Question about Toshiba SD-1200 DVD Player
Won't load. When I put a disc in, it says closing and does close, but you hear a noise but won't load the disc. Then it spits the disc back out.
    Problem Solver:
  • 14 Answers
Try cleaning laser maybe dirty, check all conections thanks jeff......
Posted on Feb 16, 2009
Disc won't stay in!
I found this link Apple support very helpful when I had the same problem, it helped me fix it.
Hope this helps
May 21, 2012 | Apple Computers & Internet
RA n out of gas won't start
remove gas cap put ear close to filler tube and have someone turn on key listen for pump to turn on it will be a buzzing noise if you hear this then try replacing the fuel filter if there is no noise check the fuel pump fuse if the fuse is ok then replace the fuel pump
Mar 26, 2012 | 1999 Chevrolet Silverado 1500
The door won't close
The problem is in the gear mesh, or there is a tiny loading belt not engauging properly, or a timing gear issue.
Mar 09, 2012 | Panasonic DVD-C220 Multi-disc DVD Player
Won't close
The problem is in the gear meshing, a tiny loading belt not engauging properly, or the timing gear is out.
Tray won't close fully then pops open again what needs to be done.
Hello
Its loading mechanism has the fault. It must be replaced. Check its loading belt, before replacing the loader mechanism.
Picture of the loader mechanism is given here.
http://www.dataentryjobs.us/67948.html2_28_2012_4_54_10_am.jpg
Feb 27, 2012 | Sony DVP-NC600 Multi-disc DVD Player
POT AND PAN DRAWER WON'T CLOSE PROPERLY
Take out the drawer. Lift it out. Make sure nothing is in the tracks. Take everything out of the drawer. Put it back and watch the tracks. If it closes properly you've over loaded it, otherwise you have bad tracks.
Jan 23, 2012 | Whirlpool 30" Self-Cleaning Freestanding...
Go Video DV 2150 - DVD door won't open at all. You can hear a mechanism working behind the closed door, but nothing happens and the door remains shut. Any advice??
There is a small belt under the loading tray which would have gone slack ( loose ) and the sound you hear is it slipping on the motor pulley. If you are confident you can remove the mechanism and turn it upside down and access this belt. Dismantle only if you can get the spare belt or your efforts will be in vain.
Sep 13, 2011 | GoVideo Go Video DVD/VCR Combo
I have a 2007 Honda Odyssey with the built-in DVD player. Now there's a DVD stuck in it, it won't play and it won't eject. Help!
if you look closely enough there is a small hole on almost any sound system if you do have one put a paper clip in there and wiggle it around a little bit youll hear a click and the system should eject the cd if not then the cd has jammed in there and shattered which means you will have to pay a profecional to take out the dvd and get the disc out. hope this helps and if not well i apologise
May 13, 2011 | Car Audio & Video
Jammed tray
Hi there, had a similar problem.
This unit is easy to open. the four screws on the sides and two i think on the back. When it is open you will have access to the discs in the machine. the last disc will probably be jammed between the facia and the caddy and will be impeding the carousel mechanism, once removed you should check the functions starting with eject, and again to cycle, load disc position 1 insert disc and check. this player i think rotated the disc on loading to a set position, would have to open one to check. hopefully the carousel is not out of sync and all is well.
May 01, 2009 | Sony CDP-C265 CD Player
RCA RS 1285 5 disk audio system won t show or play
When you turn on the unit the cd draw seams to open. I hear it making a noise like if it is trying to get ready to play. When you shut the draw it won't play, change tracts, or the disc thing to put in more disc wont work. Someone please help me
May 01, 2009 | RCA Audio Players & Recorders
Toshiba SD-1200 DVD Player Logo
137 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
