Question about Logitech QuickCam Fusion 961403-0403 Webcam
  • 8,637 Answers
Normal 0 See section B. Yahoo Messenger in the info below to setup the Audio & Video.
Also send this to your family and friends so they have their computer setup properly.
Web Camera’s have to be setup on the program they are to be used with. Just installing the camera on your computer does not set it up to broadcast on messengers or Skype.
Each program has Options that have to be setup in order for the Audio and Video to function properly.
A. Skype Setup:
After downloading and installing Skype ( set it up as follows:
  1. Go to Tools, then Options, and click on Audio Settings and set the Microphone and Speakers to the computer Audio Card.
  2. Then click on the Video Settings.
  3. The camera if Installed Properly will come up and show a video picture.
  4. Then, on the bottom of the page click on Save.
The camera and audio should function properly. Your friends and Family will now be able to see and her to you.
B. Yahoo Setup:
After downloading and installing Yahoo Messenger ( ) set it up as follows:
  1. Go to Messenger at the top left and click on it.
  2. Next go down to Preferences and click on it.
  3. Next Calling and Devices on the right and set the Microphone and Speakers to the computer Audio Card.
  4. Next go to the Test Audio section and (in blue writing) click on “Open the call setup assistant” and follow the instructions on the left window.
Hope this helps. Bud
Posted on Jun 24, 2009
Why does my webcam show a black screen?
Which version r u using? 8 or 9 beta?
1.for 9 beta:
*Can you see your cam clearly? I mean no black screen.
If your web-cam is having black screen, then you have to set it.
On main messenger screen:
click messenger
click connection
tick "connect directly to the internet"
click apply and ok.
Then open your cam and check if it working or not.
2*Follow the steps below to change your camera source.
Click "Messenger"
Click "My Webcam.
Click "Messenger" again.
Select "Preferences."
Click "Webcam."
Click "Camera Source."
Click the pull-down menu and select the camera you want to use.
Click "OK."
*Best is to visit following link:
*Messenger 8 :
First, please check your connectivity settings within Yahoo! Messenger to make sure you're not connecting through a proxy server. Here's how:
Select " Yahoo! Messenger."
Select "Connection."
Select "No Proxies."
Click "OK."
Close Yahoo! Messenger completely and start the program again. This should eliminate the error message.
please visit these site , to learn more
Apr 28, 2011 | Yahoo Messenger
In Yahoo Messenger I cant use my webcam
first you properly install the Web Cam Software, then you open the Yahoo messenger and again access the web cam. I hope it will work fine. sometimes yahoo messenger not access to Web Cam, that time yahoo messanger not working properly.
Aug 14, 2009 | HP Pavilion dv6000z Notebook
Yahoo messenger error 81003016
HI welcome to fixya free solutions. you are getting this error because of connection error! try to go to messenger then connection preference, its on the top left of your yahoo messenger..choose connect directly to the internet then apply. mess 9 noted for this error.
Messenger "9" 1st version was in Beta (testing) form. The newest version is not, But it's not working well either.Try using 8.1 "the newest before 9", until they work out the Bugs. Including people using 8.1 or older versions trying to message ones with 9 or reverse they are having compatibility problems; like text not showing,pictures not showing.Chat rooms not found or opening. It shuts down on Vista users , not allowing people to log in.Web cams do not always work. Many things do not work or are missing that YM 8.1 has. It Seems for Vista users it is so buggy Yahoo is giving up on it and are no longer trying to fix it.…
You need to remove version 9 completely 1st to Get version 8 to work best.Left over files and fragments from using control panel to remove messenger can cause problems/conflicts with the new download.
Use this method: Start,My PC, C drive, open Program files.Next open Yahoo file then Messenger file.Click on UNWISE to Un install messenger 9 completely. Do not just delete yahoo file as this can cause problems with other Yahoo programs.
Download the newest 8.1 here…
Your contacts list and messages are stored online and will be there when you return to 8.1 messenger.
And it works well with Vista.
Another big problem is with the latest update for Flash Player
Flash player 10 Does have conflicts and is causing things to not load or just crash upon opening..Use the link below for a download of Flash player # . You have to remove the present flash player,add/remove programs in control panel,Reboot then download from here.…
Some people are losing signal,things fade out, freezing up or getting disconnected . This can be caused my running low on virtual memory! You can increase your memory by going to start button, settings, control panel, system, advance tab, performance, advance tab, virtual memory, change it, make it 1500 kb or higher, In both boxes, click apply then ok . This applys for all instant messengers,MSN, Yahoo,skype ect. And yahoo games.
More help can be found here;
If none of these work for you then kindly do comment back to me.
Aug 05, 2009 | Yahoo Messenger
Try using a program called SplitCam. Simple program that acts as an interface between webcam and other applications. Often solves the issues like you are facing.
Mar 29, 2009 | Microsoft LifeCam NX-6000 Webcam
Sony Vaoi built cam doest work on messenger
i have a gateway fx gameing laptop!! i was having probs with the cam going dark on me after a bit while using yahoo was also freezing up but that i found out was cause yahoo SUCKS **** LOL...
i downloaded msn messenger, not msn live, and the cam works fine.. so it is yahoo.. i do know that sometimes my cam will sometimes go darker in resolution if i bend the top down a bit.. its doing that because the cam is thinking that im turning it off by shutting the laptop!
does the web cam work with the software it came with? can u turn it on and see urself when NOT using a messenger? if so then it might just not want to work with those 2 messengers which is weird!!!!!
MAKE SURE THAT U DO NOT HAVE THE PROGRAM SOFTWARE on that came with the laptop at the same time as trying to use it with the messengers!! see if that works and ill check back with you!
laptops did not come with the high end state of the art web cams! they were made for ease not for exceptional quality!
Mar 22, 2009 | Sony VAIO VGN-SZ430N/B Notebook
Webcam not working..says not found!
solution 1: reinstall your yahoo messenger
solution 2: reinstall your web cam driver again.
Jan 19, 2009 | Acer Aspire 5500 5570-2609 Laptop
A Plug and Play Webcam wont work on Yahoo Messenger
in your YM.. open the Messenger tool bar.. then.. My Web cam.. then.. .Preferences.. then Camera source... and select the installed webcam.. and see how it works..
Jan 13, 2009 | Yahoo Messenger
Web cam getting network error
goto yahoo messenger -> prefrences - > webcam -> camera source check if it found or not if not reinstall the camera driver hope it willl found and work
Oct 15, 2008 | Yahoo Messenger
Yahoo messenger Intel
this occurs due to 3 causes.
1. your windows filed are corrupt.
2. the driver files of your cam are corrupted.
3. yahoo msngr files are corrupted.
The best solution i can give you os to format your PC...
or try changing the USB Ports. it may help.
Mar 09, 2008 | Logitech Webcam
No transmission when used with messenger
Hey guys I'm having the same problem i got the logitech quickcam express and when I try to connect to yahoo and even aim it comes up connecting...then attempting to reconnect, then an error message comes up. The cam works fine, it just won't connect to the messengers. Did you guys figure it out? Thx B
Nov 14, 2007 | Logitech QuickCam Express Web Camera
Logitech QuickCam Fusion 961403-0403 Webcam Logo
148 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
