Question about Sharp AR-M205 Copier
Sharp AR-405 error code F1-15
When the machine is turned on this error code F1-15 comes up on the display. The given description is "sorter problems, call for service." Any ideas? I've researched this code and found that it may be a stacker motor issue. I was just wondering if anyone has had any experience with this code and possible solutions. Thanks
    President:
  • Sharp Master
  • 990 Answers
Hello sir; this error code means " elevator motor "problem inside the finisher,check it out is something stuck the motor. or you have to replace one.
Posted on Feb 16, 2009
Lanier 5635 Sorter
Under user tools, system settings make all prints, copies to come out in internal tray, the front and rear covers have to come off to remove screw 1 each side the SC code is shift tray motor error
Dec 18, 2013 | Lanier Office Equipment & Supplies
Ir6000 error code e246-0002
fuser assy either getting to hot or not hot enough. Fuser error codes cannot be reset by power cycling the machine even though that is what the display tells you to do. In order to reset the fuser error code you must enter the service mode & reset the code. To enter the service mode:
press"Additional Functions" button (looks like a picture of a head with a star inside)
press the #2 and #8 at the same time (simultaneously)
press "additional functions" again
The display should show a choice of
copier,feeder,sorter,fax,or board service modes
Select copier
select clear
select ERR
press OK
Turn power off & back on.
****IMPORTANT****
After clearing error stay at the machine to see if it comes to ready. The fuser assy can reach 139 degrees C.(Water boils @ 100C) The error can only be cleared through the service mode because a technician should inspect the fuser to verify there is nothing faulty that could possibly start a fire. If you enter the service mode & clear the error, power cycle the machine & during warm up the machine throws a code again- turn it off, unplug it & call a tech for fuser repair.
Jan 11, 2011 | Canon Office Equipment & Supplies
The copier is displaying error code C06 (or C0b) 60. If I unplug the sorting tray (where the copies exit) the machine will make copies, otherwise it is frozen with the above error code and a red wrench? ...
I can tell from the code this must be a Minolta copier or made by Minolta. The CoB60 code is a sorter failure code. This code must be reset by opening, then closing the sorter. By that I mean if you have a 10 bin sorter that hangs from the left side of the machine then you need to release the sorter away from the machine then close it back. Same thing with the 20 bin which sits on the floor. Pulling the sorter away then re-attaching is the only way to clear this code. Now if the code comes right back then there is a mechanical problem which must be repaired. The 60 code deals more with the stapler in the sorter. You can try reloading the staples but that rarely works. It is either a jammed staple or a problem with the stapler itself.
If you need further info just reply back with your specific model and issues.
Thank You for using Fixya.
WheatlandServices
Nov 18, 2010 | Office Equipment & Supplies
It says error code C0b63 what does it mean
All Cob codes on this series of Minolta copiers pertain to the sorter. Most all of the time you can simply open and close the sorter to reset the code. By open and then close I mean that the sorter must be pulled away from the copier then closed back.
Make sure there is nothing interfering with the movement of the sorter bins.
If opening/closing does not reset the code or if the code comes right back after resetting then the sorter will need service as dis-assembly/repair/re-assembly will be required. You can also unplug the large connector going from the sorter to the machine and use the copier without the sorter. If you have a 10 bin sorter that "hangs" from the side of the machine then you can leave the sorter attached and it will work fine unplugged. If you have the 20 bin sorter that sits on the floor then the sorter will have to be moved away from the copier if unplugged to prevent the machine from jamming. If you unplug the sorter be sure to turn the copiers power off before disconnecting the sorter.
Good Luck and Thank You for using Fixya.
WheatlandService
Nov 11, 2010 | Minolta EP4000/5000 CS/PRO Copier
We have a sharp AR-M208 N fax machine. Error comes up F1-15 what does it mean?
Probably is a error referring to
Finisher Lift up trouble, on the sorter....
Tray that goes up and down, does NOT reach home position.
Jun 23, 2010 | Sharp AR-M208N Copier
Cannon NP6521, 531e error
check the sorter staple motor sensor or remove the sorter from the machine
Jan 06, 2010 | Canon NP 6050 Copier
Error on the machine display is ch
If the CH is blinking the cartridge is not installed correctly. Remove and reinstall cartridge.
If the CH is on constant, it is a sorter problem. Check sorter for paper jam or bins out of place, and sorter connection.
Hope this helps.
Ed
May 18, 2009 | Sharp AR-5320 Black and White Copier
Sharp copier model SF2530 F1 flasing and copier
Hello sir; F-1 is sorter problem, did you connect sorter with machine, turn power off and check th connecter .
May 15, 2009 | Sharp AR-5316 Advanced Digital Imager...
Lanier 5645 copier - Code sc546
Try this press the "yellow/ca" botton, then enter 1-0-7, then press and hold the "red" stop" till the display changes. Once, it changes turn the Main power switch OFF. Not the one on the control pannel. Let it power down then turn it back ON. If the problem is still there try to turn the copier Off again and unplug the sorter/ finisher and turn the copier back ON. Is the problem gone, if so you may have to get a service person come in and repair the sorter. Good Luck.....
Apr 06, 2009 | Lanier Office Equipment & Supplies
Sharp AR-M205 Copier Logo
2,305 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
