Question about Digital Audio PCDJ Dac-2 Controller & PCDJ-Red S/W System
Cleaning the dac 3
I'm trying to take the top pannel of my dac 3 so i can clean the contacts on my play and cue buttons as the smoke from the bars have created some build up on them, I don't know how to remove the jog wheels do they snap off or what. I dont want to take a chance on breaking it any help would be helpful thanks a DJ in Wisconsin
$150? I'm very surprised to hear that...especially when it's not the actual switches that are the problem.
My DAC 3 buttons were becoming sticky and non responsive so i bought a can of electrical contact cleaner, took the unit apart and sprayed all the buttons on the main boards with it. After putting everything back together, it's working perfectly again.
The cleaner cost me about £4 gbp and time to dismantle, clean and reassemble was about an hour all in.
Certainly alot cheaper than $150!!!
Posted on Jun 21, 2010
Did you ever figure this out? My Cue/Play buttons have gotten to where they don't react half the time, which is very annoying. I took the screws out of the top plate, hoping it would just come off and then I could clean under the soft-touch buttons, but it didn't. I took the screws out of the side and was able to remove the enclosure, but didn't see an easy way to get to the buttons. (It looks like you have to remove the little "C" clips from the end of the axle which the jog wheels attach to in order to remove them). I just put it back together until I can find more instruction.
Posted on Jan 12, 2010
  • Tommy Evans
    Tommy Evans Mar 18, 2010
    I ended up taking it to a repair shop here in Dallas. It cost about $150 for them to replace the two PLAY switches.
Sony dtc 77es
This usually caused by a defective state sensor on a DAT type deck.
They are sensitive to smoke contamination. They might be possible to clean and recondition if the sensor was taken out.
Apr 25, 2014 | Audio Players & Recorders
Hi my sony dvp-fx820 keep giving me "Can Not Play the disc"???I Message.I have other dvd player it also giving me same Message I Accidently Pushed the progressive button. I'v fixed the problem by...
Laser probably needs to be cleaned. If you can get to the laser eye, check for scratches. With a foam cue tip or lint free cloth, not a cotton swab, with very very light denatured alcohol wipe the eye clean of debris. Clean eye once again with a dry lint free cloth. Check again for scratches, if no scratches the eye should be clean. If this doesn't work, try flipping the player upside down and secure where player is steady. Push the play button and see if it will play. If the player works in this position, that means the mechanics that move the eye up and down are weak. The entire eye assembly needs replacing.
Nov 02, 2010 | Sony DVP-FX820 DVD Player
My cue button on my cdj 1000 mk2 kept jamming so i got some foam cleaning stuff from a dj shop and sprayed it on the cue button now it started going mad skipping traks, playing in reverse. i think that the...
cue button sticking sounds like the button on the pcu board needs replaced, I would clean all the foam stuff of if possible, as for the screen not working sound like some of your wires have come unconnected easy fixed just plug them back on to the pcu board
Mar 28, 2010 | Pioneer CDJ-1000 CD Player
The blue will not converge, how can I manually do it? The blue appears to be showing bottom left corner below the screen, like it got moved.
I had the same problem but it wouldn't converge on the whole right side of the screen. I fixed my problem by taking off the speaker cover, removing the 3 allen 7/64" screws from the front of the bottom of the button pannel, then removing the 4 scew from the back of the pannel (2 on each side), and the button pannel should drop down. With the power on I cleaned the 3 projection lenses with many qtips dipped in alcohol. I left the TV on so I could see if there was any streaking on the lenses (streaking means it is still dirty). Once they were all clean and I put the button pannel back on, I went to the menu and ran the autoconvergence function. Now my picture is so clean. Good Luck.
Mar 03, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
Cant cue up cd, it just starts playing when inserted
Hey,
no need to worry, there may be problem with micro switch.
Micro switch is that when u press cue there is a another micro switch just bottom of the cue button. I think micro switch needs to be replace and all done.
thx,
djajay
Feb 18, 2010 | Pioneer CDJ-800 Turntable
What is the cue/f play/erase button on the top
When in RECORD, pressing the 'Cue' button will put a tone on the tape. This is used on the transcriber's machine to identify different jobs and such.
When in PLAY, pressing the 'F Play' button will change the playback speed to 1.5.
If you hold the 'ERASE' button and hold the portable in REWIND, it'll erase the tape while it's rewinding.
Hope this helps...
Jul 13, 2009 | Dictaphone Audio Players & Recorders
Cdj-500ll cue button repair
the faulty button will not stop it from playing well... replacing them is not hard so long as you have some experience with a soldering iron.
Clean the laser lens with a cotton bud wet with windex... then use a dry one to be sure no residue is left. If it still mistracks... new optics required!. You willl need a pioneer service agent to do this for you. A little complex for the first timer :)
Jan 08, 2008 | Pioneer CDJ-500II CD Player
Menu keeps popping up
Never a good idea to clean with any spray cleaner. The cleaner does get down in the button bar and cause corrosion and shorting along ribbon cable. Use screen wipes for computer monitors only on TV's and any type of monitors. You can remove the back of the case. And remove the button board and clean with a cue tip and alcohol along ribbon cable.
Nov 04, 2007 | Acer AL1912 19" LCD Monitor
CDJ 800MK2
the cue switch has to be cleaned by a technician. if that doesnt work. replace the cue switch.
Jul 15, 2007 | Pioneer CDJ-800MK2 Turntable
Digital Audio PCDJ Dac-2 Controller & PCDJ-Red S/W System Logo
143 people viewed this question
Top Digital Audio Audio Players & Recorders Experts
jpmax14
Terry Hair
Tom Chichester
Are you a Digital Audio Audio Player and Recorder Expert? Answer questions, earn points and help others
