Question about KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator
Kitchenaid KSC25INSSO Frig middle divider between compartments
The divider between the fridge and freezer is extremely hot, cant leave my hand on it because it is to warm. everything else seems to be working
  • 1 more comment
  • Anonymous Apr 25, 2009
    too hot to placehand on divider
  • mcconnell9 May 07, 2009
    I have the same problem - the divider between the fridge and freezer is extremely hot - to the point that it burns your hand to touch. We cleaned out the compressor area of dust, etc -- but after a week, nothing changed.
  • Mark Egan May 11, 2010
    When was the last time the bottom, compressor section of the refrigerator was cleaned of accumulated dust?
    The divider should be warm, and that it is too warm for you is subjective. A temperature reading is more analytic and would better help toward diagnosis.
5 Suggested Answers
  • 218 Answers
SOURCE: Kitchenaid Refrigerator door gaskets are getting very warm.
When the center divider gets hot, it usually means that your condenser fan (the one that blows air across the coils under the fridge) is not working, or that the condenser coils are extremely dirty. Next time the fridge is running, see if there is any air blowing underneath. You probably need a new condenser fan.
Posted on Jan 26, 2009
jumptrout51
  • 3361 Answers
SOURCE: Kenmore elite side by side: hot divider
This is normal. There is a heater in this panel to stop condensation sweating between the doors.
Posted on Feb 23, 2009
peyton32034
  • 410 Answers
SOURCE: Kenmore 5126101 middle separator b/t fridge/freezer extremely hot
There are 2 or 3 things that would cause this. first make sure the condenser coils are not plugged with dust (vacumn or blow them out) next check to make sure the fan that cools these coils is running, (this is the most likely problem). if both of these check out ok then you would need to check to make sure your interior lights ar going off when the doors are closed as these will add extra heat and cause the center rails to run hot. last and most uncommon would be a freon system problem.
fyi there is a hot gas freon line that runs in between the doors to prevent exterior sweating. when poor or no air flow problems for the condenser coil exist it causes this area to become hotter.
One more thing. if you do determine that the condenser fan motor is bad you can put a normal house fan blowing on to the coil to help cool this area down until you can get the unit repaired.
If you need any further assistance leave me a comment here and I'll gladly get back to you. Thanks Peyton
Posted on Mar 11, 2009
mark_37388
  • 100 Answers
SOURCE: Divider strip between fridge and freezer is hot
First take the grill off at the bottom under the doors look at the grate under the frig That is your condenser it will probably be covered in dust clean it off the see if you can fill air blowing under the frig there is a fan under there that keeps that coil cool and it runs around the door to keep condensation from build around the doors if no air is blowing take the back panel behind the Frig and there should be a fan running if the compressor is running this will also cause the compressor to over heat and will not cool as well but it might just need to be cleaned Good luck
Posted on Apr 03, 2009
  • 5 Answers
SOURCE: KitchenAid ksss48qmb01- divider between the two
generally this problem is caused by the evaporator fan not running, check the evaporator fan motor for blockage and or failure.
Posted on May 20, 2009
We moved our refrigerator and cleaned the coils and now the coils are extremely hot and so is the outside of the fridge on the freezer side and on the divider between the the fridge and freezer.
The can get pretty hot. However you should check to see if there is a moisture control switch on that unit. Change that to the other setting and see what that does.
Feb 01, 2014 | KitchenAid Superba Architect KSCS25INSS...
Wall dividing fridge from freezer is very hot to the touch
You either have obstructed coils (lots o dust) under the fridge or the fan that is supposed to draw air across them has ceased to work. Check the coils and clean as necessary, and check the fan. Maybe you will get lucky and find something caught in it. If the fan is not working, leave the back cover off the fridge and put a small window or box fan back there until you can get the fan replaced. The fan will keep the fridge running for you in the meantime.
Jun 29, 2010 | Refrigerators
My frig is not cold enough
Maybe the room you store it in is to hot as the fridge will only cool a certain amount of degree's below the ambient temperature, if it has a freezer compartment make sure it is regulary deforsted as the fridge temperature is linked to the freezer temperature.
Regards
chris
Jan 15, 2010 | KitchenAid Refrigerators
KitenAid KSRX25F -- HOT FRONT FRAME
The fan which cools the compressor is not working , OR , the coils under the front of fridge are very dirty .
Aug 01, 2009 | KitchenAid KSCS25IN Side by Side...
Frig not very cold & metal between freezer and frig gets hot
Poor cooling and a hot divider mean that air is not moving effectively over the condenser coils under the fridge. Check to see if the fan is blowing under there while the compressor is running. If not, then the condenser fan has failed and needs to be replaced. If it is, then use a vacuum with a long nozzle to give it a good cleaning under there.
Jul 20, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Apr 03, 2009 | KitchenAid KSRG22FK Side by Side...
Compartment Divider on side by side refrigerator gets very hot
Clean the condenser coil underneath the dust bunnies keep the coil from cooling. What you feel is your elictir running away
Mar 14, 2009 | Kenmore Refrigerators
Feb 23, 2009 | Kenmore Refrigerators
Heat build-up
Had this same problem and turned out that the coils at back of fridge and below doors were covered in dog hair. After vacuuming, area is no longer warm.
Aug 02, 2008 | KitchenAid Superba Architect KSCS25INSS...
Samsung side by side center divider front extremely hot
That sounds like you may have something in your condenser fan motor.. piece of bag, paper and may have stopped your fan altogther.. that would be the first place to check.. right by your compressor in the back of frig.
Aug 21, 2007 | Samsung RS2630SH Side by Side Refrigerator
KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator Logo
81 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
rugby prop
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
