high voltage and lit the screen.
Oct 10, 2009 | HP Compaq V70 620 17" CRT Monitor
Monitor led light goes from green to orange will not respond
Your video card or on-board video is kaput. If it worked fine on the other system, but not working on this one ... then you've blow the video.
One note: When the computer is ON, do NOT unplug and re-plug in the monitor. You'll blow the video card.
Luckily, add-on video cards are cheap and readily available ...
Jun 12, 2009 | Compaq MV 540 15" CRT Monitor
Power light comes on but nothing appears on monitor
Mostly your heatsink damaged your motherboaard. check caps lock LED and Number Lock LED are working after switching on. If not ur motherboard or processor get damaged and u had mentioned what happened. Ur heatsink shorts some circuit in  your motherboard
Apr 06, 2009 | Compaq Presario 5000 PC Desktop
Pc won't start
try to reset BIOS by CMOS battery from motherboard and insert again...if not worked then..ur motherboard needs to be replaced...
Feb 04, 2009 | HP Compaq dc5100 PC Desktop
Sir Help me with my Compaq monitor MV520 it won't turn the power led flashing orange to green continously
it could be th epower supply and it could be the monitor.
power ON button should not flash orange regardless what you do. it should stay green. then orange. not orange to green to orange.
try the monitor on another PC if you can fine one.
the other thing is are the 2 monitor similar (CRT to CRT and LCD to LCD), you can't mix the the two, they will work but need different video driver to function correctly.
Oct 20, 2008 | Compaq MV 540 15" CRT Monitor
Smart Modular SV3170A Logo
Top Smart Modular Computers & Internet Experts
Stan Skaggs
Stan Skaggs
Are you a Smart Modular Computer and Internet Expert? Answer questions, earn points and help others
