Question about Intel D845GVSR Motherboard
D845GVSR motherboard replaced but PC won't boot
I recently installed a new power supply and a D845GVSR motherboard in an eMachines PC. It now starts the fans, etc., but the monitor won't come out of sleep mode. I have tried to run the CD that came with the replacement motherboard, but the CD won't open also. Any ideas???
  • tsamerson Feb 16, 2009
    The motherboard was a direct replacement for the original one in the PC.
  • 106 Answers
Please check your RAM if it is compatible in your new motherboard.. go check the manual of the board you buy.. or visit the website of your new motherboard.. cheer. ^^
Posted on Feb 16, 2009
  • 90 Answers
You need to update the BIOS. Please download the required BIOS patch.
Also check after removing the CMOS battery once, for 15 min. then place it again. It will loose the info contained and then easy to load a new one.
Posted on Feb 19, 2009
Fan Speed 100% on Intel D845GVSR motherboard
see if you plug them in the right spot cpu gose by the cpu case fan will say case on board some take two wire fans some 4 wire some 3 wire jim
Feb 20, 2010 | Intel D845GVSR Motherboard
E-Machine PC with only a green LED on MB on Boot attempt
We have repaired many of these systems. The board was damaged when the power supply shorted. You can get replacement motherboards at www.barebonekit.net click on the link on the left side for motherboards and look for Emachine.
I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Jul 16, 2009 | Intel D845EPI (INTELKD845EPILPAK10)...
I have a emachine PC. PowerSupply blew up. changed it still down
try to remove the memory and put it back again make sure put it fit and correctly
May 28, 2009 | Intel D845EPI (INTELKD845EPILPAK10)...
I have the emachine t1100, huge desktop monitor worked fine until I installed a new video card,, the ATI Radeo 7500 64MB PCI. Computer does not boot up but fan goes on. I also disconnectd the card to go...
Try taking out all the newly installed components and see if this restores operation to your computer and monitor. You may have overloaded your system and either the power supply failed you or the motherboard.You might not have damaged anything yet, but you must take out all the new stuff and test. If the power supply failed, the unit will not start. You must check the units operation on start up. See if the fan is working. If not try replacing the power supply and test again to see if you get operation.If not you may have a problem with your motherboard. This should be tested in a service center where they can check the voltages to the motherboard from the voltage regulators. Hope this helps you with your problem.
May 07, 2009 | E-Machines eMachines Desktop PC
Dear,
ELECTRIC SHOK OR IMPROPER EARTHING IS DAMAGE POWER SUPPLY,MOTHERBOARD,PROCESSOR,RAM
HOW TO CHECK IT.
(WHEN CHECKING KEEP CAUTION :- REMOVE HARD DISK DRIVE POWER SUPPLY SOCKET)
1. check power supply watt 400/450 and same another power supply install and check it. if power supply change and system is working ok so problem in your power supply.
2. check CMOS cell on motherboard,(3 volt)
3. Bfore power supply changing check on mother board any capasitor is like as damaged or not.
OR check main chipset ic is marked as intel.whenpower on it is very hitting or
normal)if very hitting require to repair your motherboard.(intel chipset ic near cmos cell or pci slot,)
4. checking of ram on other pc (working or not)(one beeps coming or not,if one beep coming ram is working ok)
Feb 27, 2009 | Intel D845EPI (INTELKD845EPILPAK10)...
Intel d845gvsr
Fiend your solution direct from intel. Here is your solution........
http://www.intel.com/motherboard/prob676ijt65/solution
108
Jul 08, 2008 | Intel D845GVSR Motherboard
Intel D845EPI/D845GVSR MB problem
if you can get past the POST properly and see the drive size, nothing is wrong with the drive hardware. I think XP is seeing a previous boot sector install so try first to fdisk, format and system boot the drive. This should remove any boot sector "shadows".
Dec 26, 2007 | Intel D845EPI (INTELKD845EPILPAK10)...
Emachine T2742 MB D845EPI/D845GVSR
The diagram for that 9 pin J9G1 is alongside the CMOS battery.
Dec 25, 2007 | Intel Desktop Board D845EPIL Motherboard
Intel D845GVSR Motherboard Logo
101 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
