Question about Westinghouse Refrigerators
Frost Free, freezer ok but fridge warm
Westinghouse 2 door frost free fridge is not getting cold air down into the fridge compartment. I have set the freezer compartment to minimum cold (to allow maximum air to pass down to the fridge compartment) and set the temperature to maximum as suggested in the manual to remedy such a situation. Did not appear to work. I have removed the fan and air distribution covers and checked all seals to ensure there is no cold air short circuiting or bypassing. The fan operates freely and there is no blockage in the air ducts down to the fridge compartment.
The freezer is operating with the cold air readily cirulating in the freezer, but there is no cold air getting down below.
I have also had excessive moisture in the bottom of the fridge over the last few weeks and this is most likely a related problem.
Any help would be appreciated.
  • digitor Feb 19, 2009
    Hi Len,
    Thanks for your input.
    I have placed an explanation of how it was fixed under another heading on the same day. For some reason this (and I note a few others) appeared
  • 150 Answers
If all else fails I would completely defrosted the unit.If there is any blockage this will open up all the tubes.Unplug it open the doors put pans of hot water in the freezer to speed up the process.
Make sure your fan is still working ,its located behind the freezers back wall. If it is working the vent from the freezer down to the refridgerater may be blocked.With out a fan you have no circulation but your freezer may look likes its working,it may last 3 days.Also if you can move everything out unplug it turn it off w/ doors open 12 to 24 hrs this will free up any clogged tubes. Good luck.
Len West
Posted on Feb 16, 2009
My Westinghouse Frost Free fridge is not working. The freezer is working. It is has the freezer on top of the fridge, separate doors
Even though it is frost free, try defrosting it by turning it off with the doors open for a few hours. There may be ice or something else blocking the vent between the freezer and refrigerator sections. Of course you will need to remove everything from the fridg and freezer and store it somewhere else that is cold.
Dec 22, 2014 | Westinghouse Refrigerators
Refrigerator doesn t get cold
If your refrigerator is frost free and been running for a year or two then here is the solution.
Why would you need to defrost a frost-free freezer? Because they do sometimes get frosted up! This is especially common if the door gets left open for long periods without being noticed, then shut again, thereby trapping lots of moist air in the freezer, which can only come out as frost. The problem is that if their defrosting cycles don't manage to cure their problems they get frosted up at the back, out of sight. If your freezer seems to be struggling to keep things frozen but is otherwise working normally you should consider defrosting it before concluding it is broken.
I have found the best way to defrost my not quite frost free fridge-freezer is to empty the freezer compartment contents into the fridge and switch it off overnight, leaving the fridge door shut and the freezer door open. By stacking all the frozen food together as tightly as possible, ideally wrapped in something to help insulate them (such as newspapers) they stay cold for a long time. In the morning I get in my scruffy clothes and wipe up the puddles caused by the visible frost in the freezer and any puddles formed underneath the appliance. However this is only half the story. To ensure all the frosting has been removed from the hidden parts of the appliance I get my hair dryer and blast warm air into all appropriate crevices from inside the appliance and from behind it.
Mar 07, 2014 | LG Refrigerators
Items in freezer are gathering significant front, when the freezer should be frost free
A frost free freezer typically relies on a "fan" to vent that area of moisture. So, if the fan/vent is not working properly, the moisture in the freezer stays and become frost. Frost can also form if / when the freezer door is not closing properly / completely ... allowing air / moisture to enter the fridge/freezer . Have those checked out first.
Mar 03, 2014 | Angelo Brothers Westinghouse (r) Savona ES...
Kenmore side by side freezer is working and air flow is ok with freezer door open...when close freezer door cold air flow to fridge stops
fan sometime runs when doors open only. if freezer is set too cold then a little door leading to refrigerated compartment freezes shut with frost and then the cold air cant get from freezer to refrigerator. good luck
May 07, 2011 | Refrigerators
The freezer works well but the fridge is not cooling.
Classic symptom of: the connection passageway between the freezer and the fridge compartment
has closed off - usually due to ice buildup - or something clogging/blocking the passageway.
Your Refrigerator works by releasing cold air into only the freezer, then this cold air passes thru
a passageway into the fridge compartment to cold (but not freeze) the fridge compartment contents.
If this passageway is blocked, then just the freezer works, and cold air never makes it into the
fridge compartment. In the old days, you'd be told to defrost your freezer, since the blockage
was ALWAYS caused by frost buildup. Today, we have frost-free freezers, and your freezer may
simply have too much stuff inside - there has to be some room to allow some air flow around
items in the freezer, and whichever item is blocking the air passage to the fridge compartment -
just move it away from the passageway opening.
Mar 15, 2011 | Westinghouse Refrigerators
Freezer is cold, but refrigerator is warm. The fan is running, but I don't feel cold air coming into the refrigerator compartment. There did not appear to be a large amount of frost anywhere, but just...
If the freezer is cold the compressor is Ok. Now if its a two door fridge . Open both the doors while the fridge is On. Press the lower door switch ( the lower light should turn off and you should hear the fan humming sound come on ). While holding the door switch pressed close the freezer door, you should see cold air come out of the slits in the back of the lower compartment. If not icicles have blocked the passages due to the non working of the heating coil.The heating cycle is controlled by the timer switch located near the compressor at the back. Unplug the fridge and remove the timer switch.Note the color of the wires and mark on the old switch. Replace and it will work.Only frost free fridges have heating cycle
Mar 07, 2011 | Refrigerators
Fridge not holding tempreture
if there is frost present on the rear vertical wall of the freezer compartment then the defrost function is broken and needs to be repaired the freezer is like an ice block and yo get cooling up to the refridgerator compartment air has to be able to flow and that can't happen if the frost is not eliminated
Dec 15, 2008 | Hotpoint FFA60 Bottom Freezer Refrigerator
Whirlpool arc7612. Fridge not getting cold. Freezer obviously working as it frosts up despite being 'frost free'. Slight gap in door seal near top of door. Last time we had this happen I unplugged it for a...
You have to replace the door seal. The seal may be a mundane technology and it isn't the only technology making a refrigerator frost-free, but it is the most important one. Warm moist air enters through the gap in the door seal, condenses on cold surfaces and freezes. The frost interferes with airflow and prevents the system from keeping the fridge cold. Turning it off for a day allowed the frost to melt.
Aug 03, 2008 | Whirlpool Refrigerators
Refrigerators Logo
882 people viewed this question
Top Westinghouse Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Westinghouse Refrigerator Expert? Answer questions, earn points and help others
