Question about Marantz Audio Players & Recorders
Marantz amp will not put out any sound
Have had this system for years. All of a sudden the amp will not put out any sound. The lights come on just no sound. Have checked the tuner on another amp tuner works fine.
  • 55 Answers
If it went out with no indications of trouble it's probably a fuse in the output circuit. It might be an out put amp but typically they let you know they're going bad with a little noise.
Posted on Feb 18, 2009
I have marantz 7'300 an the standby light is on but wont power on no screen no sound idk help please
Unplug it from ac for 10 minutes and then try it. If that does nothing you need to get it to warranty service. It has a 3 year warranty so should still be covered. No Video or audio output on MARANTZ nr1602
Jun 14, 2016 | Marantz Audio Players & Recorders
Marantz Legacy Series - no sound is getting to speakers from tuner or cassette.
It seams like the amplifer is not working and you are right but it certanly needs to be measured first.
Nov 28, 2013 | Marantz Tr 2242 Sb Legacy Series Pll...
Car blowing white smoke but no overheating has had a new cylinder head a year ago done 54.000
is there any coolant in the oil or oil in the coolant. It sounds like a head or gasket problem. Cooling system & oil system are supposed to be sealed systems. If u have add fluids it must be going somewhere. Leaking, burning etc. Good luck, get it checked out.
Jul 01, 2017 | Daewoo Lanos Cars & Trucks
My SR5500 from Marantz has a problem. It suddenly powers off and then a clicking sound is there. It then does not come on
HI...
Are the speakers all connected properly and set to the right pair ( A or B)?
Do any lights show on the front panel such as "Stand-by"?
Aug 16, 2010 | Marantz Audio Players & Recorders
Audio glitch on Marantz SR-19
It's probably not heat due to the Marantz' large frame and heat-synchs.
This could simply be a mismatch of impedance. The amp is 120w per channel, so make sure the speakers can handle this. Check the impedance (ohms) of the speakers and the amp as well. Clipping can be caused by overpowering the speakers, which could damage the speakers in the long-run.
If this is only from 1 source- (i.e.- Blu-ray player or cable) then it could be digital clipping.. This Marantz can decode 96kHz PCM or normal Dolby Digital & DTS. If this is a Blu-ray it may be streaming 192kHz PCM... (but most likely the Marantz will not even attempt to play that audio)
I hope this helps.
May 31, 2009 | Marantz SR-19 Receiver
Marantz PM 4000 has cut out
May be the problem solved here :
http://www.audiotoolers.com/ubbt/ubbthreads.php/ubb/showflat/Number/5316/page/1#Post5316
Nov 21, 2008 | Marantz Audio Players & Recorders
No audio
Go to amp set up menu and make sure it knows the cables you are useing,ie-if the dvd is wired with coax for sound go to input set up and tell the amp you are useing this type of cable.If this is not the problem and the sound is going off one device at a time your amp needs to go back to your dealer.
hope this helps.
CABLE GUY.
Jul 12, 2008 | Marantz SR-5600 Receiver
Surround Sound from PS3
Are you getting any sound?
If your marantz amp is part of a home cinema system then depending how old it is will depend on if it will do it automatically.I have just bought a sony surround system and it detects the signal range ie it knows it is being transmitted in 5:1 surround.If you have an old system you may have to do this manually, this should not be diffecult there should be a sound setting.
Jan 28, 2008 | Sony Playstation 3 (PS3) Console
158 people viewed this question
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
