Question about Linksys Wireless-G Broadband Router
Linksys wireless G broadband router
When plugged in green lights 1234 ethernet and internet are litted steady. Power, dmz and wlan lites are off.
Please help.
Regards Ronald
  • Raymond Roque
    Raymond Roque May 11, 2010
    That's bad. Did you call Linksys Technical Support? Reset the router, if the power light is still off, that means the router might be dead.
  • 66 Answers
No problem if dmz is off ( only if you put one of your computer outside router firewall it will turn on though tghis is not recomended )
Wlan will be on only if you are connecting wirelessly .
Yes if power is not on spells trouble .
Go to your router support site update latest firmware it will end the problem .
Posted on Feb 16, 2009
Note that incoming traffic will cause the WAN (or Internet) light to blink even if it is 'probe' traffic trying to break in to your network. Such traffic is to be expected and is the reason you have firewall functionality in your gateway router.
On the inside, there is a bit of traffic on any LAN when the computers are turned on. Messages generated by the router itself are used to find computers and printers for a lot of different legitimate reasons.
Feb 25, 2013 | Linksys Wireless-G WRT54G Router
Can not connect wireless to internet
verify that the cable are conned correctly. now the ethernet cable that come from the cable modem do not need to be plugin to the port that is label Internet, it need to be plug in any port 1 to 4. then access you router via a ethernet cable and setup the router of wireless access.
Jan 13, 2012 | Linksys Wireless-G Broadband Router
No wireless connection for laptop. Linksys router - model #wrt160n v2
you can run a direct line to that router and go to the cisco web site and get the information you need to run that router. its a pdf format and is 2.56 Meg. Try this
SecureEasySetup (Orange/White) The Cisco logo is the Router's SecureEasySetup button. It
lights up and will stay orange when the Router is powered on. The color orange indicates that
the Router is not using the SecureEasySetup feature, while the color white indicates that the
Router is using the SecureEasySetup feature. When the Router enters SecureEasySetup
mode, the Cisco logo will turn white and start flashing. After the Router has generated
the SSID and WPA Personal key, the Cisco logo will stop flashing and stay white.
To clear the SSID and WPA Personal key, press and hold down the Cisco logo for five seconds.
The Cisco logo will flash slowly as the Router resets itself. The Cisco logo will turn orange to
indicate a successful reset.NOTE: SecureEasySetup is a feature that makes
it easy to set up your wireless network. If you have SecureEasySetup devices, run the Router's
Setup Wizard CD-ROM and follow the onscreen instructions to use SecureEasySetup.
Power (Green) The Power LED lights up and will stay on while the Router is powered
on. When the Router goes through its selfdiagnostic mode during every boot-up, this
LED will flash. When the diagnostic is complete, the LED will be solidly lit.
DMZ (Green) The DMZ LED indicates when the DMZ function is being used. This LED will
remain lit as long as DMZ is enabled. WLAN (Green) The WLAN LED lights up when
the wireless feature is enabled. If the LED is flashing, the Router is actively sending or
receiving data over the network. 1, 2, 3, 4 (Green) These numbered LEDs, corresponding with the numbered ports on the Router's back panel, serve two purposes. If the LED is continuously lit, the Router is successfully connected to a device through that port. A flashing LED indicates network activity over that port.
Internet (Green) The Internet LED lights up when there is a connection made through the
Internet port. A flashing LED indicates network activity over the Internet port.
Good luck
Nov 26, 2010 | Computers & Internet
Apparently wireless works, but not the wired network
If your computer is plug in to one of the ethernet ports that should light up. If not you can try another computer or try another ethernet cable. There is possibility that the port is busted.
You can perform a reset on your router and see if the status of the lights change.
If you think your router is still under warranty , you can call linksys support at 1800linksys .. They will be able to diagnosed the problem with your unit, if its faulty or not.
Jul 05, 2010 | Linksys Wireless-G WRT54G Router
Router stopped working.
As long as the power light stays solid, then the router is fine. You need to reconfigure the router for it to receive internet connection from the modem.
May 17, 2010 | Linksys Wireless-G Broadband Router
Cannot connect in any way to router, all lights on.
access your router's web-based configuration page at
Sep 04, 2009 | Linksys Wireless-G WRT54G Router
No power light, all other ports lit.
Well you know when you reset you router you have to reconfigure it so it works that could be it please email at if you need help
Jun 04, 2009 | Linksys Wireless-G WRT54G Router
WRT54GS router stopped working
try holding down the reset button which should be behind or under the router for 30 seconds, still holding down the reset button turn the power off for 30 seconds, still hoding the reset button wait more 30 seconds. After that your router should be in the way it came.
Feb 24, 2009 | Linksys : WRT54GS Wireless-G Router W/...
Setting Up a Wireless Network
You can still use your existing Linksys router with your cable modem. In fact the router your have is designed to work with DSL/Cable Broadband connections.
1. Make sure to properly connec the devices in your network. Modem will be connected to the Internet port of the router. Then, laptop will be connected to one of the 4 Ethernet ports of the router. For initial setup of your router with modem, you need to hardwire laptop to the router.
2. Press and hold reset at the back of the router for about 15 seconds.
3. After 15 seconds turn off the router and then turn off the modem. Wait for a minute.
4. Power on modem and wait for the lights to be ready.
5. When modem lights are on, turn on router.
6. There should be 4 lights on. Power should be steady green. Internet, WLAN and Ethernet port.
7. Checked if you have Internet connectivity on your laptop while it is wired to the router.
8. If Internet is working, disconnect laptop from wired connection to the router and check available wireless network that laptop can detect.
9. The default wireless network name that the Linksys router broadcasts is "linksys". Connect to it which is an unsecured wireless network.
10. Once you are successfully connected, check Internet.
Hope this helps!
Nov 16, 2008 | Linksys Wireless-G Broadband Router
Some light on; some not
disconnect power supply from the router, wait for 30 seconds , and reconnet it back then check you get the power light.. if not try in a different power outlet..check the physical connection, the modem should be connected to internet slot in the router ,so that you would find the internet light lit up.., if still you do ont see the power light or the wlan light, reset your router, if you look at the back of your router, you would find a reset button, press and hold the reset button , with a pen on paper clip for 30 seconds with the power cable connected and disconnectc power and reconnect and then check..if still not the problem is with your router
Nov 16, 2007 | Linksys Wireless-G WRT54G Router
Linksys Wireless-G Broadband Router Logo
342 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
