Question about Hotpoint HTS16HBR Top Freezer Refrigerator
Water leaking There is water on the floor coming from the rdfrigerator, what might the problem be
    Brigadier General:
  • 8,619 Answers
There are several things to check for: The condensing defrost tray under the fridge can crack or develop a hole and leak onto the floor. A door gasket not closing properly may cause sweating and leak onto the floor. Some fridge's have a humidity switch inside the fridge that should be turned on to prevent sweating on the center bar between the fridge and freezer section. If your fridge has developed a frost free failure problem, often the frost will travel down the suction line at the back of the fridge and drip water on the floor. The heat exchanger tubing can separate and also sweat and drip on the floor. A kit to repair a separated heat exchanger line, comes with instructions as well. Ice maker and chilled water fill lines can crack and leak as well, this is fairly common with the plastic lines as they can dry out and crack.
Please revert for any clarification.
A Fixya rating would be appreciated if you found this to be helpful.
Posted on Feb 16, 2009
Water leaking under fridge
a contant runing of water is most likely a leak in the ice maker supply hose , an intermitant drip of water is a drip pan thats full in bottom of fridge (closest to floor ) this water comes from the auto defrost cycle most times this water evaporates away , but as fridge gets older it makes more frost that needs melted hence more water ,sometimes it over comes the pan and runs to floor , a good flashlight and getting down to look underneath usually tells you source of leak
Feb 20, 2015 | Refrigerators
Whirlpool God 26cu ft French Door Refrigerator Model # GI6FDRXXY02 is leaking water on the kitchen floor. The water appears to be leaking in the front & water is leaking on both sides. Has anyone ha
There is usually a condensation pan at the bottom of a fridge. This can fill with water and over flow, causing what is happening. Also, the ice maker could be causing the problem because the water connections can leak at the back where they connect to the house water system.
Feb 03, 2015 | Whirlpool Refrigerators
I have water leaking in from above thru the electronic console, wondering if it might be coming from the roof racks? I also have water coming in on the drivers side floor and can't find the leak, any...
More likely is a leak at the windshield seal at the top of the windshield. The water on the floor could also be coming from around the windshield, water leaks travel anywhere they find a path. On a dry day, take a garden hose and with very little water flow, apply the water to the top of the windshield for a while. Check for water on the floor. The water that's getting into your electronic console is probably happening at speed.
Mar 14, 2011 | 2000 Jeep Grand Cherokee
2002 suburban has leak in driver side rear floor. Cannot see where water would be coming from?
We had same--water on driver side rear floor (soaked!). Driver side front floor seemed dry until feeling UNDER rug, was slightly damp. We found the location of TWO leaks causing this.
Leak #1 was through the parking brake line/cable seal; Recaulked with silicone. Removed plastic trim on floor between floor and door to reveal metal channel filled with water.
Leak #2 was where the door meets the car, near the hinge. It was the accordian-looking tube housing the wiring for the door. The big, rubber, circular plug connecting it to the main part of the car had come loose and water ran down through that, into the SAME metal channel filled with water from leak #1; will seal with silicone.
Note: We found that the channel filled extensively near the front door, BUT the carpet edge from the floor near the rear seat was dipping into it, wicking it up to the rear floor. Also, upon acceleration, the water in the channel gushed toward the back, thus soaking the rear carpet.
These leaks were found by removing all plastic trim (covering edges of carpet by doors), then one of us pouring water into specific areas of the exterior of the vehicle, and the other one watching closely with a flashlight for any signs of dripping.
Feb 18, 2010 | 2002 Chevrolet Suburban
Water leaking under floor when dishwasher runs
check the water to the unit it is locate under the door open the panel 2 -4 screw take flash light turn the unit on and see where the water come from ... it might be also from under your sink.
Jan 01, 2010 | Dishwashers
106.55244400 leaking water on floor
Hello, sounds to me like you either have a leak on the nut on the water inlet valve or a pinhole leak on the inlet valve body...have come across this many times may not see the leak from the valve because it is very fine spray but it's there...only real way to detect where it is coming from is to pull the valve out switch water on and see where the leak is....either this or you have a blocked drain tube in the refridge but with the info you supplied i would suggest the valve. If you have any other questions or concerns please feel free to comment again. Good Luck! Mike
Aug 17, 2009 | Refrigerators
95 grand am quad 4. water on floor boards?
might be a heater core leak coming through the vent system.
thats just first thing that comes to mind.
Mar 17, 2009 | 1995 Pontiac Grand Am
Heavy water leak in basement under fridge
Has this fridge got an ice maker???
Because ice makers require a water supply to make ice.
This could be where your water is coming from.
Jan 19, 2009 | Sub-Zero 650 / O Bottom Freezer...
Hotpoint HTS16HBR Top Freezer Refrigerator Logo
766 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
