Paragon 8145-20 Defrost Timer
Problem for Paragon 8145-20 Defrost Timer
MY 8145-20 DEFROST TIMER WILL NOT ADVANCE,
By butterflylad on Feb 16, 2009
I HAVE HAD A 8145-20 DEFROST TIMER ON MY FREEZER THAT STOPED ADVANCING, THOUGHT THAT THE MOTOR WAS BAD . REPLACED THE TIMER WITH A NEW TIMER AND THE CLOCKE WILL STILL NOT ADVANCE? ANY THOUGHTS R.B.H.
Comments:
Feb 16, 2009
- voltag to timer is off the main breaker and is hot but reads only 110 secound link comes from the walkin freezer, could it be the thermostat or defrost termination, would these have a hot loop back to timer? when the timer is advanced by hand the freezer will defrost . thanks r.b.h.
Clarification Request
Posted by Smithbrother on Feb 16, 2009
Voltage to timer?
Best Solution
posted on Feb 16, 2009
Very Helpful)
Smithbrother
Rank: Wiz
Rating: 82%, 1349 votes
I am not sure of your wiring but see no reason that you could not run straight from the breaker to the timer and the timer to the freezer. Determine how long you want the defrost time to be on each hour and set the pegs accordingly. This is if I understand or picture your timer correctly. You have a walk in Freezer, and a rather large box 110 volt timer,correct? The pins on the 24 hour timer wheel can be taken off or moved? If I am wrong, I am sorry. I have the wrong picture in mind.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Paragon 8145-20 Defrost Timer
Questions and Unsolved Problems for Paragon 8145-20 Defrost Timer
Do you recommend Paragon 8145-20 Defrost Timer?
Answer
Answer
need time delay stops for paregon model 3405 24 hr. timer
Answer
I have an Amana side by side that would not cool. Replaced defrost timer and defrost thermostat. The... (More)
Answer
Hello, can you tell me where can I find online install and use instructions for a Paragon 8145... (More)
Answer
no matter what the defrost timer is set at only stays on for five minutes or less
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Paragon 8145-20 Defrost Timer:
Top Timer Experts
Rank: Guru Guru
Solutions: 901
Experience: im the jack of all trades but a master of none! and being an old git you get to learn a fuw tricks
Ask Me
Find more Timer Experts
Top Garden & Power Tool Repair
(800) 937-7279
Replacement lawn mower and snow blower parts from...
Commercial Parts Warehouse
(509) 678-4379
Precise Engine Repair proudly represents Briggs...
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
