Question about NetGear WGR614 Wireless Router
WHEN SETTING UP A NETGEAR ROUTER IN THE FINAL STEP ...
....IT ALWAYS SAYS THE ETHERNET CABLE ISN'T CONNECT WHEN IT IS. IT THERE A REASON FOR THIS?
  • 2 more comments
  • egthree Feb 16, 2009
    I'M GETTING THE FLAG ON THE DESKTOP. NO WIRELESS INTERNET ACCESS.
    I'LL DOUBLE CHECK MY CONNECTIONS. THANKS.
  • Mark Egan May 11, 2010
    OK.
    You should be plugged into the NIC card on the back of the desktop, and the back of the router (unless the desktop is trying to connect wireless, which you indicate not.).
    The other end should be connected to the back of the router.
    Are you getting this flag on the laptop or desktop computer your using?
    Are you connected to the internet wireless at the same time?
    Scholar:
  • 141 Answers
Try to call Netgear. If you can't resolve it try this http://technicalsupport.blog.friendster.com
Posted on Feb 16, 2009
Hey. I want to use my Netgear WNR1000 as an extra accespoint for better range, is it possible?
Step 1: Make sure your old router is working. Step 1a: Connect the Broadband modem to your OLD_ROUTER's Internet (WAN) port. Then connect the computer to one of the four available ports on your router through an Ethernet cable.
Step 1b: Make sure that the Internet connection is working on your computer and on your wireless devices.
Step 2: Configure your new router
Most routers have an IP address of 192.168.1.1 so before you connect them, you need to ensure that they have been assigned two different IP addresses.
Step 2a: Shut down your OLD_ROUTER and the modem. Also unplug the Ethernet cable from the computer.
Step 2b. Plug the Ethernet cable into any of the numbered ports of NEW_ROUTER and connect the other end to your computer. Switch on the NEW_ROUTER.
Step 2c. Access the web dashboard of NEW_ROUTER (192.168.1.1) and change the local IP address to something like 192.168.2.1 so that there's no conflict with the old router. Save the changes.
Step 2d. Test the SSID name of the new router and make sure it's different from the old router. Also make sure that SSID broadcast is turned on. Save the changes.
Step 3: Connect the two routers
Step 3a. Connect the modem to the Internet Port of the OLD_ROUTER.
Step 3b. Connect one of the number ports of OLD_ROUTER to your computer.
Step 3c. Connect another free port on the OLD_ROUTER to the Internet Port of your NEW_ROUTER using an Ethernet or LAN cable.
Jun 04, 2011 | NetGear WNR1000 Router
I have got username(admin) password)1234) wanting
Please connect the Netgear Router to your Laptop with a Ethernet cable.
In order to connect Netgear Router to your Laptop please follow these steps:
STEP 1 : If you look at back of router there are 4 LAN ports that are together and 1 WAN or Internet port which is alone. Connect the Internet cable ( provided by your Internet Service Provider) to WAN or Internet port of router .
Now take another Ethernet cable and connect one end of the cable to any one of 4 LAN ports and connect the second end to your laptop. Now please turn on the router.
STEP 2: You can see Power, Internet, Wireless and one LAN port light there on the router. Now come to computer and try to open the router login page.
In order to open the router page , you need to open your Internet Explorer and type 192.168.1.1 in the address bar.Now it will ask for router login information .
Username = admin Password = password
If it doesn't work please try to check the IP address of your computer ( In order to check the IP address of computer, Click on START menu , goto RUN and in RUN Window please type cmd. A black window pops up under this please type IPCONFIG and check the ETHERNET adapter IP address.
Now try to open the router page using this IP address.
STEP 3: Now on the router page you can see number of option on the left side. In order to change or secure the router for wireless connection please click on WIRELESS SETTING option under BASIC SETTING.
Under the SSID : type the name for your wireless network ( of your choice) CHANNEL : it should be 11 or 6 . Security : select WPA-PSK and under key please type any password of your choice ( it must be 8 characters atleast)
Please save the setting.
STEP 4: Now unplug the Ethernet cable from your laptop. Under the wireless networks , you can find your wireless network name . Just select it and click connect on. It will ask for security key or network key please type the same password that you have created for wireless setting.
Now it will connect you to your wireless network that is secured now.
Dec 09, 2010 | NetGear WGR614 Wireless Router
How do i connect my netgear rangemax wireless router
You should have a manual/setup guide.
BUT, the basics of setting a wireless router are.
Connect an ethernet cable from your MODEM to the WAN port on the rear of the ROUTER.
Connect an ethernet cable from one of the LAN ports (usually 4) to your computer.
You now log on to your router via your web browser, set your wireless security (using WPA2) choose your password.
Save and exit from the router setup, disconnect the ethernet cable from your computer to the router and try and connect wirelessly
Your support page is here, choose which version of the router you have and download your manual
http://kb.netgear.com/app/products/family/a_id/1299
Aug 11, 2010 | NetGear RangeMax WPN824 Router
Have wireless broadband on home computer with Netgear dont have network key which I need to connect new laptop to wireless broadband Bt of no help and cannot give me a no fo Netgear either even though Bt...
You will need to check the wireless settings of the router .
Is there any computer connected to the router with the Ethernet cable?
If not then connect 1 computer to the router and open the router set up page. Once you open the router set up page, you will be able to find the wireless network key.
Use that password to connect to the wireless network
Click Here for step by step Instructions on how to find the network key
Dec 19, 2009 | NetGear DG834G Router
I have a NETGEAR wire/wireless router MBR624GU. My internet provider is Comcast using a high speed internet modem by Ambit model U10C018. I connected the Comcast modem to Router LAN port using a Ethernet...
If you connect the computer directly to the modem, does it work?
If that works then the modem is working.
Now connect the computer to the router and the modem to the router.
You will need to open the set up page of the router to check the settings of the router.
You can set up the router without the CD also.
It is very easy.
Click Here for step by step instructions about how to set up the router
Dec 10, 2009 | NetGear MBR624GU Wireless Router
How to connect Netgear to Time Warner internet modem? I have Netgear installed on my computer, and I have the internet modem plugged in to my computer.
Just disconnect the ethernet cable from the computer and put it into the slot called internet on the router then run ehernet cable from port 1 to computer.
Dec 05, 2009 | NetGear WGR614 Router
Netgear WGT624 router won't connect to the internet
I am in the UK and have found through experience the Netgear's seem to work perfect on a BT line (equivalent of AT & T)
but not on the cable.
I would suggest purchasing a Linksys by Cisco WRT54GL Wireless-G Broadband Router as these seem to install in minutes,
saves me hours of wasted time when setting up wireless networks.
Jan 18, 2009 | NetGear WGT624 Wireless Router
NETGEAR WG111T 108 MBPS WIRELESS USB 2.0 ADAPTER
Configure router via ethernet cable in first instance. Then install adapter. May need to hange MTU for AOL as ISP.
Oct 08, 2007 | NetGear WG111T 802.11g/b (E82321) Wireless...
NetGear WGR614 Wireless Router Logo
24 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
