Question about Pioneer SD-532HD5 53" Rear Projection Television
Alinement of blue cross with red and yellow.
Can not aline the blue cross with the yellow and red. the screen is out of focus. the blue cross will not move, the yellow and red can be alined.
    Genius:
  • 2,920 Answers
You will need to call someone in to realign the picture...
Posted on Feb 16, 2009
Jvc manual
Well there is no yellow, there is only red, blue and green, Blue is the set line the other 2 need to be aligned to. If blue is bent or out of alignment then there is a problem with some internal chips that would require a good deal of soldering skill
Jan 03, 2012 | JVC AV-48WP30 48" Rear Projection...
Screen is red and I cannot adjust it enough to get the red out
Problem is going to be in the Green and Blue Tube ,you need to change the Coolant Fuild out and out in New,Philips is well known for having Bad Coolant fuild in the G/B Tubes.
With Back Off and TV on Look down inside of each Tube you should be able to see a Clear picture, in each Tube, If you do Not then you need to change out the coolant fuild.
You also have a Screen/Focus Control Block, it controls the Screen Drive and Focus to Each Tube R/G/B 3 controls on top and 3 below them. Top 3 should be for Focuse and Bottom 3 Screen Drive /Brightness to each Tube.
Now in order to aline for Correct Color you will need to adjust all 3 Tubes , Turn Color OFF in Menu then aline the Tubes untill you have a Black and white Picture ,Then go back to menu and turn Color on.
Mar 01, 2011 | Philips 51PW9303 51" Rear Projection...
Mitsubishi VS-6041 focus issue
Try adjusting the sharpness in your TV's menu. If it's not just that, then perhaps the tube/LCD display is simply degrading.
Jun 03, 2010 | Mitsubishi VS-6041 60" Rear Projection...
How do i re aline my projection Hitachi TV out of the 6 x 5 are out of line how do I fix it
I'm not sure what you mean by: "out of the 6 x 5 are out of line"
If you are referring to aligning the colors on the screen, the settings you are looking for are called "Convergence". There will usually be a red, blue, and green cross you will have to line up perfectly. the green is usually not moveable.
May 16, 2010 | Hitachi 61SWX12B 61" Rear Projection...
Can't aline the vertical red and blue on the left
The Convergence circuit has failed. It is recommended that a professional do the job.
The Convergence IC's need to be replaced.
It will be a STK393-110 or a pair of STK392-570's.
Hope this helps,
skyassoc
Jul 16, 2009 | Mitsubishi WS-65819 TV
Mitsubishi ws55809 TV
recommend you ask slinteriors http://www.fixya.com/users/slinteriors
Aug 28, 2008 | Televison & Video
Unable to converge red/blue
youre convergence ICs need to be replaced. You will need two STK392-120 ICs . You can get new ones here with online free support to help you do the repair, plus they send step by step instructions with pics on how to do the repair. Here is the link.
http://servicemanuals.vstore.ca/
Apr 18, 2008 | Televison & Video
HP880c missing colors
you need to go to preferences and adjust the new cartridges, aline, clean, etc.
Jan 06, 2008 | Office Equipment & Supplies
Color problem
Did you try alignment of color convergence in setting up. Try this
1 Press MENU
2 Select SET UP
3 Select CONVERGENCE
4 Select screen mode ZOOM this accesses the center convergence adjustment.Press set/enter
5 Use arrow keys to aline the red cross to the white cross.Press set/enter
6 Use arrow keys to alingn the blue line in the same manner. Once adjustment is complete press MENU to turn the menu off.
I hope this helps if you cant move the red or blue lines you face the same problem I face. I still havent gotton any solutions to my post about being unable to adjust the red line.You could also call Pioneer's help line 800-421-1404.
Oct 04, 2007 | Pioneer SD-P50A5-K 50" Rear Projection...
Pioneer SD-532HD5 53" Rear Projection Television Logo
154 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
