Question about Maytag MER6772 Gemini Electric Kitchen Range
Circuit blows and when we get it back on the fault code says H3
We have a maytag gemini electric smoothtop double oven range precision touch 750 series and it is sporadic with blowing fuses and sometimes it takes a few tries to reset the fuses. When it comes back on it reads H3 at the top and then the clock flashes 12:00. I usually have one oven on and a couple of burners when it happens. However tonight it was blowing the fuse with only one burner on (after it blew it with oven and other burners on). Help! It is sporadic but is getting worse. An electrician said our circuit was OK.
  • Anonymous Feb 17, 2009
    Hi, I have an Ariston electric oven (4yrs old). Since day one we have had this problem and now fed up (no one seems to have an answer). 9 times out of 10, once oven has heated up and when we have finished cooking, we turn the oven off (with control dials at the front of the oven) and it trips the fusebox (and all the lights/sockets/appliances in the house go off). Only the section of the circuit breaker which is connected to the oven is affected. Oven repair man checked and found no problem with the oven. Electrician found no problem with the electrics and is completely confused by the situation. Has anyone had this problem before?
  • 706 Answers
Hello rcgrecco,
I will try to assist you but will be making some assumptions based on your problem description. First off, when you say it takes a few tries torest the fuses.. are you referring to circuit breakers? or changing out fuses a few time until it begins to work ok? In either case, the fact that it is drawing more current than the service ( fused or circuit breaker protected implies that you have one of two problems, 1. undersized service ( meaning the fuse of circuit breaker which protect the circuit is under-sized) or 2. a short internal to the stove or receptacle that supplies power to that stove.
I would approach a solution in this manner. Remove or disable power to the stove then open the wall receptacle and ( with power verified and off) tighten all wire junctions.. I have seen cases where a loose wire termination becomes resistive and then in order to meet power demand at the burner, more current is drawn which in turn causes the breaker or fuse to trip..) I would also check the terminations at the point of entry for the power cord at the stove. Make sure all the wire terminations are tight. Once you've done that, try turning on one burner at a time and see if the service remains on or trips the protector ( fuse/breaker) I wouldn't use the oven until I verified that each burner works OK.. then try the oven by itself.. and add a burner .. then two.. ( the point being is to try to determine if you have one of the heating elements shorting. 12:00 flashing is the default time setting after power is lost and restarted. I am almost 'questioning your electricians findings" since circuits do not trip unless there is a fault ( too much current being drawn or the service is under-sized for that oven) or... the circuit protection in and of itself is failing due to marginal components. The fact that it is getting worse suggests that whatever was shorting is shorting more frequently.. perhaps a heating element is shorting after it gets hot.. they are typically resistive elements and it is possible for a short to develop between the core material and the protective jacket.. I hope that helps you... or at least provides a few ideas on where to look...
Regards,
Rick
Posted on Feb 16, 2009
Only one burner doesn't work on my maytag gemini stove
MET8776BS Maytag Gemini Smoothtop Double Oven Range
reviews.us-appliance.com/.../MET8776BS-Maytag-Gemini-Smoothtop-D...
Rating: 4.5 - ‎94 reviews MET8776BS Maytag Gemini Smoothtop Double Oven Range - Stainless Steel - Reviews ... Really like the features, however one burner doesn't work, after a month.... 2 ovens sure beats the storage bin underneath! the only negative I can think of is ...I bought my double oven a few months ago and am very happy with it.
Oct 16, 2015 | Maytag Kitchen Ranges
Maytag Gemeni double oven stovetop stopped working
Thats the controller, you'd need to call a professional no quick fix for that one sorry. besides attempting to fix it your self will cause more damage than good
Jan 02, 2008 | Maytag MER6772 Gemini Electric Kitchen...
Maytag precision touch control 500 electric smoothtop
The heating coils in the oven need to be inspected very carefully where they plug in to the oven wall. You will need to remove the back covers and check the insulators and wiring harnesses. Over time the insulation can break down and oxidize the metal connections. You can use a voltmeter or test light to verify that the coils are getting voltage from the thermostat/switch. replacing parts is cheaper than buying new if you can find the parts.
Oct 04, 2017 | Cooktops
I have a maytag MER6772 Gemini Electric Rage it gave the F1-2 code. What must I do to Fix This Problem?
Maytag / MAYCOR / Magic Chef / Jennair / Admiral
Oven Fault Codes
Display Condition Remedy
F0 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F1 Defective Touch Pad or Membrane Replace Touch Pad or Membrane
F2 Oven over heat defective Relay Board or (if present) or defective Sensor
F3 Oven Sensor Open Replace Sensor
F4 Shorted wire or Sensor locate short and correct it or replace Sensor
F5 Hardware, safety circuits disagree Replace Clock
F6 Missing AC (power) signal Check for proper voltage (plug, breaker, etc.)
F7 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F8 A/D Warning Replace Clock
F9 Door Lock Warning Check door lock circuit or Replace Clock
Jan 16, 2010 | Maytag MER6772 Gemini Electric Kitchen...
I have a Maytag Gemini Precision touch 750 series double oven range MGR6775ADB. The lower over is not responding. It will not preheat. The display says preheat and stays at 100. There is no flame igniting.
This sounds like your ignitor has gone out. The preheat will work because the valve doesn't have to ignite to heat to 100 degrees, but whent he unit is ready to ignite, the gas can't ignite it. If you will call or email us, we'll be sure to get the correct ignitor out to you asap so you have your oven orking right away! Thanksgiving is just around the corner, so I hope you get this repaired soon. We hope this helps and we hope to hear back from you soon.
Sep 30, 2009 | Maytag MGR6772BDS Gemini Gas Kitchen Range
MER6779BAW Range/Double Oven
I haven't checked anything but the heating element. The fault codes read F0-0, which means no fault but..... ?
Mar 03, 2008 | Maytag MER6772 Gemini Electric Kitchen...
Maytag 500 electric smoothtop
lower elemnet in lower or upper oven??, should be an expused elemnt 2 screws on back wall of cavity should remove it forreplacemnt.TURN OFF POWER FIRST it is LIVE!!!!!!!!!!!
Feb 26, 2008 | Maytag MER6772 Gemini Electric Kitchen...
F1-6 Fault Code
This code is in responce to a fault/failure in the lower keypad assembly. It is possible the keypad was bumped.
Maytag Gemini fault codes.
Fault code Suspect area Fault code Suspect area
F0 - 0 None
F1 - 1 Runaway cook upper oven
F1 - 2 Runaway cook lower oven
F1 - 3 Runaway clean upper oven
F1 - 4 Runaway clean lower oven
F1 - 5 Keypad cancel upper
F1 - 6 Keypad cancel lower
F1 - 7 Keypad disconnected
F1 - 8 Keypad shorted
F1 - 9 Slave
Dec 29, 2007 | Maytag MER6769 Gemini Electric Kitchen...
Maytag MER6772 Gemini Electric Kitchen Range Logo
812 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
Sal DeAngelo
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
