Question about Kenmore Dishwashers
Very noisy in rinse motor is very noisy, i stopped arm from rotating and figured out that wasn't problem, sounds like motor
  • 706 Answers
You may have something lodged in the pump that is causing it to rattle a bit.. Depending on the model, you may need to remove or disable power, then gain access to the pump by removing the toekick panel from the front.. You may also be able to zero in on the specific cause of that rattle by removing that toekick and cysling the dishwasher while listening for the source of that rattle.. A flashlight may help spot that source.. Hope that at least gets you headed in the right direction... Re-post if you still have an issue..
Regards,
Rick
Posted on Feb 16, 2009
My customer is having issues with the unit not cleaning food from dishes.
You must be able to hear if the water is being sprayed with force onto the plates. Did you check that the wash arm and rinse arms rotate? I have seen them stick and not rotate. Did you remove the arms to check for blocked jets. You would be surprised at what can get stuck in them, grey lint in particular, plus seeds and pips.
what is the Make (LG?) and Model.
Aug 23, 2015 | LG Dishwashers
Machine Running noisy during cycle
lift off spray arm and remove motor rotor and remove any debri this can cause a noisey motor.
Sep 04, 2012 | Fisher and Paykel 24 in. DD603H W Built-in...
My Frigidaire dishwasher upper sprayer arm is not rotating. Can't figure out why?????
Over time, dishwasher spray arms can become clogged with minor debris or hard water buildup that can prevent the arm from turning properly. An easy suggestion is to apply rinse aid to the junction between the spray arm and the mount to help remove it. Try this tip first to see if it resolves the issue. - Best of luck!
Aug 27, 2012 | Frigidaire Dishwashers
The dishwasher has three arms in it. The top and bottom arm do not rotate. The middle arm rotates fine. The arms will move when manually munipulated but do not spill while the dishwasher is on. There was a...
sounds like maybe some rinsing salt was spilled when the salt reservoir was filled the first time (or broken glass, this always used to be an issue in catering) and got pumped through, lodging in the gap between the arm and it's mounting. this can roughen the two meeting faces of plastic and cause them to jam up.
remove the arms and examine the state of the plastic, also look for granules/particles of glass. if it was salt it will be long gone...
Dec 08, 2010 | Maytag Dishwasher
Both spray arms of my DU943PWKQ0 do not turn or spray. The motor is moving and the it drains without problem. During the wash and rinse cycle I can hear the sound of water, however it doesn't clean at...
Try rotating the spray arms by hand. It should rotate freely. If possible clean the arm rotating place by removing them.
Arms rotate by by pump pressure only. finally check the water pump also.
May 18, 2010 | Whirlpool DU943PWK - Multiple Color...
Bottom spray arm not rotating
The arm usually will stop rotateing because there is a obstuction in the arm itself you will need to remove the arm normally unclips (older machine used to scew off)When you have the arm out check all hole top and bottom and open any that are blocked rinse out arm and replace give it a wash and see if there is any improovement,let me know.
Thanks
Feb 01, 2009 | Kenmore 24 in. 15689 Built-in Dishwasher
Wash Arms not spinning --Dishes not clean
Without the model number of your Maytag number, I can not determine if when you order a wash pump motor you also get the impeller.
Sounds like you are on the right path to getting your dishwasher to wash dishes again.
Oh, while you have the dishwasher open, check that the heating element has not failed using a Multimeter.
Good Luck!
Feb 01, 2009 | KitchenAid 24 in. KUDI02IRBS Stainless...
Noisy Bosch dishwasher SHU43C05UC
your main wash motor is faulty it must be replaced.
May 05, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwasher
I had this same problem. I think its the upper spray arm vibrating during wash cycle. To verify; prevent the upper arm from rotating by putting a long spatula through the top rack or zip tie the arm so it don't rotate. If the noise goes away you found your problem.
Feb 15, 2007 | Maytag 24 in. MDBH940AWS Built-in...
Dishwashers Logo
78 people viewed this question
Top Kenmore Dishwashers Experts
Fred Sops
D. E. Hev
Raisin Brann
Level 1 Expert
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
