Question about Sylvania 6427TE 27" TV
Fuse constantly pops when turning on power
I have a question. My tv stopped working after playing with the outlet, of hooking it in and out to move cables around. it just popped and left a brown mark on the outlet plate. I took apart my tv and saw the fuse was blown. So i replaced the fuse and everytime i plug it in the darn thing pops right away. i hear the tv coming on and ''pop'', i replaced it several times. What you think i can do. BTW it's not an iLO or anything. i'ts a sylvannia. been working perfect until then.
  • NeedRprHlp Feb 16, 2009
    Thanks i will Try that
    works! THNX
    Problem Solver:
  • 14 Answers
Check power supply transisters possible shorted
and check transister next to ht runs picture may be shorted also check diodes 4off runs ac to dc
changover , this possible causes the fuse to blow , allways be carefull when pluging any
electrical item in
please let me know how you go thanks jeff..........
Posted on Feb 16, 2009
Why was it working and now won't turn on?
Low voltages or burning fuse on power in motherboard may have harm. Check fuse for first trick.
Jul 04, 2015 | Vizio Televison & Video
Toshiba hooked to dish struck by lighting, will not turn on, solution?
Ensure the power outlet has power. Try TV on a different power outlet. Switch off TV manually, switch off power, remove plug and retry after 48 hours. If problem persists, please refer it to a qualified service technician.
Aug 01, 2012 | Televison & Video
How do i stop my jvc stereo from resetting, because every time i turn off my car every thing gets reset
There is a constant power wire and a switched power wire. The constant must be hooked up to a constant power (one that doesn't lose power when the car is off). Either the YELLOW or RED wire will be the 'constant on'. Or you can hook that one directly to the battery. The other power wire from the deck should be hooked up to the switched power (or plugged in with a fuse that turns on with the car). Voltometer is your friend here.
Jul 29, 2010 | Car Audio & Video
Pops power supply fuse when I plug it in
Check to fuse box to see if the fuse is working properly. Next, see if the TV "pops" the power supply when pluged into a different outlet in a different power supply area. If the TV works without poping the fuse, the fuse with the original outlet needs replacing. If both outlets "pop", either the electrical system needs checking. Or if this is a new problem that started when you first tried the TV, the TV could be wanting more power than the electrical system will allow. Check the power requiremnets in the TV manual.
Jul 28, 2009 | Recoton Advent Advent TS2066A TV
Vax v-060p not powering up
All houshold electrical appliances which are constantly moved about eventually stop working due to fatigue. The most likely cause of your problem is the power cord from the wall outlet.
Replace the power cord then check again to see if it turns on.
Best wishes,
Graemevm
Jun 06, 2009 | Vacuums
RCA 36' tube tv won't turn on
possible that a fuse blew while transferring tv, most like to happen despite care in handling if tv was on for a while, kind of like moving a light bulb that is hot and suddenly filament breaks when you move the bulb slightly. Other than that I'd say it's a good time to get a new tv just in time too for the digital transition.
Feb 06, 2009 | RCA F36450 36" TV
Have just installed sony cd radio in puegeot 206.All works great, but when ignition turned off,unit looses its memory,looks like its not getting constant 12v.how do i overcome this.Somebody suggested that...
Sony cd radio player has Yellow wire in rear connctor. This wire supply volts to keep memory alive. Check is it hooked with Battery volts ( 12 volt )
Aug 20, 2008 | Car Audio & Video
Panasonic CT-32SL14 flat screen tv stopped working
We played Wii sports and fit for few hours than tv started to flicker and change colors to green and black and white. We shut down Wii and not TV screen doesn't show any picture. The power is there and the sound... but the screen is just blue. Any one experienced anything similar?
May 20, 2008 | Panasonic CT-32SL14 32" TV
JVC TH-A10 Won't TUrn on...
Unplug the JVC and the subwoofer from that outlet. Then, plug them back to a different outlet (where power is constant and not interupted by any switch.) Hope this helps
Aug 25, 2007 | JVC TH-A10 System
RCA VR601AHF
I just had this same problem. I thought that the timer was stuck and was the reason why the VCR wouldn't play. I just moved and thought the unit got broken in the move. However, I think it was just not hooked up properly to the TV. I unplugged it, plugged it back in, and got it hooked up properly and it started working again (I tested the connection with a DVD player first). The flashing timer light went off as soon as I reset the clock. It seems odd that having it not hooked up properly should stop the VCR from playing, but that is what seemed to happen in my case. Hope this helps.
Aug 16, 2007 | RCA VR622HF VHS VCR
Sylvania 6427TE 27" TV Logo
103 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
